Old 03-27-2013, 06:45 PM   #15
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Originally Posted by rice_classic View Post
If it's driven on the street you gain not from running a race-only oil. You need a "compromise", an oil that good enough for the track but has the necessary ingredients for the street (detergents etc). Many street oils are so good they work very well under racing conditions.
If you have a dedicated race car that's never left outside in the cold you really should be running a dedicated race onlyoil, they're just that good.
I see some excellent oils in this thread. Good thread, but surprised nobody mentioned Joe Gibbs, one of the undisputed champions of racing oil development.
http://www.drivenracingoil.com/dro/xp3.html
Interesting, so what are the factors one need be concerned with if they elect to run the 300V on a car thats track and street, always garaged, I'm fine with the shorter intervals/higher running costs. is it fine for 500 cold starts?
Huehuecoyotl is offline   Reply With Quote
Old 03-27-2013, 06:48 PM   #16
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by AZP Installs View Post
Haven't seen that used in subies yet. It may be because no one thought to use it or perhaps it is similar to Mobil 1 which does not do very well in Subies at all.
-Mike Paisan
You should not see this being used any car that isn't a dedicated race car at all. How many race-only Subarus do you normally see? I've only seen 2 around here. Also, Joe Gibbs race oil is not similar to Mobil 1.
PRO86 | WTCC | STL
Old 03-27-2013, 06:50 PM   #17
rice_classic
For you're car? Anything's possible.
Also, loaded question, you already know the answer.
PRO86 | WTCC | STL
Old 03-27-2013, 07:05 PM   #18
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
Hmmm. I was contemplating tossing in some 0w-30 euro spec mobil 1 i have left that was intended for my old A4. Whats wrong with mobil 1?
supramkivtt2jz is offline   Reply With Quote
Old 04-05-2013, 10:07 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah, not at all similar.
I don't know of any dedicated subaru race cars locally.
The only problem I have with race oils is that our race car burns way too much to afford them lol
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
SkullWorks (05-15-2013)
Old 04-06-2013, 05:23 AM   #20
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
.....Mobil 1 which does not do very well in Subies at all.
Could you please elaborate on that?
Old 04-06-2013, 09:20 AM   #21
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
This is a good read.
http://store.forcedperformance.net/m...otor%20Oil.pdf
Deadspool is offline   Reply With Quote
Old 04-06-2013, 02:38 PM   #22
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
We've been doing oil changes on Subies for 10+ years.
Over that time we've done 6,000+ oil changes on Subies.
We've found Mobile 1 and Subaru Synthetic to consume the most amount of oil between changes, on average about 1Q per 3,000 miles. While Motul 8100 C3 X-Clean 5w30 and Amsoil 5w30 both generally go 5,000-7,000+ without consuming any oil or <1 Quart and still yield great blackstone results.
-Mike Paisan
AZP Installs is offline   Reply With Quote
Old 04-06-2013, 02:40 PM   #23
AZP Installs
Up here we have lots of dedicated Subie race cars actually
I agree though that you need a balance between a good protective oil and what is fiscally smart. Similar to using less expensive rotors since they are considered a wear and tear item on a track car.
-Mike Paisan
Old 04-06-2013, 03:24 PM   #24
D1cker
Drives: B9 S4/ND2
Have you guys been using the Amsoil 5w30 Signature series? I plan on running it with a 5k OCI, i went with it over the motul as I get it for about 60% of the cost of the motul.
D1cker is offline   Reply With Quote
Old 04-06-2013, 04:59 PM   #25
AZP Installs
We've been using and are an Amsoil dealer for about 9 years. The 5w30 Signature is what we use in conjunction with their extended life oil filters. Very good results via blackstone and our own ad-hock testing. If you get it for less than the Motul cost, then use it. We sell a lot more of the Motul these days because our cost on the Motul is much less than that of the Amsoil and therefore our customer cost is also that much lower.
-Mike Paisan
Old 04-06-2013, 05:19 PM   #26
D1cker
Drives: B9 S4/ND2
Thank you for the reply. I was actually referring to the motul 300V for the increased cost instead of the 8100. How would you compare the 8100 to the amsoil?
-Mike Paisan
Old 04-06-2013, 05:27 PM   #27
Captain Snooze
Drives: Red Herring
Disclaimer: I have never had a uoa performed. I am basing my following comments from the little reading I have done about oils from the internet. So much information!! Some of it true. Please bear with me.
Originally Posted by Deadspool View Post
I am suggesting that Mobil 1 was no good in that engine. I have read a few times that there is no "best oil"; different applications respond differently to different oils.
You are saying that Mobil 1 is consumed at a higher rate than other oils in Subaru engines. How would you rate it's lubricating/anti-wear abilities?
Besides the expense of having to add oil on a regular basis is high oil consumption indicative of anything else?
Thanks for the education.
Old 04-06-2013, 05:30 PM   #28
AZP Installs
We like the 8100 as well as the Amsoil, for our purposes we feel the Amsoil is great for extended OCI >7500 miles. The Motul comes back with great numbers with 7500 mile OCI.
-Mike Paisan
"Come Race Me Bro" Encounters GH05T FR-S / BRZ vs.... 2565 02-28-2023 09:34 AM
New 4-2-1 Long Tube Header Anorexic 86 Engine, Exhaust, Transmission 28 08-25-2013 03:28 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
