Old 03-31-2013, 04:52 PM   #71
Turbowned
Turbowned's Avatar
The FA20 is a beefy motor. If you're not shooting for more than 350hp and not planning on endurance racing the thing, I wouldn't bother with more than a new OEM short block. This isn't the engine's fault; this is the fault of improper installation.
The Following User Says Thank You to Turbowned For This Useful Post:
TRD_07 (04-01-2013)
Old 03-31-2013, 05:09 PM   #72
Frs300
Frs300's Avatar
Drives: Pile of junk
Tansey i had already asked about that before it even blew up
Frs300 is offline   Reply With Quote
Old 03-31-2013, 05:20 PM   #73
GNS
Drives: .
Originally Posted by Frs300 View Post
ya i ment bov sorry. im at work doing 100 things at once.
i was going to install my gauge pod that night. this dealership has done turbo/sc on trucks quite a bit. i should have drove to mn and had fullblown install it.
FullBlown you guys have the heads ready yet? i may need some lol
May I ask how much you saved by getting Toyota to install the kit vs driving out to get the vendor to install it for you?
GNS is offline   Reply With Quote
Old 03-31-2013, 05:26 PM   #74
Frs300
Frs300's Avatar
im in florida fullblown is in minnesota. so that was out of the question. looking back i should have went that route. would have spent a bit more money but my car would still be running. im sure they would have hooked me up on install with all the parts i purchased from them
cost of install
hotel
gas
food
Old 03-31-2013, 05:50 PM   #75
bakerr6
Drives: 2013 raven black fr-s
cost of install
hotel
gas
food
You would have saved on shipping haha
bakerr6 is offline   Reply With Quote
Old 03-31-2013, 05:51 PM   #76
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yeah, no point in keeping rehashing what could have been...
Old 03-31-2013, 05:58 PM   #77
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
How are you finding 96 octane in the Bay Area?
@OP-Sorry for your loss. And not to kick you while you're down or anything, but I will say that spinning the tires in first and hitting 6000 rpm in second doesn't seem like "normal driving" to me, especially on a not fully setup or tested brand new turbo setup. I know the pull of boost and the excitement of your new setup is hard to resist, but I think this could have been avoided if you had waited to beat on the thing until you had all your sensors etc. setup and working. Heck, I wouldn't tune a factory turbo car much past stock without a wideband and some way to monitor the boost, much less a full aftermarket setup.
Nathan
SubieNate is offline   Reply With Quote
Old 03-31-2013, 06:13 PM   #78
Frs300
Frs300's Avatar
yes ill admit if i had a wideband and or boost gauge installed it might have been preventable. Still doesnt excuse the fact something was more than likely installed wrong
Old 03-31-2013, 06:55 PM   #79
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
@Frs300 out of curiosity, did your engine have any weird noise when you started it? my engine has a weird sound in that exact area where your hole is since i installed my turbo kit. at first, i thought it was my turbo that was dry and missing oil, after many checks and stuff its getting its oil but the weird noise is still there. i removed my serpentine belt and checked all my pulleys for a bad bearing and the alternator as well but all is fine. i started the motor again and it still sounds weird. i dont know if you are getting your oil feed from the same location as me and if your turbo uses an oil restrictor but mine doesnt. i am starting to wonder if its not a lack of oil in that area in the motor caused by the turbo oil feed.
i simply turned my car off and i am debating removing my whole turbo kit and going back to stock just to start the motor again so that i can compare the noise with or without the kit.
Silverdub is offline   Reply With Quote
Old 03-31-2013, 07:01 PM   #80
Frs300
Frs300's Avatar
no weird noise that i could hear...just bov opening and closing at idle
Old 03-31-2013, 07:04 PM   #81
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
maybe im just being paranoid since i built everything myself and its a brand new car...
Old 03-31-2013, 07:05 PM   #82
86pro
Drives: frs
I agree, i think your fuel pump wasn't properly installed. Hence why you werent getting the right power and putting strain on engine. It was only a matter of time. Next time park it up until you sort it out. Sorry to hear that you blew your engine and look at it in a good way, when you build back up go all out.
86pro is offline   Reply With Quote
Old 03-31-2013, 07:13 PM   #83
Frs300
Frs300's Avatar
should get this
http://store.crawfordperformance.com/store/products/654
Old 03-31-2013, 07:14 PM   #84
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
no heads though.... hope yours are still good! if they are just do it!!
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 04:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 10:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 09:24 PM
