Old 03-26-2013, 05:14 PM   #57
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by ultra View Post
The next big problem is that you'll need a completely new transmission as well. You see, the H1V8 is designed for sub 1000kg cars with bike trannies or sequential boxes.
The ZN6 at 1400+kgs is far too heavy for a bike transmission to handle which leaves you with two choices:
A: A Hollinger style sequential box. Big $$$ there.
B: Fab up a custom bellhousing to mate the H1V8 to the stockZN6 Aisin tranny. Better have some mad CAD skills and be prepared to completely change/build up the tranny internals and possibly swap put most of the remaining drivetrain gearing as well too. Don;t take my word for it - have a read through the Miatabusa build on MotoIQ for some good info on the joys of putting a bike-derived motor into a conventional road car.
i think option B would be best and if i'm not mistaken the builder of the engines, Hartley enterprises will build you an adapter for your stock transmission. at least that what i got off the website before they sold their engine technology.
FreshFRS is offline   Reply With Quote
Old 03-26-2013, 05:16 PM   #58
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
This discussion is so full of FAIL its making my head hurt.
Bottom line is you would be WELL above $80,000 to do this swap after parts and labor. If you are crazy enough to spend that kind of money on swapping in this type of motor into your FR-S when there are better, cheaper alternatives, there is ZERO chance you will listen to any form of reason.
When you get finished installing this motor, send me a PM. I have a pink unicorn that farts pixie dust I want to sell you.
Scott
naikaidriver is offline   Reply With Quote
The Following User Says Thank You to naikaidriver For This Useful Post:
ultra (03-26-2013)
Old 03-26-2013, 05:19 PM   #59
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Assuming they did, you still need to figure out how to deal with an input shaft that's spinning at 7500rpms before the engine is even in the meat of its powerband, let alone at its' peak.
Hence, much like the Miatabusa guys found out, you'd probably need to do some sort of gear reduction magic *before* the bellhousing.
Maybe.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 03-26-2013, 05:25 PM   #60
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Scott
this discussion is just toying around with the idea, ignoring the cost it would be an epic build. and would produce a perfect amount of power while reducing the weight of the car by ~100lbs its an interesting concept. Just way too expensive to be practical in anyway.
Old 03-26-2013, 05:26 PM   #61
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Maybe.
that is a very good point.
i guess we would have to test the tranny to see if it could handle the RPMs (this engine revs to 10k) , i think we would be somewhat alright considering that my old s2k (AP1) when finished revved out to 9500. i mean skylines and supras on stock trannys can push 10k rpm if built right.
Old 03-26-2013, 05:43 PM   #62
swift996
swift996's Avatar
I've followed this engine for a while. I wish someone would mass produce it. There are so many applications for it.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-26-2013, 06:54 PM   #63
bolus
Drives: FRS, Atom
The atom uses a Sadev sequential (another $20k) though it is the front wheel drive model. If you spent that much for an engine you have to mate it to a sequential box
how about go AWD with a quaife?
http://www.quaife.co.uk/shop/products/qbe87g
bolus is offline   Reply With Quote
The Following User Says Thank You to bolus For This Useful Post:
ultra (03-27-2013)
Old 03-26-2013, 08:41 PM   #64
Turdinator
Señor Member
Turdinator's Avatar
If you have the money then i say go for it. With some other supporting mods it would make for one HELL of a fun car. Cusco do a close ratio kit for the g/box and a 5.1 FD. Then there is the sound... ITB, flat plane crank and 10,000rpm...
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
TouchMyHonda (08-23-2013)
Old 12-09-2014, 09:21 PM   #65
mike the snake
I say take that engine, and that transmission, and mount them behind the seats, make a mid-engined monster out of it. Monster MR2
Old 12-10-2014, 11:51 AM   #66
Koa
Holy necro
Old 12-10-2014, 12:27 PM   #67
sato
sato's Avatar
Drives: Dodge Patitas
Originally Posted by JoeBoxer View Post
Yeah peak torque at 7500rpm is a huge turn off for me. I think it would be cool to strip down a scion iq and put that motor on the back though.
Check the website and see that sexy torque curve... even though peak is at 7500rpm, it is a very flat torque curve, with a flat torque curve of 200 ft-lbs from approximately 2750rpm...:
... and its a flat plane V8... sounds awesome
Originally Posted by Koa View Post
Holy necro
Fell for it too! Hahaha
sato is offline   Reply With Quote
Old 12-10-2014, 12:40 PM   #68
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
This is about as realistic as an S85 swap. Except 10x more expensive.
Old 12-11-2014, 11:40 AM   #69
bfrank1972
Drives: 2013 FR-S Argento
I'd imagine with the higher gearing driveability would suffer, and sure it's a much lighter motor, but that's with nothing on it. Add all the accessories (alternator, AC compressor, etc) and I think your weight gap will narrow quite a bit. Then think about maintenance on a Hyabusa engine - valve adjustments etc. Engine life overall will probably be 1/3 of a properly maintained FA20.
A fun idea for a budget-unlimited show car that's trying to be different, but for real-life driving probably the least practical option.
Old 12-11-2014, 11:52 AM   #70
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
An LS swap would be much more practical, which I think has been said already.
Amaya is offline   Reply With Quote
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 12:40 AM
What do you think about this idea... FRSowner Scion FR-S / Toyota 86 GT86 General Forum 10 07-20-2012 03:26 PM
Dealership playing games w/ price? Chewie4299 BRZ First-Gen (2012+) — General Topics 14 07-02-2012 06:11 PM
Playing music off of USB question Hanzo Electronics | Audio | NAV | Infotainment 22 06-26-2012 10:44 AM
My first time playing... ruskymx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 06-25-2012 02:19 AM
