Old 03-11-2013, 11:54 AM   #1
CSG Mike
CSG Mike's Avatar
Regarding "Race" oils.
Cross posted from a discussion here: http://www.ft86club.com/forums/showthread.php?t=30742
Originally Posted by icemang17 View Post
motul makes a quality product....far superior to the oil that our engines was designed to run....no worries....ZERO..... 3-4 events per year isn't that hard on the car.....as long as the oil is fresh prior to event (or sorta close)
My experience.....the quality of oil you run is HUGE, unreal really.....Motul makes a quality product, as does Royal Purple, Redline and Amsoil (I am a Amsoil dealer).... While I am not 100% certain of Motuls exact blending, one thing you DO NOT want to do is run true race oil in a STREET car.....true race oils do not have the proper amounts of detergents to keep the engine clean during extended oil change intervals and cope with excessive hydration if you park outside.....they are designed for extremely hard use with very short change intervals, hence the lack of detergents
An example....my race 928 is a 4.5L V8 designed for heavy oils....I run Amsoil 15-50 racing....I take a sample every 2 hours on track to send out for analysis and changed around 6-8 hours....not from the analysis saying it needs to be changed, but because I can't handle the dark black oil..... Street cars go thousands of miles at least 150 hours on the engine between changes.....so you see the need to have the proper oil given your requirements
My VOA (virgin oil analysis) would say otherwise. I run 300V for 10k intervals in my S2000, which is currently at 116k miles, and has hundreds of hours of run time at 6000+ RPM. Believe me, I'm completely anal about proactive/preventative maintenance.
We run 300V in the CSG shop cars, and our current oil change is at about 6000 miles. I can assure you that the car has seen plenty of track time
Re: 8100. You want to prepare you car for the harshest condition you will expose it to (this applies to brake pads as well). If you plan on running one marathon a year, do you train by doing 2 mile jogs every day? In my experience, 8100 has broken down with JUST canyon driving; I used to use it before I ever started hitting the tracks, and UOA showed it be insufficient, even though it is a very highly regarded oil.
As always, YMMV. We change our fluids based on test results from Blackstone, and recommend that anyone interested in extended oil change intervals to do the same.
We carry the full line of Motul fluids. PM @CounterSpace Garage for more info, or visit our www.counterspacegarage.com
300V virgin oil analysis.
Oil analysis on my factory fill on the S2000 (Yes, I started from the begining)
Different oils I tried in my car, until I discovered 300V. Look at the viscosity break down. My car was strictly a daily driver/canyon carver at this point. Still zero track time!
Experimenting with different diff fluids.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
Anthonytpt (03-14-2013), DoomsdayJesus (05-15-2014), normancw (05-17-2014), SirBrass (05-15-2014), SXE10 (04-06-2013)
Old 03-11-2013, 12:49 PM   #2
bluesubie
Drives: 2004 Subaru Forester 2.5XT
You are correct about the detergents, although 8100 0W-20 is a 100% synthetic, ester based oil.
http://www.motul.com/us/en-US/produc...iscosity%5D=36
There's a new Motul 8100 0W-20 available in Australia and it is likely PAO based.
http://www.motul.com/system/product_...pdf?1339474108
Only the 6100 series is synthetic blend.
http://www.motul.com/us/en-us/produc...%5Brange%5D=25
-Dennis
bluesubie is offline   Reply With Quote
Old 03-11-2013, 01:10 PM   #3
OrbitalEllipses
Drives: Attitude
Just one point I'd like to make that Dennis could probably clarify: Don't the racing oils usually have higher phosphorous levels, to the point they could be deadly to the cats?
Old 03-11-2013, 01:15 PM   #4
CSG Mike
CSG Mike's Avatar
Oops. I stand corrected. Need more coffee. Not sure why I was thinking 8100 when I was thinking 6100.
Old 03-11-2013, 02:17 PM   #5
bluesubie
Higher phosphorus levels than GF5 oils? Yes. Enough to be deadly to cats? No, IMO, as long as you're not burning a lot of oil.
