Old 03-22-2013, 04:56 AM   #169
KlafKoon
Drives: 2013 H8R FRS, 03 Miata (Sold)
Kind of new to the whole electrical/wiring thing and was wondering where one would go about buying the necessary negative trigger relay for the stalk setup.
KlafKoon is offline   Reply With Quote
Old 03-22-2013, 10:13 AM   #170
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
You should be able to get it at any parts store, like Autozone or O'Reilly's. if not, then maybe try Radio Shack.
kmbkk is offline   Reply With Quote
Old 03-26-2013, 06:36 PM   #171
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Originally Posted by PatGT86 View Post
how does this look?
Let me know if I need to make any corrections...
Also, assuming we're hooking up a pair of 55w halogen lamps, what relay & fuse amperage should we be using? I can add that info to the diagram if it makes sense to
Thanks to your post I was finally able to wire up my fog lights using Nigel's harness by rewiring the relay for a negative trigger.
iketiak is offline   Reply With Quote
Old 03-26-2013, 07:20 PM   #172
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
So basically usin this, Nigel's harness will work with the stalk route?
lbroskee is offline   Reply With Quote
Old 03-26-2013, 07:35 PM   #173
iketiak
iketiak's Avatar
Yes, I could also turn on the fog lights on and off independently. The setup on Nigel's harness is originally a positive trigger, after going through the posts and looking at pat's diagram I finally understood how to wire it all up. Honestly you could buy all the components yourself and it would be cheaper than buying Nigel's harness.
Old 03-28-2013, 07:27 AM   #174
mjreynolds2
mjreynolds2's Avatar
Drives: Scion FR-S Asphalt
Originally Posted by FRSFirestorm View Post
I had planned on dong front fogs but had planned just an illuminated switch somewhere inside to turn them on. Having the indicator in the instrument panel is now what I want.
After a bit of looking through wiring manual it appears the the switch in the stalk grounds the white wire coming out of the stalk and signals the BCU which probably illuminates the instrument panel indicator.
At some point I'll test this and if so I'll just do an internal switch somewhere and tie it to the instrument panel light.
[IMG]http://www.ft86club.com/forums/data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAqgAAAI4CAIAAAA pvIxIAAAgAElEQVR4nO3d/1cUZ57o8fkn7rk/7M5276m9c4Jn9JB1krjJCleHzEUnMqaTEDYSjbZMIEoS0BkNMC RK1hFcICMGc3UUgbiTCNodgxkV244rQpDpLBox2EkQA6YvdtAh OO0XxLo/FDRYfmuh+3m6ut6v8/khCZJ6hKp6U93VzY+mAQAA0/jRU0891R3Fit7+d8vf/X3tp587Pv+GYRiGYYw+63fUWf7u77du2RK5dJ49e/abb77xer3t7e3zb/OjlJSU76LVsWPHrH//4+W/W/fxqR6GYRiGMfrs9nz1z4/8y7x5kS3v+fPne3p6zp49e+rUKXe79+CZ7w97/cH50fz587+PSr29vb/61fzpjz2+9+S5/Wf6GIZhGMbok/Gb31l//A/Hjx+PaED9fn9fX9/58+fPnDlz5OTXjWe+d381Nj+y2Ww/RKU1a9b+44//YesnR11nLzEMwzCM0adi94F//PE//HHr1kgHdGBg4NKlSxcuXDh79mxTx9lG7/efft0fnB+lpqaq0ae9vV2xWNdsrmnx32AYhmEYo8+Bry7MeCIx MzMrEAhEuqE3b968cePGlStX/H5/q7f30Ff9/9V1KTjRGP5AIJCYkJg8P/XTnkHp3yqGYRiGmfxkF/5esVh7e3sFZNR44Xc6HIrFWtfaKf37xDAMwzCTn7rWTsVifb+2 VkxGDRb+QCAwc2bikpw3pH+fGIZhGCYssyTnjZkzEwU8yK8xWP gbGxu53GcYhmFiZvaePKdYrE6HQ1hJDRb+555LTZ6fKv37xDAM