go_a_way1
Old 03-26-2013, 07:53 PM   #1051
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by djdnz View Post
Thanks man, yeah the rear looks spot on. I have a feeling the front will look more like this though :*(
I'm confused though, these are 18x9.5 +42, yet I've seen pictures of the Gram Light 57Xtreme's in 18x9.5 +40 and they don't seem to be as pokey. Maybe they have just been running more camber? I'd like 1.5 deg front, 2 MAX.
Its all about the size of the tire and the drop. The further you go the less poke you could end up with, given you fix the natural camber that comes with the drop(Lower control arms or bolts) Theres a wheel out there that is 18x8.5 and 9.5 +48 respectively that will give you NO poke issues whatsoever.
Here they are http://www.ft86club.com/forums/showthread.php?t=31556
Tansey86 is offline   Reply With Quote
Old 03-26-2013, 10:06 PM   #1052
Rudiris
Drives: Scion fr-s hot lava
XXR 527 18x8.75 +20 Chromium Black Rims will this fit thanks in advance
my car is just like a stripper i keep throwing money at her hoping for the show to get better
Rudiris is offline   Reply With Quote
Old 03-27-2013, 12:18 AM   #1053
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by Slick View Post
Hey ilpad,
When are you looking to buy your wheels?
I will have mine back with tires mounted in a few days, same size too 245/35R18 in a Conti Extreme Contact DW.
As for fitment, I was pretty surprised when I initially test-fitted the wheels, not so much because of the fitment calculator but because there seems to be many others running with this wheel width (both in 17 and 18") and a +35 offset.
The camber/crash bolt makes a difference and so will springs as well. The H&R's should give you more camber than the ProKit I am going with.
It's hard to judge where it will all end up, but I think I'll be okay which is why I ordered the 245s after the test-fitting.
Proof is in the pudding.
I fitted the set of 245/35R18 on 18x9 +35.
Here's some pics at stock height.
Stock suspension for now, really only test-fitted until weather gets better and springs/alignment are done next weekend.
After these photos, winter wheels were put back on the car. Hopefully the majority of the snow will finally be gone after next week.
There is a bit of poke so far.
This next pic shows clearance between the spring perch and the tire. The tire's rim saver edge is the closest to the spring, whereas the wheel rim is just below the perch.
Without a crashbolt, clearance is 12mm, with the crashbolt in place it is down to 8mm. Seems tight, but can go even more.
With springs installed, suspension settled and after an alignment, it should look pretty close to flush from the top, maybe a mini-poke.
Will post more pics once suspension is done.
Btw, wheel/tire combo weighs 1/2 pound less than stock, pretty happy about that. Here is a pic showing the difference between the OEM size winter and the new Contis. Quite surprised that it looks stretched, could've fit a 255 easily!
Slick is offline   Reply With Quote
Old 03-27-2013, 12:20 PM   #1054
tennisfreak
Drives: 2018 BMW M240i
17/7.5 Wheel and Tire Setup, Your opinion
So I have been looking at wheels and tires like crazy wanting to purchase something that looks and performs better than stock. I definitely dont want wheels that weigh more than stock and would love to come in under 19lbs.
I ran across this little gem of a wheel weighing only 16.3lbs and only cost $173!!! Motegi Racing MR125 http://www.tirerack.com/wheels/Wheel...ed&showRear=no
I wanted to go with an 18 wheel but to get down below 20 lbs I am going to spend $250+ per wheel.
As for tires I am looking for a great performer but something that can also be a daily driver and not wear out in 10,000 miles.
My current selection is Bridgestone Potenza S-04 Pole Position which run about $154 each: http://www.tirerack.com/tires/tires....cleSearch=true
Only downside to this setup is the lack of width I guess. Its not a 8 or 9 inch width which could give up some grip.
What do you think?
Old 03-27-2013, 08:49 PM   #1055
Flako
Drives: Asphalt scion frs
Ok so I'm stuck I'm trying to see if 18x9.5 + 40 will fit all around on a stock suspension and if not what exactly I need to make them fit! I know nothing about aftermarket wheels =[ help?
Flako is offline   Reply With Quote
Old 03-27-2013, 08:54 PM   #1056
Tansey86
Tansey86's Avatar
http://www.ft86club.com/forums/showthread.php?t=31920
Old 03-28-2013, 12:45 PM   #1057
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I like them in matte gray better!
Old 03-28-2013, 01:32 PM   #1058
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
What do you think?
If staying with 215/45-17 I'd get a Mich Pilot Super Sport - that will be fine on your rim, grip WAY more and still be light. It's wider than a normal 215.
Only reason to go 8 or 9 inches is if you are thinking about a 235 or 245 or bigger tire. More grip for racing but less mpg, heavier steering, etc for normal driving. 225 series on a 17 doesn't really fit our cars IMO.
Khyron686 is offline   Reply With Quote
Old 03-28-2013, 01:37 PM   #1059
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
215 or 225 in stickier summer tires is more than enough for street driving. A 7.5" wide wheel is fine.
I can't say I'm a fan of that wheel, but if you like them, that's fine. For around that price (a tad more) I'd be running Kosei K4Rs, personally.
Can't say I like your tire choice, though. Michelin PSS are basically the same price and are a much better tire.
MVJ1975 is offline   Reply With Quote
Old 03-28-2013, 01:42 PM   #1060
Subabie
Drives: BRZ LTD
tires fitment
OK! I am not lazy, I did search for an answer in this forum but non found!!
So here is my questions:
I want to keep the stock rim of my brz but would like improve the the thickness of the tires hopefully to get a smoother ride and less "lift" look on the car
if I change my tires to 215/55/17? will it serve the purpose? Will I run into any problem??
Thoughts and advices are appreciate!!
Subabie is offline   Reply With Quote
Old 03-28-2013, 01:49 PM   #1061
Khyron686
I'm running 215/50-17 as my winter setup - gives me the extra inch of ground clearance. But you notice when driving that the wheels are bigger - it's basically making every gear higher. No way in hell I'd go 55. Odo/Speedo is off by a few %.
One thing I did notice is that the slush/ice does get caught between the tire and the fender. Not a ton of room there. I will probably go back to stock size next set.
Old 03-28-2013, 01:51 PM   #1062
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
The sidewall on the 215/55 will be almost an inch taller (.9 inches) than the stock 215/45/17. You will have less wheel gap and your car will sit off the ground an inch more.
You could try going with a closer-to-stock size tire, but one that's less performance oriented so it has softer sidewalls.
Grimlock is offline   Reply With Quote
Old 03-28-2013, 01:53 PM   #1063
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
A 215/50 is about an inch taller in diameter than stock, but it'll only give you an extra 1/2 inch of ground clearance.
Old 03-28-2013, 04:51 PM   #1064
tennisfreak
Thanks for the opinion. I checked out the Kosei K4Rs and they look great plus they are even a little lighter!
As for the tires your right I will switch over to the Michelin.
Thanks!
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
