Old 03-21-2013, 05:59 PM   #1
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Trying to install FA20club CAI need some help
Does the bumper have to be removed. I don't see how I can possibly fit this large filter in there. Are there any DIY's posted? I wasn't able to find anything. FA20club isn't answering the phone.
Bg8780 is offline   Reply With Quote
Old 03-21-2013, 06:00 PM   #2
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Yes the bumper has to be removed.
Old 03-21-2013, 06:05 PM   #3
Bg8780
Bg8780's Avatar
I was able to remove the snorkel but this huge filter doesn't look like it will fit without breaking the bumper cover
Old 03-21-2013, 10:10 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
This.
1974 TA22 Celica
2013 86 GT
Old 03-21-2013, 10:19 PM   #5
DR 86
DR 86's Avatar
Just remove the bumper it's easy. 4 clips each wheel well splash guard, pry out your side markers, 1 clip above each side marker, 3 clips underneath the front lip plus 2 10mm bolts, 5 10mm bolts plus 3 clips up top, pull....voila! Get a proper clip removal tool, it'll save you a lot of angst. Also, don't lose the 3 metal clips on the side marker. When you put the side marker back in, use a screwdriver to push on the back of the metal clip...if you just push on the side marker itself, the clip will bend and it won't have the tension to keep the side marker tight in between the bumper and fender.
DR 86 is offline   Reply With Quote
Old 03-21-2013, 10:25 PM   #6
FR-S Matt
It fits... once you remove the bumper you will see. Make sure you're careful with the plastic clips and unscrew your turn signal bulbs to fully remove the bumper off. Don't just let it hang.
Old 03-22-2013, 08:08 PM   #7
Saab2Frs
Drives: 2013 Hot Lava Scion FRS
I thought I saw a post about this where FA20Club said you can just remove the top clips? Maybe I'm wrong. Removing the bumper might seem easy when you have a driveway to do it in. I live in the city and park on the street lol.
Saab2Frs is offline   Reply With Quote
Old 03-22-2013, 08:21 PM   #8
FA20Club.com
Drives: 2013 White Out FR-S
we dont pull the bumper just the sidemarkers to remove the phillips screws attaching fender to bumper and the 5 10mm bolts on top and the 2 clips. once those are gone you can pull the bumper forward to release the headlight brackets and pull the top to slide the filter and lower tube into place.
FA20Club.com is offline   Reply With Quote
Old 03-23-2013, 12:09 AM   #9
reeves
Bumper doesn't need to be removed. Just remove the top & side/fenderwell bolts/screws, then pull the bumper away from the headlights.. there should be enough room to fit the filter in there.
You may have to pull the bumper with a little effort to get it to "detach" from the frame/headlights, but it's flexible enough to take it.
reeves is offline   Reply With Quote
Old 03-25-2013, 10:56 PM   #10
Saab2Frs
Can someone tell me if this is the crank case vent and, if so, how did they go about getting the OEM hose to fit over this tube? The OEM hose doesn't have enough slack or play to get it in place. I was thinking I might need to buy a length of rubber hose and clamp it over the OEM hose and then over the crank case tube. Anyone tried this?
Old 03-25-2013, 11:13 PM   #11
Saab2Frs
Sorry, forgot to post the picture. Here it is:
Old 03-26-2013, 07:40 AM   #12
UncleFester
Yes, and mine fit fine.
UncleFester is offline   Reply With Quote
Old 03-26-2013, 11:35 AM   #13
Saab2Frs
How were you able to fit it? Mine doesnt seem to have enough slack.
Old 03-27-2013, 01:06 AM   #14
GremlinGSP
Here are a couple pics of mine attached. I will say it was a stretch and I had to turn the hose to get it to connect. It will go it just takes some maneuvering.
GremlinGSP is offline   Reply With Quote
Fa20Club Review... feldy User/Vendor/Sponsor Reviews, Feedback, Comments 6 09-24-2013 07:39 PM
FA20Club CAI Snake Engine, Exhaust, Transmission 2 01-26-2013 08:08 PM
Ecutek From FA20Club.com tonytduc Issues | Warranty | Recalls / TSB 1 01-11-2013 10:12 PM
Another purchase from FA20Club Frostyman User/Vendor/Sponsor Reviews, Feedback, Comments 8 01-03-2013 06:02 PM
FA20CLUB.com E85 Goodness FA20Club.com Engine, Exhaust, Transmission 45 11-13-2012 01:05 PM