wzBhmTWbaxSLtb+/X1hJjRT+3t5exWKtqD8g/fvEMAzDMGGZx55IXL++WGRMjRR+7ba+A19dkP59YhiGYZjJj/Y4f3Nzs8iYGin8q9/I43F+hmEYJmampGa34Mf5VWOFX7FYV294V/r3iWEYhmHCMtmFv3/2OdGdNUz4+/v7eYKfYRiGiaVJXZL5xht5gntqmPB7vV5eyMcwDMPE0gh+IZ+G 8DMMwzCMnCH899Lc3KxYrHtPnpP+fWIYhmGYsAzhvxftPfsIP8 MwDBMzQ/jvhYf6GYZhmBgbwn8vhJ9hGIaJsSH896K9X+/WT45K/z4xDMMwTFgmeX5qSbHQ9+tVDRR+VVUVi3XN5hrp3ycm7NPkKp1 qsSraTCut9l0/5CyIe6igsut6i7+7JH3Fupp1jxa1NcleJ8MIme6S9PiRwyF9Xc 7YP++qa91tT5qiWKxx6dUfdl9v6eutWmePs1iVh+wrG3uPyV85 88CzJOeNX7+cJTimRgr/y5lZqUsypX+fmMjMQHWRPcc10OK/0eLvq8y1JSQl2519hJ8x33SXZGys9t32z32nC+fYMpzfHvNf/LBi2ZMVXzQ635q98mBD341jX+x+bt72uj7pK2ceeLS37A0EAiJ jaqTwv19bq1isn/YMSv9WMRGYceHvctnnba3aUzA113WI8DOmm+AVf3KO64uxf96z x754d4P2Z7pc9nlv5by6rLD1suzVMpOa2k8/VyzW9vZ2kTE1Uvjb29t5mj92Jxj+64ecBXHaY5sPFVR2dRF+xm Rzlyv+jt229DuEf/SZsmUlHVdlr5yZyMx4InFz5WaRMTVS+FVVTUxIXJLzhvTvExOB CYa/rzJXu47pq8y12Z1thJ8x2TzwQ/0tfacL57xG+A06qze8K/jRfoOFX3u0/8BXF6R/q5hwz2j4u1z2kWcrrx9yFkzNfa8gfcW6mnWjd/9xWcPE/Nwl/P4bxzoOZiRNUSxTEnJ3142/uc+SYq/8rIHn+I05da2disXa2NgorKQGC7/2O/r45bwMwzBMzEzy/FSRv5zXYOFXVXVz5Wbeu5dhGIaJmdn6yVGR7+RjvPD39/fPnMkz/QzDMEzsTOqSzISExP7+fgEZNV74VVV1OhyKxVpRf0D6t4phGIZ hJj/aM/1vvJEnoKGGDL+qqpmZWUrwvd4YhmEYJibG6/VGOqBGDX8gEHA6HEyMTUlxsbbrv5KVpf2XV7JGfsIrKS6WvjyG ET/bt2372cMPKxZr2vPP5+fl5eflzXvqKcVinffUU7s+/FD68pjwTmNjo4DX9Rk1/DCkwePlyVMUy4yMqlODQ57yeKtisSp2h09VVVUNBAJpqamzEhP bPR+MfMgyI6PqVEt7+6zExLTUVMHvagmIMP6gUFVV9bvzF5R7B rUPBgKBWYmJsxITvV86xx8UruZm7edjmSuHYRF+CDPkc7w+v6p zeMBdMKPM0+PIyncPjPtwY2Ojor115ZCnfGaZZ0hVfSN/RnvTRqfwX14JRNitB8XQ8KBn41zLnGD4nQ7HyGO/tx0U2vHS3Nws9y8AIyL8EG34vOPVQne/p2z66OWLdpLLz8sbuYIJPhhgmTK37Lj20Veysri+QazSDoqB4X POwk3OqsJg+NNSU+9xUKSlpubnibgXDDGG8EOswVM7MvOd56+N/nuPc/kmz5Cqqqpisb5fW6uq6tjFzeDxcttG7aPamzbKWTMQUSMHxeB5 R/6rjm/OO9YGwz/2QNedDgrtKX9564ZREX6IM+xr3pi5ckfngKoOD7jfznL06MI/8psq7nSO0964SebqgQgYd1D0OO0Pj9zaHV8WPCgIP8KO8EOYK9 6qBWPntUundthnKJaUN93nh1VVVdX8vLw0bX8be1RzRpbjnPZR HtVELLr1oBhSVXXIN+6Kf+wZrtsOCu2+v5LiYomrh0ERfkSL5u Zm5S6/qYL7mGBO2s19dzwotA9xUGACCD+iiPaqfd3d+9oJjjv7YEKBQE A7KMa3PxAIaLe88BgYJobwI4oEAoH8vDzFYn00furCZ3658Jlf Pho/VTvB8SJ+mFOw/bMSE7Un9WclJmpvacVBgYkh/Ig6m4pWZr74jBb+zBef2VS0UvaKAMm00mvh197gUvaKYGCEH1H 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 +ubb74h/JCA8AM6hB+RMDw8PDQ0dOXKlR9++OHSpUvff/+93+8n/JCA8AM6hB8RMjw8fOPGjaGhoWvXrl25cuXKlSuEHxIQfkCH8CN ybt68qd3nr/0QQPghAeEHdAg/BNB+AiD8kIDwAzqEH8IQfkhA+AEdwg9hCD8kIPyADuGHMIQfEh B+QIfwQxjCDwkIP6BD+CEM4YcEhB/QIfwQhvBDAsIP6BB+CEP4IQHhB3QIP4Qh/JCA8AM6hB/CEH5IQPgBHcIPYQg/JCD8gA7hhzCEHxIQfkCH8EMYwo+IGhq8dHlo7N/8X33lHyL8wG0IP4Qh/IikIU/5zDLP0KCnbGm5Z1D1OTLsDh/hh5nd6Grc/p8N7uOnu3x/vTIc/M+EH8IQfkQS4Qd0bv5wtqlh55aSguUL5sY/Mndh7tr3PX8l/BCI8COShjzlj6/cebxp50rbb3Y2eQ6WPUv4AXX4ysXuk586qtYsfOSfFxQQfohF+ BFJN7oObvx9wfLXCtaXrLEnPZS4dM37nr8SfpjZ0Mkq27/+JG7pO39u9foGg3fAEH4IQ/gRUf2tZQvm2tJSlyzN+HXe75e/YN/ZeY3ww8xuDn7buv9P76169p9mZ6zf8UnTqe6LV24SfghE+BFJQ 57yJ4pbr/61df1inuMHRg1fueQ7e9pdtTzpJxarYnf4CD8EIvyIJJ7jB3SG TmxJnj49edFv1mzcUX+g6YS39xJX/BCK8COSbnQd3FhWXjZudvIcP0xu6PLg1Zu3/VfCD2EIPyQg/IAO4YcwhB8SEH5Ah/BDGMIPCQg/oEP4IQzhhwSEH9Ah/BCG8EMCwg/oEH4IQ/ghAeEHdAg/hCH8kIDwAzqEH8IQfkhA+AEdwg9hCD8kIPyADuGHMIQfEhB+QI fwQxjCDwkIP6BD+CEM4YcEhB/QIfwQhvBDAsIP6BB+CEP4IQHhB3QIP4Qh/JCA8AM6hB/CEH5IQPgBHcIPYQg/JCD8gA7hhzCEHxIQfkCH8EMYwg8JCD+gQ/ghDOGHBIQf0CH8EIbwQwLCD+gQfghD+CEB4Qd0CD+EIfyQgPAD OoQfwhB+SED4AR3CD2EIPyQg/IAO4YcwhB8SEH5Ah/BDGMIPCQg/oEP4IQzhhwSEH9Ah/BCG8EMCwg/oEH4IQ/ghAeEHdAg/hCH8kIDwAzqEH8IQfkhA+AEdwg9hCD8kIPyADuGHMIQfEhB+QI