Old 03-29-2013, 08:24 PM   #1
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
No maf no start?
Im waiting on a maf housing from treadstone performance and i am wondering if my car would start without a maf hooked up. I know my vdub would but would run rich. I would run the car without boost obviously with the wastegate open.
Silverdub is offline   Reply With Quote
Old 03-29-2013, 08:39 PM   #2
charged86
charged86's Avatar
No idea. I could run mafless on my big turbo 1.8t
Old 03-29-2013, 08:43 PM   #3
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Should i try lol
Old 03-29-2013, 08:48 PM   #4
charged86
charged86's Avatar
Should i try lol
Just turn it on for a second. Might not turn over. Make sure your ventilated. All I can tell ya
Old 03-29-2013, 08:50 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
If you disconnect the MAF the car should revert to speed-density as I think it has a MAP sensor, or Alpha-N if everything is completely fubar
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
charged86 (03-29-2013)
Old 03-29-2013, 09:03 PM   #6
SloS13
Drives: 2013 FR-S whiteout
If it's like a KA24DE, it'll idle fine but not run with any load on the engine.
SloS13 is offline   Reply With Quote
Old 03-29-2013, 09:25 PM   #7
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
It idles good, crazy smell in the garage now from all the new stainless piping. Had a coolant leak, fixed allready. Also check my oil feed but almost seems dry... Ill check it out tomorrow
The Following User Says Thank You to Silverdub For This Useful Post:
Old 03-29-2013, 11:51 PM   #8
charged86
charged86's Avatar
u
Git r done
Old 03-30-2013, 08:51 AM   #9
Visconti
Drives: 05 STi
Car has a pretty complex sd system .. Should run fine with no MAF
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
Silverdub (03-30-2013)
Old 03-30-2013, 09:12 AM   #10
wparsons
wparsons's Avatar
If it has a good SD system, why does MAF placement make such a big difference in AFR on aftermarket intakes? Does it rely primarily on the MAF unless there's an issue with it?
flickr
Old 03-30-2013, 09:43 AM   #11
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Thanks @Visconti as soon as i get my stupid maf housing im ordering my tune! I just cant wait
Old 03-30-2013, 10:14 AM   #12
andrew20195
Drives: 2013 Subaru BRZ
Most cars with MAF/SD rely primarily on the MAF except during rapid load transitions. The MAF tends to be more accurate (if properly calibrated), but SD responds to changes much more quickly.
andrew20195 is offline   Reply With Quote
Old 03-30-2013, 10:26 AM   #13
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
SD relies on MAP and/or oxygen sensor?
Old 03-30-2013, 10:31 AM   #14
andrew20195
Speed Density relies on MAP (Manifold Absolute Pressure) and IAT (Intake Air Temperature), from which it calculates density, checks engine speed, then looks up the result on the Volumetric Efficiency table stored in the ECM to determine fuel delivery.
If it's in closed loop, it will adjust fuel trim based on A/F sensor feedback. Not sure about the 86, but most cars are open loop at idle and wide open throttle.
The Following User Says Thank You to andrew20195 For This Useful Post:
Remote Start Anyone? arleewa BRZ First-Gen (2012+) — General Topics 43 08-20-2014 02:43 PM
BRZ wouldn't start Pete156 Issues | Warranty | Recalls / TSB 57 05-29-2013 07:36 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
