Old 03-25-2013, 02:46 PM   #295
2forme
Originally Posted by sw20kosh View Post
Hey Gem,
I know you were concerned about heat and track-ability of the kit. Looks like the stock radiator is not sufficient to handle this extra power. Oil cooler would be a must too.
http://www.ft86club.com/forums/showp...35&postcount=9
"Rough day for me today. Vortech super charger heat soaked motor and car ran slower than stock.
I laso changed my suspension from the last time I ran at the track FML, Horrible times. Oh well next time. I'll post up some video of a stock BRZ smoking me just pathetic."
What was the ambient temp? The vortech BRZ I beat on didn't break 238* on oil and 196* on coolant. Ambient temp was 35-40*, though LOL.
Old 03-25-2013, 02:52 PM   #296
sw20kosh
Drives: 2013 Black FR-S
don't know, but it was this weekend in socal at the FT86 cup challenge. It isn't that hot down there yet I don't think. The high of yesterday was 75. The high today is in the 60's.
Old 03-25-2013, 02:56 PM   #297
2forme
Wow, that's lame.
I think I remember seeing an upgraded radiator that also had an oil cooler built in made for the 86.... I can't find the link, though.
Old 03-25-2013, 02:57 PM   #298
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Wow, that's lame.
Robispec's total cooling solution. I have one coming!
http://www.ft86club.com/forums/showthread.php?t=28324
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
2forme (03-25-2013), Alfalasy (06-30-2013)
Old 03-25-2013, 02:57 PM   #299
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
What would it be heating up the engine bay? After market headers, with no wrap? Was he running an oil cooler?
Adeets is offline   Reply With Quote
Old 03-25-2013, 03:04 PM   #300
sw20kosh
simply running more power in an engine makes the cooling system work harder. Bigger explosions in the combustion chamber = more heat the system must take out. The stock radiator is not meant for 220+ whp.
To compound that, you are placing a hot obstruction in front of the radiator (the intercooler) which is also giving off heat. The overall efficency of the cooling system takes a big hit.
Old 03-25-2013, 03:05 PM   #301
2forme
Wow, that thing is big. I like the all-in-one solution. I wonder if it will fit with the Vortech airbox. It sits VERY close to the stock radiator by the looks of it...
The Following User Says Thank You to 2forme For This Useful Post:
Sportsguy83 (03-27-2013)
Old 03-25-2013, 03:07 PM   #302
Sportsguy83
Drives: Limited BRZ
Yeah, that is why I got it. All in one. Adding an oil cooler in front of IC, in front of AC condenser, in front of radiator does not sound like the best idea.
(did you see the post in my build I made specifically for you )
Old 03-25-2013, 03:07 PM   #303
Visconti
Drives: 05 STi
Hey Gem,
Woah woah woah. You are completely jumping the gun. Based on our last conversation I understand that your car was underperforming at the track. We can't point fingers at anyone or anything until we have some data. Unfortunately you didn't produce any data logs while on the track.
John
Visconti is offline   Reply With Quote
Old 03-25-2013, 03:16 PM   #304
2forme
John
Well, the temps I saw in the car I was in were considered "warm" and that was in near freezing ambient temps. I can't imagine it would be the same when the ambient is 75ish... LOL.
But yes, data logs would tell us what exactly happened.
No I didn't! Where is your build thread???
Old 03-25-2013, 03:20 PM   #305
Sportsguy83
Drives: Limited BRZ
See signature below
Old 03-25-2013, 03:30 PM   #306
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
John
I agree with John, whoa whoa
dont jump to conclusions YET
I been driving it in 90 degree weather pouding away just fine @ 10psi
running lean, or ill tuned WILL make you run hotter!!!
I am open on considering a radiator, but I dont like to spend the money unless i have a case for it, and at this point, I dont, but would love to justify one
Turbos and SCs have different results on oil temps, and I am not yet seeing temps that alarm me, oil or water, so I am curious what phenomena occurred on this guys car...When I track, i have the laptop wedged under passenger seat data logging, I want to see your data log, showing oil iat water timing and knock first
Huehuecoyotl is offline   Reply With Quote
Old 03-25-2013, 03:42 PM   #307
sw20kosh
John
Don't shoot the messenger! This is not my car. Just relaying info from the hpde forum.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
Huehuecoyotl (03-25-2013), Sportsguy83 (03-25-2013)
Old 03-26-2013, 08:22 PM   #308
Huehuecoyotl
This just in, preliminary work today with Perrin, furthering his tunes, and testing for him on my fuel, and geography
We dyno'd 255WHP, TQ remains at 191, we're working on that too, we did get 191.8 on another run, so if I took best numbers we're at 192 TQ!
-oe injectors
-oe fuel pump
-newest vortech compressor
-10psi baseline before I push 12psi(next week guys!)
-went up one size in tires since last dyno
More details to come...
We learned:
higher or better torque over drivable range will be tested
I have very crappy gas in the mountains where I live
The kit is awesome, and can go higher still
The better curve is perrins "map3" and the lesser one is "map1", we went thru a bunch or revisions, Jeff is an awesome guy to work with. No ego, very open, very available, easy to reach, and very easy to get results with. +1 Perrin.
Maha dyno raw figure is always gonna be low compared to every other dyno, so we add no additional correction beyond basic SAE to get Wheel Hp , NOT crank
only 1.5Gallons of hi-octane was mixed in to my 91 crap mix of a half tank, as we could see detonation earlier than my last visit, we didnt want to go into 93+ octane territory, and its pretty expensive, so we were careful to not add too much
After reading some posts on fuel pump installs gone wrong, wastegate actuators not being installed right and blowing up motors, whatever the TQ and HP output benefits may be of the TC setups, with this SC, there is no pulling of manifolds needed, no disconnecting fuel lines under the hood needed for install,no need for oil cooler, no oil pan welding, no need to add a Fuel Pump to make 255 WHP, no need for going past OE injectors. No Need for anything beyond a stock clutch. It feels like Vortech engineered a low risk setup with a KISS philosophy, makes installing, upgrading and being up and running an easy path to safe easy reliable power with little to no risk of boost spike, since it makes 10psi at redline. Jeff's setup for my next phase of testing will be a wastegate that holds pressure at 12psi. I dont think I plan to go further than that, feels risky-like to me.
Vortech makes all the parts for this entire kit in house, in america, they stock overnite spares for each and every part that is in my car and have inventory on spares and complete kits. Its a very effective model for me to work with looking forward to the least possible downtime for my build as I test out the upgrade paths.
Here is a video of my dyno two weeks ago, sorry its late!
[ame="http://www.youtube.com/watch?v=R5oMErjJ8sM"]Dyno Vortech supercharged BRZ - YouTube[/ame]
The Following 6 Users Say Thank You to Huehuecoyotl For This Useful Post:
akuhei (03-26-2013), Calum (03-26-2013), NorCalRider (03-27-2013), Pete (03-26-2013), Sonolin (03-26-2013), TRD_07 (03-30-2013)
Front pipe / Quad Tip Exhaust / Light Weight Race Exhaust / Unequal Length Headers JonMotoring Engine, Exhaust, Bolt-Ons 314 01-22-2016 12:19 PM
Pete's Perrin Vortech build thread Pete Member's Car Journals 91 06-04-2013 01:38 AM
*PHASTEK* Perrin Tuned Vortech Supercharger Install Thread (3 Vehicles, 3 Kits) PhastekSport Forced Induction 425 04-26-2013 10:06 AM