fwQxjCDwkIP6BD+CEM4YcEhB/QIfwQhvBDAsIP6BB+CEP4IQHhB3QIP4Qh/JCA8AM6hB/CEH5IQPgBHcIPYQg/JCD8gA7hhzCEHxIQfkCH8EMYwg8JCD+gQ/ghDOGHBIQf0CH8EIbwQwLCD+gQfghD+CEB4Qd0CD+EIfyQgPAD OoQfwhB+SED4AR3CD2EIPyQg/IAO4YcwhB8SEH5Ah/BDGMIPCQg/oEP4IQzhhwSEH9Ah/BCG8EMCwg/oEH4IQ/ghAeEHgo4ePfp+ba1isTodjuAoFuv7tbVHjx6VvTrEIMIPCQg/oNm6ZYtisd5jtm7ZInuNiDWEHxIQfkAdrf6j03928eLF2z968e LFR6f/jPYj7Ag/JCD8wL2rr6H9iATCDwkIP0wulOpraD/CjvBDAsIPMwu9+hraj/Ai/JCA8MO0du3a9UDV1wTbz33+mDzCDwkIP0xrc+VmxWJ9oOprLl6 8qL3GLxKrgqkQfkhA+GFa2mv0J/a52mv9w7semBDhhwSEH6ZF+CEd4YcEhB+mRfghHeGHBIQfpkX4 IR3hhwSEH6ZF+CEd4YcEhB+mRfghHeGHBIQfpqW9nG8Cn8jL+R AuhB8SEH6YVklJiWKxvrgg/YE+izfwQRgRfkhA+GFmLy5If6D285a9CC/CDwkIP0wu9PZTfYQd4YcEhB8Ipf1UH5FA+CEB4QfU+7Wf6iNCC D8kIPyARmv/PYbqI+wIPyQg/EDQrg8/fL+2VnuNfnC0V+41Hjwoe3WIQYQfEhB+QEf34v4Jv8kPcF+EHx IQfkCH8EMYwg8JCD+gQ/ghDOGHBIQf0CH8EIbwQwLCD+gQfghD+CEB4Qd0CD+EIfyQgPAD OoQfwhB+SED4AR3CD2EIPyQg/IAO4YcwhB8SEH5Ah/BDGMIPCQg/oEP4IQzhhwSEH9Ah/BCG8EMCwg/oEH4IQ/ghAeEHdAg/hCH8kIDwAzqEH8IQfkhA+AEdwg9hCD8kIPyADuGHMIQfEhB+QI fwQxjCDwkIP6BD+CEM4YcEhB/QIfwQhvBDAsIP6BB+CEP4IQHhB3QIP4Qh/JCA8AM6hB/CEH5IQPgBHcIPYQg/JCD8gA7hhzCEHxIQfkCH8EMYwg8JCD+gQ/ghDOGHBIQf0CH8EIbwQwLCD+gQfghD+CEB4Qd0CD+EIfyQgPAD OoQfwhB+SED4AR3CD2EIPyQg/IAO4YcwhB8SEH5Ah/BDGMIPCQg/oEP4IQzhhwSEH9Ah/BCG8EMCwg/oEH4IQ/ghAeEHdAg/hCH8kIDwAzqEH8IQfkhA+AEdwg9hCD8kIPyADuGHMIQfEhB+QI fwQxjCDwkIP6BD+CEM4YcEhB/QIfwQhvBDAsIP6BB+CEP4IQHhB3QIP4Qh/JCA8AM6hB/CEH5IQPgBHcIPYQg/JCD8gA7hhzCEHxIQfkCH8EMYwg8JCD+gQ/ghDOGHBIQf0CH8EIbwQwLCD+gQfghD+CEB4Qd0CD+EIfyQgPAD OoQfwhB+SED4AR3CD2EIPyQg/IAO4YcwhB8SEH5Ah/BDGMIPCQg/oEP4IQzhhwSEH9Ah/BCG8EMCwg/oEH4IQ/ghAeEHdAg/hCH8kIDwAzqEH8IQfkhA+AEdwg9hCD8kIPyADuGHMIQfEhB+QI fwQxjCDwkIP6BD+CEM4YcEhB/QIfwQhvBDAsIP6BB+CEP4IQHhB3QIP4Qh/JCA8AM6hB/CEH5IQPgBHcIPYQg/JCD8gA7hhzCEHxIQfkCH8EMYwg8JCD+gQ/ghDOGHBIQf0CH8EIbwQwLCD+gQfghD+CEB4Qd0CD+EIfyQgPAD 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 fwQxjCDwkIP6BD+CEM4YcEhB/QIfwQhvBDAsIP6BB+CEP4IQHhB3QIP4Qh/JCA8AM6hB/CEH5IQPgBHcIPYQg/JCD8gA7hhzCEHxIQfkCH8EMYwg8JCD+gQ/ghDOGHBIQf0CH8EIbwQwLCD+gQfghD+CEB4Qd0CD+EIfyQgPAD OoQfwhB+SED4AR3CD2EIPyQg/IAO4YcwhB8SEH5Ah/BDGMIPCQg/oEP4IQzhhwSEH9Ah/BCG8EMCwg/oEH4IQ/ghAeEHdAg/hCH8kIDwAzqEH8IQfkhA+AEdwg9hCD8kIPyADuGHMIQfEhB+QI fwQxjCDwkIP6BD+CEM4YcEhB/QIfwQhvBDAsIP6BB+CEP4IQHhB3QIP4Qh/JCA8AM6hB/CEH5IQPgBHcIPYQg/JCD8gA7hhzCEHxIQfkCH8EMYwg8JCD+gQ/ghDOGHBIQf0CH8EIbwQwLCD+gQfghD+CEB4Qd0CD+EIfyQgPAD OoQfwhB+SED4AR3CD2EIPyQg/IAO4YcwhB8SEH5Ah/BDGMIPCQg/oEP4IQzhhwSEH9Ah/BCG8EMCwg/oEH4IQ/ghAeEHdAg/hCH8kIDwAzqEH8IQfkhA+AEdwg9hCD8kqHnnrdyMFxY+88uFz/wyN+OFmnfekr0iQDLFYi0pLs7Py8vPy9tcuZnwI3IIP4QKBAL5 eXmKxfpo/FQt/I/GT1Us1vy8vEAgIHt1gATBg2JWYqIWfsVi1X4O4KBAJBB+hNvg8 fLk152+IXXweHnyFMUyI8txbnj0g9pJzelwBAI97vyEqfnuvkD A6XBo7Ze5bEAQvzt/QblnMPjvr2RlaQeFqvqDB4V20V9SXCxxoYhVhB9hNXzOudw2N+ l1p29oyFOWWOYZ8jky7A6fqqqq2tzcPHqCU9UBd0HynLnxhe6B YVVVtfY3NzfLXDwQccODno1zLXOC4W9sbFQs1sbGRlXVHxRa+7 1er8TlIiYRfoRdj9O+0ukbUoc85fFWxfJwhqNH+0B+Xl7ayP42 POBe+2zVEVe+rcDt1z6alprKRT9i3PA5Z+EmZ1VhMPyvZGXd7a AIBAKzEhO56EfYEX6EnRb+awPut7McPeqQp/z5Ku+wqqrqrMTEzZWbVVXVHtLUnsicmu8eUFV19PpG3rKBSLt2 3pH/quOb8461wfArFuv7tbWqqt7xoNCe8pe1XMQqwo+w08J/xedYmaGFf2aZZ0hVx5/jBtwFtirvsKoOuAtGH9h8v7aW8COm9TjtD2tpV+LHDoqxJ79uO ygIPyKB8CPsRh/qHzy1wz5j/M19r2RlvZKVNfqQZuewqqqq3z36wOboR4HYNuQbd8Wflpp6j4O C578QCYQf4mh38LW3t9/+ofb29rFLH8A0tAe67ngHn3bfH3e8IuwIP8QJBAJpqamzEhN1p