Old 03-25-2013, 03:45 PM   #1
tennisfreak
Drives: 2018 BMW M240i
Wheels and Tires, what to pick Im so confused
I know this thread is likely to upset some on this board but Im sorry.
I have been going through thread after thread here and the more I look the more confused I get.
In the past I have always just went to discount tire had them tell me what would fit on my vehicle and pick one that I liked. I never stopped to consider how dramatically tires/wheels could affect your vehicle's performance (outside of how the vehicle rides).
So what I want:
Replace stock tires/wheels with new black powder coat wheels and stickier tires.
Improve cornering and grip without negatively affecting acceleration.
If possible get a larger diameter wheel with lower profile tire (if not I can stick to stock sizes on new wheel).
Any recommendations on what size of wheel/tire to get? I seen so many different wheel widths and then talk of tire stretching and offsets and it has honestly just confused the crap out of me and now I have no clue what to get.
Old 03-25-2013, 03:54 PM   #2
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
what are you looking to get out of the car? If you don't know do some serious thinking, and reading. If you want the car to feel the same as it does now maybe go with the same size or slightly wider than stock.
Old 03-25-2013, 04:12 PM   #3
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
Welcome to the hell that is selecting the perfect wheels/tires/suspension for you FR-S.
I've been in the same dilema for weeks now. Its fun, but damn does it make your brain hurt after a while. I've changed my mind no less than 15 times now....
Just keep looking at pics and find stuff u like and then ask questions about them. The members here are fantastic about answering questions promptly.
Also, call Zoeb at wheeldude. He has an FRS and cycles thru tons of Rota setups. Hes a great resource.
ilpad is offline   Reply With Quote
Old 03-25-2013, 04:17 PM   #4
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
I would get black RPF1 17x9 with 245/40/17 if I were on a budget and looking for a light and sticky combo
shu5892001 is offline   Reply With Quote
The Following 2 Users Say Thank You to shu5892001 For This Useful Post:
D1cker (03-25-2013), whataboutbob (03-25-2013)
Old 03-25-2013, 04:39 PM   #5
Opposed
Drives: 2013 Asphalt FR-S
Agreed. I went with the Mach V Awesomes, also light and affordable and comes in a 17x9.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 03-25-2013, 04:58 PM   #6
D1cker
Drives: B9 S4/ND2
Pick a wheel you like the look of and then we can hep you with wheel/tire sizing.
D1cker is offline   Reply With Quote
Old 03-25-2013, 05:12 PM   #7
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Lol don't be like me... I ordered a set of 18x9.5 +27 et wheels for $3000. To decide I wanted to go a different route before tossing em on... Now I got a set of 18x10s on the way that I spent a pretty penny on as well.
However I'm a wheel whore.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-25-2013, 05:38 PM   #8
ShoNUFF
Who's the BADDEST?
ShoNUFF's Avatar
Drives: 2013 BRZ Limited - Crystal Black
How does the car ride with such an aggressive setup? Accel wise?
AM I THE MEANEST?
AM I THE PRETTIEST?
AM I THE BADDEST LOW DOWN MOFO AROUND TOWN?
SHO-NUFF!
ShoNUFF is offline   Reply With Quote
Old 03-25-2013, 08:12 PM   #9
tennisfreak
Here a few wheels I like. I have to stay within my budget which is less than $200 a wheel. Is it ok to go up to 18 without affecting acceleration? Or do I need to stay at 17?
http://www.tirerack.com/wheels/Wheel..._19&sort=Brand
http://www.tirerack.com/wheels/Wheel...3&autoModClar=
Old 03-25-2013, 08:15 PM   #10
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
If you improve grip you may accelerate faster as long more grip is not followed with big weight gain.. 17 × 8-9 might be the best option for you pal.. 18 usually have better stance and looks but for minimum rotating mass the width should be lower than 8"... except you opt for real light wheels like OZ Ultraleggera..
dokterdewe is offline   Reply With Quote
Old 03-25-2013, 08:34 PM   #11
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Don't know I haven't driven it in 2 months, and it'll be another 2 months until I drive it again. Also, I don't know what stock wheel/tires weight but my 18x10 setup with tires mounted weight less then 45lbs filled
Omar GC
Instagram: 2jzus
Old 03-25-2013, 08:53 PM   #12
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
That's funny cause I just ordered the hyper black motegi sp10 today in 18x8 with Dunlop direzza z101 tires in 225/40/18. I wanted hyper black over black. I didn't want to add weight and I didn't want understeer from a staggered setup. I like the plus 40 offset for a flush front. I don't think you can go wrong with any you linked to just look at the specs and weights. Tire rack includes the lug nuts and centering rings for no extra charge. I'll have pics by the end of the week. Your only gonna hurt acceleration performance if you go with a larger tire diameter or a heavier than stock wheel and tire. The motegi's should save a pound or two per wheel and the tires will add about a lb. So I'll end up even or a little lighter hopefully.
FastLane1000 is offline   Reply With Quote
The Following User Says Thank You to FastLane1000 For This Useful Post:
ShoNUFF (03-25-2013)
Old 03-25-2013, 09:46 PM   #13
whataboutbob
AutoX-10/10ths every run
Worked for me. Make sure you get the 35 offset, especially if you don't plan on doing coil overs.
Build thread:Here
Old 03-25-2013, 11:30 PM   #14
tennisfreak
Cool thanks, looking forward to some pics!
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
FRS-Stock Rims and Tires For sale New! 500 pick up 650 shipped FRS-Jay Wheels and Tires 0 01-10-2013 01:20 PM
Help please. Will these wheels/tires fit? Suiris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-03-2012 08:50 PM
Pick up my FRS friday... ordering wheels today. Some questions NickFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-19-2012 10:14 PM
