Old 07-03-2012, 11:59 AM   #1
Suiris
Suiris's Avatar
Help please. Will these wheels/tires fit?
I am looking to purchase wheels/tires for my FR-S. Suspension height is stock at the moment but I will put some drop in it in the near future.
I'm not super up to speed on what offset, backspacing and all that other jazz on a tire really translates to... I really just want to know.. will TAB A fit into SLOT B without any issues?
Thanks!!
The metal I'm looking is:
Enkei Performance Series GW8
http://www.tirerack.com/wheels/Wheel...ed&showRear=no
and the rubber:
Dunlop Direzza Sport Z1 Star Spec
http://www.tirerack.com/tires/tires....cleSearch=true
2013 Scion FR-S Raven MT: http://www.ft86club.com/forums/dto_g...ehicle_id=1141
--This tagline is umop episdn
Suiris is offline   Reply With Quote
Old 07-03-2012, 02:13 PM   #2
bneale
bneale's Avatar
Drives: Scion FR-S
Those are nothing special. They are the exact same width and size as the stock rims.
Also, if you use the vehicle configurator thing properly, they will always fit. Tirerack will measure a customer car to confirm fitment before putting the config up on their website.
So in theory, as long as your using the config tool, you should be fine. I don't see any problems.
Here I was thinking you were trying to get 9 inch wheels like I want. 7 inch wheels will clear with room to spare as long as you get the correct offset.
bneale
bneale is offline   Reply With Quote
Old 07-03-2012, 06:38 PM   #3
Suiris
Suiris's Avatar
Well I think the offset is different between that one and factory. Factory is 48mm and those are 42mm.. Still good?
Old 07-03-2012, 06:44 PM   #4
schtebie
Drives: CBS BRZ Limited
If the offset is +42, it means it is pushed outward (think "away" from the car). It should fit just fine.
There's another vehicle with a 17x7 +42 in the wheel gallery.
schtebie is offline   Reply With Quote
Old 07-03-2012, 08:50 PM   #5
Suiris
Suiris's Avatar
Thanks for the info! Will be ordering this up soon!
Widest Track tires for stock wheels?? track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 10-11-2015 11:01 AM
FRS FACTORY WHEELS AND TIRES FOR SALE detainu Wheels and Tires 24 07-06-2012 05:06 PM
FRS FACTORY WHEELS AND TIRES FOR SALE detainu Northwest 5 06-23-2012 12:40 AM
Delete driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-21-2012 12:50 AM
Winter tires and wheels, what is your plan? RaceR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 06-01-2012 10:52 PM