zmv1zsrMTEtNZVXLcNstDv4bj8o2tvbZyUm8hgYIsHs4Q8EAo2 NjU6HgxEz27dt+9nDDysWa9rzz2vPX6Y9/7xisf7s4Ye3b9smfXkMI36CB8WSxYvHHxSzE/93bB8U/f39sgtgUmYPv9frHbnXhmEYhhE4Tp7ak4TwexWLta61s8V/gxE/isUqfQ0MEz1jniOC8EtE+Am/5INf+hoYJnrGPEcE4ZeI8BN+yQe/9DUwTPSMeY4Iwi8R4Sf8IqbJVTo1+NzetNJq39jBL31tDBOp8b XlTNN2+xm2ihOHO3bbRo6CeFvNmYbGSttDVsUyw7buaEPfyKeY 54gg/BIRfsIvbAaqi+w5rgHdwS97VQwTsfG15TxeWu270dKx+7lc16G O3WlFbU3ah7pc9jlFlR2Blr6uksUvF7Ze1j7FPEcE4ZeI8BN+Y UP4GZPN2BX/lISiz8au+KcVb6p/68mK08du+xTzHBGEXyLCT/iFDeFnTDbBK/7uz3LmvVN9InjFf/2Q860nK04fG/nJIN5W0619inmOCMIvEeEn/MKG8DMmm7uGf9xD/f7LdRV2wg+RCD/hFzaEnzHZjLu577marmPjn+P3B0Zv7puSkFtb3RHQPsU8RwThl 4jwE37JB7/0NTBM9Ix5jgjCLxHhJ/ySD37pa2CY6BnzHBGEXyLCT/glH/zS18Aw0TPmOSIIv0SEn/BLPvilr4FhomfMc0QQfokIP+GXfPBLXwPDRM+Y54gg/BIRfsIv+eCXvgaGiZ4xzxFB+CUi/IRf8sEvfQ0MEz1jniOC8EtE+Am/5INf+hoYJnrGPEcE4ZeI8BN+yQe/9DUwTPSMeY4Iwi8R4Sf8kg9+6WtgmOgZ8xwRhF8iwk/4JR/80tfAMNEz5jkiCL9EhJ/wSz74pa+BYaJnzHNEEH6JCD/hl3zwS18Dw0TPmOeIIPwSEX7CL/ngl74GhomeMc8RQfglIvyEX/LBL30NDBM9Y54jgvBLRPgJv+SDX/oaGCZ6xjxHBOGXiPATfskHv/Q1MEz0jHmOCMIvEeEn/JIPfulrYJjoGfMcEYRfIsI/8fAf+OpCXWsnM5nRvvhMtM3ek+cmdjbnoJjkGO6ImPCuQvglIv wTD/+SnDcUi5VhYnImdjZ/7IlE6StnBA/hNxzCP6nwpy7J5IJAypLYaORm9YZ3J3M2X73h3Zj/EkXnkgy3qxB+WQj/pMK/JOeNie30E54JH2YxtiQ2Grkpqdk9mbN5Sc3umP8SReeSDLerEH 5ZCD/hN+SS2GjkhvAbdEmG21UIvyyEn/AbcklsNHJD+A26JMPtKoRfFsJP+A25JDYauSH8Bl2S4XYVwi8L 4Sf8hlwSG43cEH6DLslwuwrhl4XwE34ZS/K15UwLvhwoOcc1IGijj5dW+260+Aeqi+wR2WiXy/7QTLuzb/wmmlyljxaWZo//+zpbS3JTFItVeejlwpaL4fybjv/CTiutOlj6aFFb0wP+NQm/qCUNVBcla9+suPTqD7u7StLjR7536bs/7ji6Mn2GYrHGpVdWdQTC+HVocgX3iqsNNctGd8tlJR0/NDRW2h6yKpYZtnVHG/ru/78i/AZF+Am/tCWNOwEJ2WjEw3/9kPOthKSfT811HdKFv6itaewfLtdVLEpYebCh7/rhlmrbvO119zzDPnD4R/6OE/8KE35RSwruJN0li4squ7pKMjaOfu/6KnMXZTi/PeYPfFyz4smK08fC93W4NfxvjR0IXS77nKLKjkBLX1fJ4pcLWy/f939F+A2K8BN+aUuSEP7IPszQV5m7rLDxY/u0gsqui3cPf19lbl5Jx9WxT7nnGXbiV/zpuz8i/JLmQa/4laR3qseu+JNz9uyx3+8nwgl/He54xT+16LMDzrdC/AkjOITfoAg/4Ze2pFi74u9y2R/SojvT7vz67uHvLklfEcHwc8UfBfOAV/z91UXLclxfjF3xd7ns87bX9Y3+ZJC+uyF8X4e7XPFfP6SFf+Rn x3hbTfd9/1eE36AIP+GXtqTYCv/oedN//ZCzYGru/g9rXkso+uywv7+66PnZFaeP8VB/xMawB8Xdwz/2UP+NY63bZ4sI/7iH+v2X6yrshD+GEX7CL21JsRX+cdfuXS77tILKL/678Nabs8b+vn3fVq5MUSxWJamgpDViN/dZlq2vL5k6duvW1RD/JzLC/0NDs6fa1Vbtaqtu7XvQXcKwB8W4m/sW7/64r3tc+G8cG725T0nKW+PqDe9z/KN7xdKcorxxB0Jg9Oa+KQm5tdUh3FFI+A2K8BN+Qy6JjUZuhId/8IOyFxIy1uYUleYUlea815ZTYA0AACAASURBVNYY9V+i6FyS4X YVwi8L4Sf8hlwSG43ciA3/1cNnurYULUp77y8fdfQ2dPTu++b+N5NL/xJF55IMt6sQflkIP+E35JLYaORGaPh97YXpS2zp9uA8vXr/vqj/EkXnkgy3qxB+WQg/4Tfkktho5EbKc/z7Tl5o8gf2e842+oai/0sUnUsy3K5C+GUh/ITfkEtio5Eb4eH/255tryW97HT4vi5/9flZhUddUf8lis4lGW5XIfyyEH7Cb8glsdHIjfDwD1QXpaW995 ePOr7d4yxODO2la9K/L1G4JMPtKoRfFsJP+A25JDYauZHwUH/36fKSgrT0lxcW7tzW8bfo/xJF55IMt6sQflkIv/HCzzACZsL75wOGP7C/ta2iaOGTRfuqXW3V9aVPTuiKn5E4hN9wCL/xwi94i9G5JDYauRF7xf/Drtoy+zyrYkmxpdtt6ZlLa88cjfovUXQuyXC7CuGXhfATfkMui Y1GboS/nG9z+fbXHp23kJfzGW6jhN+gCD/hN+SS2GjkRvhz/FcbalYmpOflbNq75di5w7yczzgbJfwGRfgJvyGXxEYjNzJexx/Y76pZmPRTxRLqb6KT/n2JwiUZblch/LIQfsJvyCWx0ciN8PBfO1i/6icWq/JPtpeqPQd6r0f/lyg6l2S4XYXwy0L4TRX+64dbd9uTpigWa1x69YfdgYaaZYplpi 39GcWSPIHfVheOJUn5OrDRe42MK/7LB5udS5N+qlimPLJsn9jn+O94UFgVi1WZNvYLjqP/uyZlo4TfoAi/mcLfd7pwji3D+e0x/8UPK5Y9mfPblOBrcjjHsdHREf8c/776N2c+/pRtxca3d7XUnRH7S3ruflBMnejvjJbyXZOyUcJvUITfTOHvctk