The phosphorus levels shown above are actually typical of Rotella 5W-40, and many other 40 weights that Subaru turbo owners (like me) love to run, and the other Subaru forums don't have a lot of posts about cat failures and most would say the dead cat thing is overblown. There's a guy over at bitog that has worked in the oil industry for many years for some of the major oil companies and he has been running high phosphorus diesel oils in gas cars since the 60's!
Of course, YMMV, and don't blame me if you do have a cat failure running a high phosphorus oil. :happy0180:.
-Dennis
Old 03-12-2013, 08:31 AM   #6
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Here in the NY/NJ area we get back blackstones from motul in client cars 8100 x-clean 5w30 on 5000 mile intervals that are amazing. We have been selling and using in our cars the 8100 for a long time and for a street car on 7500 intervals it is more than adequate to be used. On cars that are tracked, you will want to change your oil shortly before an even and shortly after an event to provide the most protection.
The v300 is also great, but overkill for most drivers in our opinion.
We also stock and sell Motul so feel free to ask for a quote and we are one of the only stocking dealers in the Tristate.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
p00mba (04-06-2013)
Old 03-26-2013, 04:41 PM   #7
gonzo
Drives: frs
So it was the 6100 that showed breakdown in the above UOAs?
gonzo is offline   Reply With Quote
Old 03-26-2013, 05:04 PM   #8
CSG Mike
CSG Mike's Avatar
One is 8100 and one is 6100. Both broke down.
Old 03-26-2013, 05:34 PM   #9
AZP Installs
We've ran the 8100 in both our street and track cars for a few years now. No breakdowns and the UOAs for them have come back very well. We have ran the 8100 X-Clean C3 5w30 and 5w40 in our cars and have a fairly decent size sample of customer cars that run them. I would say that we do about 50+ Motul oil changes a month on customer's cars as well.
-Mike Paisan
Old 03-27-2013, 02:54 PM   #10
schtebie
Drives: CBS BRZ Limited
@CSG Mike:
Is there any benefit to running Motul 300V 0W20 over Motul 8100 0W20??
Or would you recommend just running 300V 5W30 all the time (especially if the car will see the track)?
schtebie is offline   Reply With Quote
Old 03-27-2013, 03:00 PM   #11
AZP Installs
Originally Posted by schtebie View Post
@CSG Mike:
The 300v 0w20 will be more robust than the 8100 0w20 but the cost is probably not warranted for a street car.
The 300v 5w30 would be a good choice for track beaten cars.
-Mike Paisan
schtebie (03-27-2013)
Old 03-27-2013, 03:44 PM   #12
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Will the 300V 0W20 withstand street use such as 8000 OCI and cold starts every day?
I heard some people say 300V is good for track and only meant for really short OCIs
shu5892001 is offline   Reply With Quote
Old 03-27-2013, 06:32 PM   #13
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
If it's driven on the street you gain not from running a race-only oil. You need a "compromise", an oil that good enough for the track but has the necessary ingredients for the street (detergents etc). Many street oils are so good they work very well under racing conditions.
If you have a dedicated race car that's never left outside in the cold you really should be running a dedicated race onlyoil, they're just that good.
I see some excellent oils in this thread. Good thread, but surprised nobody mentioned Joe Gibbs, one of the undisputed champions of racing oil development.
http://www.drivenracingoil.com/dro/xp3.html
PRO86 | WTCC | STL
Old 03-27-2013, 06:36 PM   #14
AZP Installs
Haven't seen that used in subies yet. It may be because no one thought to use it or perhaps it is similar to Mobil 1 which does not do very well in Subies at all.
-Mike Paisan
"Come Race Me Bro" Encounters GH05T FR-S / BRZ vs.... 2565 02-28-2023 09:34 AM
New 4-2-1 Long Tube Header Anorexic 86 Engine, Exhaust, Transmission 28 08-25-2013 03:28 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
