Old 03-27-2013, 01:49 AM   #15
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by GremlinGSP View Post
Here are a couple pics of mine attached. I will say it was a stretch and I had to turn the hose to get it to connect. It will go it just takes some maneuvering.
WTH?! i dont have a hole in mine for that hose. did u DIY?
lbroskee is offline   Reply With Quote
Old 03-27-2013, 02:16 AM   #16
GremlinGSP
nope intake came that way and used all stock fittings.
GremlinGSP is offline   Reply With Quote
Old 03-27-2013, 07:05 AM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So where did you attach that hose??
Old 03-27-2013, 10:17 AM   #18
lbroskee
lbroskee's Avatar
i bought a mini looking filter from pepboys and just attached it and hid it under the intake.
@FA20Club.com, why did his have that hole yet mine (and some1 else i saw at the FL mega meet) did not?
Old 03-27-2013, 10:41 AM   #19
Saab2Frs
Drives: 2013 Hot Lava Scion FRS
Thank you for these. I spoke to Tony last night and he told me some customers had an easy time getting some slack for the hose. I just didn't want to break something, so I figured it'd be best to come to the forums or call Tony. I think I may just buy a small line of vacuum hose and clamp it over the OEM hose.
Saab2Frs is offline   Reply With Quote
Old 03-27-2013, 10:50 AM   #20
reeves
I think it's an option to have that hole or not.. mine's doesn't have it either. When you buy the intake, there's an option (on the pull-down menu) for "Recirculated (OEM)" or "Vent to Atmoshpere"... I think the hole is for people who selected "Recirculate".
Old 03-27-2013, 10:54 AM   #21
lbroskee
lbroskee's Avatar
maybe i bought it before that option then, bc i didnt see it and he never mentioned it to me through PM nor in the thread
Old 03-27-2013, 12:30 PM   #22
mad_sb
Drives: 2013 Asphalt FR-S
Yes, FA20 has options between OEM Crank Vent setup or No Vent setup. There is also an option for a smaller diameter longer body filter, it actually has about 30% more filter area than the aem dry flow option.... I'll post pic this weekend when i install mine.
Old 03-27-2013, 01:06 PM   #23
reeves
Can't remember what options were originally offered with the intake.. but my guess is those options probably became available on the site as more & more people requested it.
They're actually quite accomodating and willing to customize certain parts for you if you request it (even if it's not listed as an option).. as long as they have to means to fabricate it.
Old 03-27-2013, 02:24 PM   #24
maj75
Drives: Blue FRS 6sp, 95 M3
Installed mine yesterday and had the same issue. My vent hose didn't have enough slack. It was so tight I thought it would pull the fitting out of the pipe.
I went to Autozone and found a Ford PVC 90 degree fitting and used it. No stretch or tension on the pipe fitting.
maj75 is offline   Reply With Quote
Old 03-27-2013, 03:13 PM   #25
GremlinGSP
I may end up doing that. I felt like it really could have used a 90deg bend instead of the straight connector on it. I was able to hook it up but I had to wrangle it into working.
Old 03-27-2013, 08:02 PM   #26
maj75
I went looking for a 6 inch piece or breather hose so I could make a short piece and use the factory 90 degree fitting.
They didn't have any bulk hose that large, so I went to the section where they have the factory hose fittings pre made. Found the Ford piece and it worked fine.
Fa20Club Review... feldy User/Vendor/Sponsor Reviews, Feedback, Comments 6 09-24-2013 07:39 PM
FA20Club CAI Snake Engine, Exhaust, Transmission 2 01-26-2013 08:08 PM
Ecutek From FA20Club.com tonytduc Issues | Warranty | Recalls / TSB 1 01-11-2013 10:12 PM
Another purchase from FA20Club Frostyman User/Vendor/Sponsor Reviews, Feedback, Comments 8 01-03-2013 06:02 PM
FA20CLUB.com E85 Goodness FA20Club.com Engine, Exhaust, Transmission 45 11-13-2012 01:05 PM