Xjz6B2uWyz3uvsuqtHFd/Q81bE77cn+yS2Gj0bVR8+A+fuXDYd+1Ix+ma5t4jgr9Edz4ovi jJ2DjhH4WlfNekbJTwGxThj3z4fQP7O3obxua7xgd/FjM8x3bHbls64Wej9xmx4f9uS+GLM5d9XHdsxzO/yl6Wu2i24Pfqv/NBQfhDGsJvUIQ/4uFvOrJ9/G8dtaW/nFn/rZxjW/eoZsWJj2sIPxvVj9Dwd+y2zdle19dXmfurhfXftfQ2Z8944Ged InBQEP6QhvAbFOEX9VB/T8/OjxpKag9s+4t/wk8cTv7YPtZxMCNpimKZkpC7u6470ED42ehtIzT8XS77jJVrP9 qW9tNVFV/6P3IWz3q6dk+f0C/RnQ4Kwh/SEH6DIvxCwt/nXffCvy0s/VNJ9Y7stBez918w0LEdnUtio5EbsQ/1Xzvc+kn+v/+xvPVi05Htaatr+CU9Btoo4Tcowi8k/L62nEdeXXv0bMOpzsrCF2w13QY6tqNzSWw0ciPj5XwG+xJF55I Mt6sQflkIv5iH+gcd9f83Ozfbtmhl9nvNDQ/+pqQSj+3oXBIbjdwQfoMuyXC7CuGXhfCLueL//LcJ2Wubzkm+qz8yY5JznHk2KjL8q/Z+uWrv6dz3ap/J3zQ62xdt86za+2U0f4mic0mG21UIvyyEX8wV/7cVq1+Wf1d/ZMYk5zjzbFR4+L94ZdWC//X0m/PzN6YsevrH/2J7+Gcvzt96Ipq/RNG5JMPtKoRfFsIv4HX8fXWH9+XMW5hT31Ltaqkoeonn+NloNG 9UePg/X2z/5SMr9rxSfSTz33/zkyd/99Tz85PKP4/mL1F0Lslwuwrhl4XwRz78fd9u+cMa2+NP2lZvyCkqzXm7ZsupB 75vWeKxHZ1LYqORG+Hh/3LVh3v+z7S/+x//8+/+x/9c8tzakpmZtcsdPNRvgI0SfoMi/GIe6r92+MTJaldbtaut2vV53ZnAZI5thhEwE94/Hzz8JzJXLYobeaj/uYcW/Sln75cP+hw/I3EIv+EQfiHh/38n82anpP3uP3KKSnOK/rDWxev42Wj0blTyQ/2/2LT8wcMv/vsShUsy3K5C+GUh/GLewKdz7XMr1x49y139bDT6Nyrhof5df07NfOWRX6TNWFS6sPr EKlnh7+utdfceM+Z3TcpGCb9BEX7u6p/smOQcZ56NSgj/nSZsX6KO3baRB6Xj731fbZOr9NHgr+IN+bOi5LsmZaOE36AIv7 neqz8SY5JznHk2KjT8jr1P/WLdEsfJ5eU1i6tPRij8aSM5v9pQs0yxWJU5xcXvvBxnscYt3v3 xF6OBT/pdTu5sxZI88nsrxj7rRov/4ocVo3++67OcpClKYnLCI/f6ZULsKqGslvDLQvh5r/7JjknOcebZqNjw70n66RuLHZ8vtj+XVP55ZK/4p60r2bYsLtd1qGO3Lemd6q6vSxan2Cs22h4qqPzmi8I5r62rW XeHK/5ppdUngn/+5wlJP08oam5wvZMwjfATfqMi/KZ5r35fW8604I24yWO/js/XlpOx+yPXxrSJrsok5zjzbFR0+OOWpJTuTHn6FzNW7Fxcvmfxe 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 zBi4yR/zLumnvwg7IXEjLW5hSV5hSV5rzX1hiZY3v8jG69uyTdXtjaW11 kkxV+xWLd+snRrZ8cVSb6fmHMvWfvyXMV9Qcm8N2JsfCPO+IGq oveKum4epcP2cdufLnrXD/seifBYlUsKRnOb+/xiv8JfAHrWjvHf9fMsKsQflkIv4grftuisj8c+aqho+ej1qNrl 7+01Hm+xX/18JmuLUWL0t77y0cdvQ0dvfu+uTz5c9x9Z/RMpz10OeNX6c9PXZb3kozwL8l5QzvpPMBLIsP3dRD5N5WyUe2q UbFY12yuedDPjfXw91UX2RTLzIQkW3ZR3lSLVbFMSSgstk+zKv d82l7kd231hnfFb1T8rkL4ZSH8Ap7jv3a49ZO8N1Y8k56RtmLj +gNnj/hvtPjaC9OXjL6lj92Wbn969f59ETu2IzoTXlJda+fEvvKyvg4G 2uinPYMT/vLGePgPfWBLeqe6ozknKSW7KG/64t0ftWyfPae08K1Qrvgj+11rkXFQSNxVCL8shF/UG/jceX7Yd/JCkz+w33O2MbRb/WMp/Gw0Ojca2+EfvXV/oLrInl2U92hRW5OvLefxvJzCqAi/sTZK+A2K8EsM/9/2bHst6WWnw/d1+avPzyo86orKYzs6l8RGIzexHf6SQx/Y5myv850unJNC+Cc5hN+gCH/kw+/rqzu8L2fewpz6lmpXS0XRS6P3+g1UF6WlvfeXjzq+3eMsTrznT cISj+3oXBIbjdzEXvinjtzF9owtPU/3HP9o+Is31RfEyX6O33AbJfwGRfgjH/6+b7f8Yc3TwXto//H53356ceRD3afLSwrS0l9eWLhzW8ffovPYjs4lsdHITYyF/87Td7pwzmvj7/CXvyQDbpTwGxThF/JQ//9rz7FYnyr4j5yi0pyiP6x1XWjxB/a3tlUULXyyaF+1q626vvRJrvjZaHRsNMbD3/1ZTtIUxTIlYeXBhr7oWJJhN0r4DYrwC3iof2D/F+6cpNfXHj3b0NHb0PFdY+/1Fv8Pu2rL7POsiiXFlm63pWcurT1zNCqP7ehcEhuN3MR4+GN3S YbbVQi/LIQ/4uFvOrJ9/Mv2bOkvZ9Z/2+JrL0zfXL79tUfnLXzQl/MxjICZ8Nk8eX6qdmgIG8ViFbzF6FzShDc64U9Mnp86mV2F8MtC +MXc1X+xzuksqdmtzYb61o+6r7X4rzbUrExIz8vZtHfLsXOHeT kfG42OjU7mMm7N5hrp0WUedCbzY0p24e8nvGMTflkIv5jwf7Mu 7dmFpX8qqd6R/fzPk9IXJv7bB3v6brT4A/tdNQuTfqpYrArP8bPR6NjoZMLPGHFk7diEXxbCLyT8vracR15d e/Rsw6nOysIXnn7nvaWPllb7rh2sX/UTi1X5J9tL1Z4Dvdej9hCNwiWx0cgN4TfbEH6zIfxirvivHW7d 99sV2bZFK7Pfc21+r/i3Dd82+W+0+C8fbHYuTfqpYpnyyLJ9ZnvLXjYanRsl/GYbwm82hF/EXf2N3YEj33zX0NE77q7+Gy3+q/vq35z5+FO2FRvf3tVSd0bEL+mJpbMGG43QEH6zDeE3G8Iv4K7+ bbaKj8pXv3zLXf3+Gy3+q4fPXDjsu3ak43RNc++RKD5Eo3BJbD