go_a_way1
Old 03-25-2013, 02:21 PM   #1023
philosophy
philosopher
Drives: '13 BRZ Sport-Tech CB MT
Originally Posted by BRZfan View Post
I just purchased a set of Enkei, 17 X 7.5, GTC01's at Tire Discount. (see my wheels thread). I rely upon them to know what can and should be done. I am using the same OEM tires and was told that I can, when replacing the OEM tires then go to a larger tire size (width) if desired. Regarding wanting to stay stock, the Enkei wheels have the same + 48 offset.
These wheels look great! Thanks.
philosophy is offline   Reply With Quote
Old 03-25-2013, 02:34 PM   #1024
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Originally Posted by tedddee View Post
Wow really?
Here I am nervous about putting 235/40's on 7.5's. I have a set of 04 STi BBS that I want to use on the BRZ, everywhere I look says 235/40's need 8 inches at least.
The 235/40/17 has a smaller diameter then the stock tire but not by much and its about an inch wider. i have been racing on a this type of set you on my Honda Challenge race car because they only let me have a 7 inch wide rim. we just tracked our frs this week end and loved the way she felt. we ran at willow springs raceway (big track) only up grades we have are TRD air filter, TRD aero kit, Hawk break pad (DTC30) and 235/40/17 Toyo R1R tire. during the time attack we ran a 1:38.0 for a 4th place finish. car was planted and was super easy to drive with a touch of under steer
DAMotorsports is offline   Reply With Quote
Old 03-25-2013, 02:48 PM   #1025
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
Originally Posted by Khyron686 View Post
The best way is to browse the other wheel threads and note the tire choices on the ones you like. AutoX guys use fat tires for extra grip so they will have some meaty choices as well - so check their subforum as well. The Yok Advan AD08 in 235 is wider than some 255s.
225/40-18 is 3.5 inches of sidewall.
215/45-17 is 3.8 inches of sidewall (stock).
215/50-17 is 4.23 inches of sidewall and looks 4x4ish
A 911 on 20s is 3.38 inches of sidewall and looks like a rubber band - it doesn't take much to make a big difference IMO.
Also if you don't like low-profile tires consider sticking with 17.
kk so i think i've settled on 225/40 on the front 8.5 and 235/40 on the rear 9.5, i'm a liiiittle worried about rubbing in the rear, think that'll work?
eddieEndo is offline   Reply With Quote
Old 03-25-2013, 03:46 PM   #1026
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
18x8.5 +38 in the front
18x9.5 +38 in the rear
225/40 in the front, 235/40 in the rear: will this rub at all on stock suspension?
Old 03-25-2013, 03:48 PM   #1027
itdansharpe
itdansharpe's Avatar
Fitment is perfectly safe, albeit a bit of a stretch on the rubber.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 03-25-2013, 03:50 PM   #1028
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
hmmm are both wheels gonna be stretched? trying to avoid stretched heard some horror stories
help me come up with a fitment for those wheels haha, I don't want stretch and i like my sidewall so probably sticking with 40
Old 03-25-2013, 04:36 PM   #1029
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Is this a good set up for turbo frs
17x9 et 35 all around
225/45 front
245/45 rear
Old 03-25-2013, 04:39 PM   #1030
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
225/45 front
245/45 rear
Depending on power output and quality of tire it should be fine.
Tansey86 is offline   Reply With Quote
Old 03-25-2013, 04:42 PM   #1031
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
300whp
Looking at hankook v12
Old 03-25-2013, 05:05 PM   #1032
wparsons
wparsons's Avatar
Originally Posted by N8marsh View Post
wouldn't circumference change if diameter changes though?
Originally Posted by philosophy View Post
That was my worry. But it seems, from what is said here, that half an inch extra in diameter won't make a big enough difference. I sure hope not because it looks like I'm gonna get some 17x7.5's!
Ummmm, both sets are 17" diameter. The width is different, but not the diameter.
flickr
Old 03-25-2013, 05:07 PM   #1033
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
That will be pretty stretchy (but still totally fit fine) which is what you said you didn't like.
Have a look at this guy - he's got the 265s on both (which you'd only have on the rear) and see if you like the meat. Then you could do 235 or so on the front and still retain some tight steering.
http://www.ft86club.com/forums/showthread.php?t=31920
Khyron686 is offline   Reply With Quote
Old 03-25-2013, 05:08 PM   #1034
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
correct me if I'm wrong but 235 on a 9.5 is a slight stretch, no?
dori. is offline   Reply With Quote
Old 03-25-2013, 05:10 PM   #1035
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
ok cool, maybe 225 in the front 255 in the rear?
Old 03-25-2013, 05:11 PM   #1036
D1cker
Drives: B9 S4/ND2
It will not effect the outside diameter of the tire. You will be just fine with 215/45/17's on those wheels.
D1cker is offline   Reply With Quote
The Following User Says Thank You to D1cker For This Useful Post:
Huehuecoyotl (03-25-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
