#15 |
Drives: 2023 WRB BRZ (MT)
#17 |
I Love custom Turbo kits
Drives: Limited BRZ
So where did you attach that hose??
#18 |
i bought a mini looking filter from pepboys and just attached it and hid it under the intake.
@FA20Club.com, why did his have that hole yet mine (and some1 else i saw at the FL mega meet) did not? |
| The Following User Says Thank You to lbroskee For This Useful Post: | Sportsguy83 (03-27-2013) |
#19 |
Drives: 2013 Hot Lava Scion FRS
Thank you for these. I spoke to Tony last night and he told me some customers had an easy time getting some slack for the hose. I just didn't want to break something, so I figured it'd be best to come to the forums or call Tony. I think I may just buy a small line of vacuum hose and clamp it over the OEM hose.
#20 | |
| The Following User Says Thank You to reeves For This Useful Post: | lbroskee (03-27-2013) |
#21 |
maybe i bought it before that option then, bc i didnt see it and he never mentioned it to me through PM nor in the thread
#22 |
Drives: 2013 Asphalt FR-S
Yes, FA20 has options between OEM Crank Vent setup or No Vent setup. There is also an option for a smaller diameter longer body filter, it actually has about 30% more filter area than the aem dry flow option.... I'll post pic this weekend when i install mine.
~Namaste~ |
#23 | ||
They're actually quite accomodating and willing to customize certain parts for you if you request it (even if it's not listed as an option).. as long as they have to means to fabricate it. |
#24 |
Drives: Blue FRS 6sp, 95 M3
Installed mine yesterday and had the same issue. My vent hose didn't have enough slack. It was so tight I thought it would pull the fitting out of the pipe.
I went to Autozone and found a Ford PVC 90 degree fitting and used it. No stretch or tension on the pipe fitting. |
#25 |
I may end up doing that. I felt like it really could have used a 90deg bend instead of the straight connector on it. I was able to hook it up but I had to wrangle it into working.
#26 |
I went looking for a 6 inch piece or breather hose so I could make a short piece and use the factory 90 degree fitting.
They didn't have any bulk hose that large, so I went to the section where they have the factory hose fittings pre made. Found the Ford piece and it worked fine. |
| Fa20Club Review... | feldy | User/Vendor/Sponsor Reviews, Feedback, Comments | 6 | 09-24-2013 07:39 PM |
| FA20Club CAI | Snake | Engine, Exhaust, Transmission | 2 | 01-26-2013 08:08 PM |
| Ecutek From FA20Club.com | tonytduc | Issues | Warranty | Recalls / TSB | 1 | 01-11-2013 10:12 PM |
| Another purchase from FA20Club | Frostyman | User/Vendor/Sponsor Reviews, Feedback, Comments | 8 | 01-03-2013 06:02 PM |
| FA20CLUB.com E85 Goodness | FA20Club.com | Engine, Exhaust, Transmission | 45 | 11-13-2012 01:05 PM |