RyQ/jNNoTfbAi/4Pfqv9bo2rXWdaHF/92WwhdnLvu47tiOZ36VvSx30exIvVf/2C8aH/em5ff/w9F/1mCjERrCb7Yh/GZD+AWH/2pDzQpbTXdLx27bnO11fX2Vub9aWP9dS29z9oyQ3id80uH/rLGl2vaQVUkqqmxtK0yfoVisStI71d0Xgm9gLib8n/YMbv3k6NZPjn7aMzixs8ZkNjqBz53wRic5E/6bVtQfqP308wl8LuE32xB+syH8kQ9/d/dOV1v1yIz+kp4ul33GyrUfbUv76aqKL/0fOYtnPV27J4Q3EJ1Q+JOD78oytejjitxlha0/HHK+9WTF6WN+7U3LU3JqttvmbK/r+iwnKUVM+JfkvPHYE4mPPZGYuiRzYmeNCXxW6pLMx55I1F61L Gyjk5wJbPTTnsHk+ana33TN5poH/XTCb7Yh/GZD+CMe/mOe/SuLSnPGRnuv/muHWz/J//c/lrdebDqyPW11TcR+SY/uiv+Ddenx2g8Bca9u37TzP3PSZyiW5JFfUybwoX7ty17X2hn2t 5y799S1dlbUHxC8USmz9+Q57W/6oN8awm+2IfxmQ/gFP9Qv/hC9Pfz2wtbLLf4bI083aFf5NdttSe9Ud31ROEfQFb92ra9dggv 5Otz4tGdQ/EYnPxPY6IGvLigW6+oN76YuyUyen/qgn074zTaE32wIv9nCP/ocvyUlo/aD15KmKA89b/u3FLuzU/Bz/LWffq59ASf2PPQkN7r35DlhG53kTGyjWz85qr2d6gT+poTfbEP 4zYbwx3z4Y3NJbDRyQ/jNNoTfbAg/4Tfkktho5Ibwm20Iv9kQfsJvyCWx0cgN4TfbEH6zIfyE35BLYq ORG8JvtiH8ZkP4Cb8hl8RGIzeE32xD+M2G8BN+Qy6JjUZuCL/Zhv***eEn/IZcEhuN3BB+sw3hNxvCb7zwM4yAEV8CRtZI+XYrhF8ewm+88Is/RKNwSWw0csMVv9mG8JsN4Sf8hlwSG43cEH6zDeE3G8JP+A25JD YauSH8ZhvCbzaEn/AbcklsNHJD+M02hN9sCD/hN+SS2GjkhvCbbQi/2RD+mA9/X2XuzLhc16GR387X1uS/0eJry3k8L6cwOXgL99Sigx/UFCRYrIplhq3ixGEjnDXYaISG8JttCL/ZEP5YD3+Xy56UnDCtoLLr+q3hL632jf3Dsdbts5OKKjsCLd0nC tNfLmy9HP1nDTYaoSH8ZhvCbzaEP7bDf/2Q860nK9ybcm12Z9/dw3/9kLPouZrucZ9y+ljUnzWMstGtnxx97InE5PmptZ9+LmyjFfUHt I1OYN8m/GYbwm82hD+2w99XmTtTezA/Ltd14K7hv9pQs8JG+COw0QNfXVAs1tUb3k1dkvnYE4liNrr35L ngRpPnpz7opxN+sw3hNxvCH9Ph73LZ522v67vR0uWyTyuobNll S3qnuvvqYdc7CXO21/XxUH/EN1rX2qlYrHtPnquoPxDp99rTTXCjD7pmwm+2IfxmQ/hjOPzjr937KnNtdqf3w4qX4yxW5SH7ysbeY/5xl/7+QIOzKMFiVSwp9prT3NwXxo1q1/qKxbpmc40hNkr4zTaE32wIfwyHP5aXZKyN1rV27j15zigbJfxm G8JvNoSf8BtySWw0ckP4zTaE32wIP+E35JLYaOSG8JttCL/ZEH7Cb8glsdHIDeE32xB+syH8hN+QS2KjkRvCb7Yh/GZD+Am/IZfERiM3hN9sQ/jNhvATfkMuiY1Gbgi/2Ybwmw3hn1T4H3siUcu/sFEsVsFbjM4lsdHIfWLy/FTCb6oh/GZD+Cce/or6A+IzwDAhzmR+TFm94V3pNWKEDeE3G8I/8fAzTDQPV+1MiEP4zYbwE34mNofwMyEO4Tcbwk/4mdgcws+EOITfbAg/4Wdicwg/E+IQfrMh/ISfic0h/EyIQ/jNhvATfiY2h/AzIQ7hNxvCT/iZ2BzCz4Q4hN9sCD/hZ2JzCD8T4hB+syH8hJ8x5DS5SqdarIrFqlisUwtLsx8vrfbd8 gcIv2mnyVX6aFFbk/avHbttI/tJvK3mTENjpe0hq2KZYVt3tKFv5M8TfrMh/ISfMeTccnL3teUQfmZ0dOFPC/5zl8s+p6iyI9DS11Wy+OXC1svanyf8ZkP4CT9jyBl3xR9v2/YB4WeCc+cr/mnFm+rferLi9LHb/jzhNxvCT/gZQw5X/Mzd5i5X/NcPOd96suL0MV9bzjTtkf9u7c8TfrMh/ISfMeQQfuZuc/+H+v2X6yrshN+0CD/hZww542/uU56z26YFb+CSeTZnomHG7RvLSg59MBZ+f2D05r4pCbm11R0B7 c8TfrMh/ISfic0h/EyIQ/jNhvATfiY2h/AzIQ7hNxvCT/iZ2BzCz4Q4hN9sCL9XsVgr6g/UtXYyTMxMRf0BbceuOvSZ9MUw0Tz/t+GIlF2F8EtE+L1K8A4phmEYRtQQflnMHn5VVXt7e71ATCj9j/9QLNaUXz61a9euxsbGxsbGzZWVT8z4lydm/MvRo0dlrw5RpHrHjjvuKorFunfvXjFrkH3uNy/CDxjK4PHy5NedvmuDno1zLVYlLnNH54D2Ea/Xq1isJcXFgUBAVf3u/ISp+e4BVe3t7Z2VmDgrMTEQCMhdO2S4dt7x+lSLVUl+2+27pv0 nbVd5JSuLXcWcCH+4DXnK47UHsqbMLTzkGx70lM1RLFbFMqfcc 76zKnPqyH/3u/NtBW6/dtQpcYXugaEBd+H0fPeA7L8BotfwOedy29yk152+Lqd96Q7v3w bchY+XeYZUVVXVkuLisVP2gLsgec7c+EL3wLA6eqJvbGyUuXjI NOgpW1Dg9mv/wq5icoQ/3IY85fFzyj2Dw+cdWXELdni9TvuM+VWdw6qqDrgL4hbsOL6vIG 7Bjs8PFMRlO31D6oC7IM6qWBIK3H7V58iIGzn8gLvocdpXOn1a 66+ddxS+OXo2VyzW92trVVVV1eEB99pnq464Rn64VFVVTUtNzc/Lk7FgSDfoKZujxL3uPD9yxa9YrJsrN6uqyq5iToQ/3EbDr6o9TntCxh+3FMRZFYtVSd7o8dZnWLKdPZ+Vx88p3bl+en yZZ2h4wF04NWWTc9uCqfnugbHPBe4mGP7hwc7arOWO86M/KI67W8rvzk/Q7p+aOvoYUn5eHmdzExse/+AQu4rJEf5w04Xf0aOqqjrcuSNlRkbp70fDn7y2LFOxO3zqFW/VS/OrOoe8VfPjyzxD4z4FuDMt/H/zHd+clVnbOTj2+NDYFf+Au8BW5R1W1QF3wehDuK9kZXE2NyW/Oz/f6Rsa8pQljgs/u4qZEf5wC4Z/wF0Qt2CbY9N8y4IdniPlyUkFu/9z9KH+F/5Q+Ypid/iGO3ekTBl9ccuCHd6vnfY5wQfcgDvpcdpXOntPBfec6aNn81ey