Old 03-21-2013, 11:20 PM   #85
Cryotechnician
Drives: WRB Burzuh
This actually just happened to me today and I was on a slight incline aka my driveway. It happened when I had the car in September too ... also on my inclined driveway.
Cryotechnician is offline   Reply With Quote
Old 03-21-2013, 11:47 PM   #86
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Car not getting spark from the fuels, or maybe you were low on gas?
LeeMaster is offline   Reply With Quote
Old 03-21-2013, 11:52 PM   #87
Cryotechnician
Drives: WRB Burzuh
lol definitely not low on gas, filled up on the way home from school. I can understand the engine not getting a spark but my wonder is why only on an incline will this occasionally happen? I recall reading it happening to other people on inclines
Old 03-21-2013, 11:59 PM   #88
Steve
Steve's Avatar
Drives: 6MT
Haven't had this problem or even a hesitation now that I wait for the key-in-beeps to end.
Steve is offline   Reply With Quote
Old 03-23-2013, 12:31 PM   #89
dolph
Drives: 2013 BRZ, 2004 WRX
The first time I started the car (auto w/ push button) at the dealership, it struggled for a good 3 seconds before it fired up, salesman looked concerned but I couldn't reproduce. Since then, I've had just a few incidents where it wouldn't start at all until I cycled the ignition completely off and tried again.
It's always started though, and hasn't struggled again (6500mi).
dolph is offline   Reply With Quote
Old 03-23-2013, 02:33 PM   #90
QuikSilveRX-8
QuikSilveRX-8's Avatar
Drives: SE3P
HA! I wonder what kind of TSB will come out for this problem. A lot of complaints, no absolute solution? It's best to try this everytime:
Originally Posted by russv View Post
Try giving it a moment once you turn the key to the first position for the fuel pump to prime the injectors. I've had this problem occasionally.
Three moving engine parts, yet complicated... Or do I mean complex?
QuikSilveRX-8 is offline   Reply With Quote
Old 03-31-2013, 08:40 PM   #91
Msnicoleeeee
Msnicoleeeee's Avatar
Drives: Firestorm FRS
So my car isn't starting whatsoever... I had my uncle install an alarm, an HID kit from DDMTuning and DRL lights from Fuzion Teknique today.. For the past 3-5 days, in the morning, I would try to turn on the car and it would stall for a bit and struggle to turn on but eventually it would start. But now, after having all this stuff being installed, it won't even turn at all!! It's making this big... Clanking sound like a wrench being hit on metal repeatedly. My uncles both think its the starter, but this is a new car, had it for almost 2 months with 2500 miles on it...
Not sure what to do. What should we check? Should I just call Scion?
Msnicoleeeee is offline   Reply With Quote
Old 03-31-2013, 09:47 PM   #92
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Sounds like your mods are draining the battery over night. Unhook the battery before you park it after charging it up (drive it around a bit and let the alternator charge the battery, when it doesn't start in the morning try jumping it) and I bet it will fire right up in the morning. Your uncle probably missed a wire.
As for a TSB, nobody's been stranded and I doubt it's anything other than people not allowing the fuel system to pressurize before trying to start the car.
ineedyourdiddly
Old 03-31-2013, 10:21 PM   #93
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by 5hairpins View Post
When I remember to wait at the ACC position on the key, it fires up everytime. If I just turn the key, I may get the delayed start or no start.
Maybe if a I quote this response, people will start getting it...
The Following User Says Thank You to Lonewolf For This Useful Post:
strat61caster (04-01-2013)
Old 03-31-2013, 10:37 PM   #94
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
My car struggled to start the other day. This is the second time it's acted this way; it sputtered to life after cranking instead of firing right up.
Subie is offline   Reply With Quote
Old 03-31-2013, 11:02 PM   #95
Msnicoleeeee
We just installed everything today.. So not sure why its doing this.
Well the car turns on fine now BUT it won't shift into any gears.. WTF.. We're all at a loss now.
Old 04-01-2013, 11:43 AM   #96
strat61caster
Hmm doesn't make sense. At this point your best shot is probably a dealer.
You could make a thread detailing everything and someone might come up with a solution but it really doesn't fit into this thread any more.
ineedyourdiddly
Old 04-02-2013, 03:31 PM   #97
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
2200 km on my car
had this issue two times so far, once around 500km and once at 1500.
both times it wouldn't start for 3-4 seconds. I'd let it sit for a few sec and give it a 2nd try and it would fire right up.
was at the dealer today and mentioned the issue, no fix.
nos145 is offline   Reply With Quote
Old 04-03-2013, 12:44 AM   #98
QuikSilveRX-8
Drives: SE3P
That's the problem with this thread, many would just want to post their problem and seem to miss one important thing: reading the previous posts.
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 02:34 PM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
trunk wont unlatch bakerr6 Issues | Warranty | Recalls / TSB 9 09-24-2012 01:32 AM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 03:28 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