stJSU0cfvO0cVlVVHbmVpLe3d9wTATCV4cHO2oy4W27u03aVQO Dy7btKf38/u0rMI/zhNnZz34yMPzT7hs67C1MUi3WqvbZz8FLw5r7etrLp8WVtX1bN H3lS3+/OT5q/bU8ZD/Vjopqbm8c9dzsmEAi8kpU1KzGxv79fysIQbe69qygWK7tKbCP8 kgy4R27uG4+b+zA5mys3KxZrfl6edomvqmpzc3NaaqpisTY3N8 teHaLI7btKe3s7u4pJEH5Zgi/nCxq+88v5hn3t/+2T8rPAsO9U++hjgzCK92trde+PNisxsb29Xfa6EHWcDsftuwr VNwPCH25DnvKZ2pOug56ypfd53H7IUz4zv3z92jpH2avj7+kb+ 5+o42/JueV5hKpTg0Oe8uUO3wQXOvrM38j7Cty2sOVVzlvXf8tKggbcB XEJE7ovYdzL0ib1F4He7e+NKntFiFLsKuZE+MNNH/7gm/Yc8J4eDW3Z8cHB4+XJU5SkOXNnBMPfPejZONcy5RfJSY+vLyvW Ap/8Znn+bMUy+sR/8H8+eGqHPXPH6aby5VXOsgVzkx9WkleV56coFltx2er5yUlTLS kFZavmWqbMLTvQNrKAP3vqsxWLVUmp8g6rY2/oMXzOmbl0Q9nKZ6tOnXdkKylVnZ1Vz67MX52xNCPeqsRvcJ/S7gza2OreMN0yuv6Rv+3wgHvt3OSk6fnugbE3CNvY1lmfFWdVL LZyz7mx9yy65ilPmTM3bsrc/PUFyVOU5JcykmfPTX5YiXvdea65PHNVvm2te+Caz5HP7Y2Tccc 3RZe9KEQjdhXTIvzhNnZRblUsc8oPOQtsVd5hvzs/e4f3iqqqw96q+fHrnbten191esCzcW58MPxHnfYF5Z4uT5lt+v qy4hmvO3tO7Eh5aUvV2luu+Ed+qhjyOVZm7Nqlhb/A3eUpS5lfdfqv7rcX2xc8nu/u95RNT6nyXnIXJM+ZO7KAjPy8F6eOPZUwPOjZlJG/zen4s8d3TfU5svIdrrI5SvwG18G3s0b+z0vLPWfd+UvLPT5vVf Zv8rMfz3T0dFbNH/nRQVVVvzs/e8fxfQXxhe6Bbqd9QbnnkqoO+Ryvj/xwMPJiIb87P3vH6abyGYXu/uPl8Qt2eHvc+QmKZUaWo+uv7sLH15cVL9/prsoucJ8OfqEwMZzNESJ2FdMi/OGmu+J3VGWMHFEJq6v2fby7LCPOqsTnl69fWu4ZvOWh/l27tE8c8pQlri8rnlnmGRr0lC0tLsu/X/jXOn1XfI615Z7BIc+mX9uXvuroUX2OV8s8Q7f8FPLw3OSkkfcQ HDPgde8qz8x3nmsuf35teX5mxkuZBfnZ5Z+5R8N/2rl80y1POox7GmL0bQe1dx4873O/PddiVZLfdv2l4c3kKYol5c2qDS+N/vULDu4rX+7wqT3O5Zs8Q9o7GWc7fUOqz5GxYGnG8vpO99pnSza stgV/qsBEcDZHiNhVTIvwh9vt4R+5Ph7yOYJX+eudu16fW3Z8wFs1/5Yr/qU7vJe8VQum3zf8tzzUf7/wjy1g5bh3B/K785eWey6p6iVP2dICt8dpf1iJzy9fv2Buytvu/uO3XvH3nXesWmxfcGv4g68X125L3LItc5XzfL+nbEGG/aUsx7lrnrJE+9IXgw8PjDyRPz78CQXu8+cdK5/dsm3DcodvwF0QN/aqdEwMZ3OEiF3FtAh/uN35OX6rkrzmI8f6uRbr1JeWLo4vdJ//7D7P8Y+Gv/yQsyBu3HP8+pv77hf+5X90jSygcEdp5rjwDw96HQXJU0bfY+Bv 3qoFin2Xx5GtpFR5r3nKl9d3ugun3voc/63hH3v+Qh1wF8Sv2LF7zVztOX7vgTeTp4x7jt+qJL/t7mm+Pfxzkx8e96HbX+mAB8bZHCFiVzEtwh9trnirlpr0XXuHO 3fY1vI2BpPE2RwhYlcxLcIfPS55ymzKrb8220x6nPYZ414vgAn ibI4QsauYFuEHYgpnc4SIXcW0CD8QUzibI0TsKqZF+IGYwtkcI WJXMS3CD8QUzuYIEbuKaRF+IKZwNkeI2FVMi/ADMYWzOULErmJahB+IKZzNESJ2FdMi/EBM4WyOELGrmBbhB2IKZ3OEiF3FtAg/EFM4myNE7CqmRfiBmMLZHCFiVzEtwg/EFM7mCBG7imkRfiCmcDZHiNhVTIvwAzGFszlCxK5iWoQfiCmcz REidhXTIvxATOFsjhCxq5gW4QdiCmdzhIhdxbQIPxBTOJsjROw qpkX4gZjC2RwhYlcxLcIPxBTO5ggRu4ppEX4gpnA2R4jYVUyL8 AMxhbM5QsSuYlqEH4gpnM0RInYV0yL8QEzhbI4QsauYFuEHYgp nc4SIXcW0CD8QUzibI0TsKqZF+IGYwtkcIWJXMS3CD8QUzuYIE buKaRF+IKZwNkeI2FVMi/ADMYWzOULErmJahB+IKZzNESJ2FdMi/EBM4WyOELGrmBbhB2IKZ3OEiF3FtAg/EFM4myNE7CqmRfiBmMLZHCFiVzEtwg/EFM7mCBG7imkRfiCmcDZHiNhVTIvwA4Y2NOjvHxy6ccXX+flp3 5WbnM1xN+wqGEH4AePqby1bMNeWlrpkacav836//AX7zk7O5rgTdhWMIfyAYQ15yp8obr3619b1i8s9g6rPkWF3cDb HHbCrYBzCDxjWkKf88ZU7jzftXGn7zc4mz8GyZzmb447YVTAO4 QcM60bXwY1l5WXjZqeHsznugF0F4xB+IKZwNkeI2FVMi/ADMYWzOULErmJahB+IKZzNESJ2FdMi/EBM4WyOELGrmBbhB2IKZ3OEiF3FtAg/EFM4myNE7CqmRfiBmMLZHCFiVzEtwg/EFM7mCBG7imkRfiCmcDZHiNhVTIvwAzGFszlCxK5iWoQfiCmcO Zi1cQAAAEVJREFUzREidhXTIvxATOFsjhCxq5gW4QdiCmdzhIh dxbQIPxBTOJsjROwqpkX4gZjC2RwhYlcxLcIPxBTO5ggRu4pp/X9b7zpLTShcLQAAAABJRU5ErkJggg==[/IMG]
I just ordered an illuminated fog light button for my car. I'm swapping out my factory HU for the appradio 2 which will leave the USB and AUX plugs useless. As soon as I get the parts in Ill be taking the USB and AUX out and place the button there!
mjreynolds2 is offline   Reply With Quote
Old 03-28-2013, 07:45 AM   #175
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Originally Posted by bpracer View Post
I'm going by what somebody else posted. If true great, if not, well, it should still work. I'll know next week.
Product Name: BRZ WIPER STALK FOR PREMIUM MODEL - WITH FOG LIGHT
SWITCH
Item#: 83115FJ070
Unit Price: $60.00
Reading through all the posts I'm still trying to find a stalk without "Auto" position, with FOG Light position. A part number for them. I've also read that a Tundra or Corolla stalk will work but no part numbers.
@bpracer, can you confirm this stalk did not have "auto"?
FRSFirestorm is offline   Reply With Quote
Old 03-28-2013, 10:08 AM   #176
bpracer
Drives: Asphalt FR-S
This switch has the "auto" position. So, it is not perfect.
I'm trying to think of something to do with that step in the switch, if anything.
I may try to take the label off that position. I am waiting for my bezels so I have not tried to install yet.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 03-28-2013, 10:18 AM   #177
PatGT86
Drives: 2013 Raven Scion FR-S
Everything I've read seems to indicate that the Toyota stalk (part number 84140-02670) DOES NOT have the auto position -- the only catch being that the retaining clip that comes with this one is too big and you'll need to remove & reuse the clip from the factory FR-S stalk.
If you google the part number, any pics that come up look like it's what you're looking for.
I have not ordered it yet, however I do intend to when I'm ready to complete this mod...
PatGT86 is offline   Reply With Quote
Old 03-28-2013, 10:28 AM   #178
zooki
Drives: waiting on a 2021...
Everything I've read seems to indicate that the Toyota stalk (part number 84140-02670) DOES NOT have the auto position -- the only catch being that the retaining clip that comes with this one is too big and you'll ne 1,ed to remove & reuse the clip from the factory FR-S .
This is he correct part number. This is the stalk I used. It does NOT have the Auto position, and it fits right in when you reuse the spring clip from the old switch.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 03-28-2013, 10:28 AM   #179
bpracer
From this website, that part is both Tundra, Corolla, and Matrix part so that clears up some confusion for me as far as car models.
http://www.toyotapartszone.com/oem/t...140-02670.html
Geez, you can get virtually the same Subaru part for so much less, ah well. I'm not sure I want to spend another $90 for this part, maybe...
Asphalt FR-S
Ducati 848
Old 03-28-2013, 10:45 AM   #180
PatGT86
Aw c'mon, think of how good it will look!
Sent from my Nexus 4 using Tapatalk 2
Old 03-28-2013, 11:21 AM   #181
Sco2355
Try amayama to see about a price. They were usually cheaper than most places I looked.
Sco2355 is offline   Reply With Quote
Old 03-28-2013, 03:42 PM   #182
bpracer
Yeah, yeah, already ordered the Corolla, Tundra, Matrix switch...
I may take apart the BRZ switch to see what makes it tick. Maybe there is something creative that can be done with the auto setting.
Asphalt FR-S
Ducati 848
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
