Old 03-25-2013, 11:40 AM   #85
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Originally Posted by FR-S Matt View Post
$525 for that??? Yeah... NO. That or tell him you will install it. That's stupid.
It's $525 installed...not a bad price. Still could be $525 wasted but we need to get some dyno results to verify if this is a scam TRD product or not...
tripjammer is offline   Reply With Quote
Old 03-25-2013, 11:50 AM   #86
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Yeah Dyno result or MAF reading log with the ecutek cable.
We should start some MAF reading data base of all intake as many have ecutek cable it should be easy to make some log's comparing to their OEM airbox.
Mars2 is offline   Reply With Quote
The Following User Says Thank You to Mars2 For This Useful Post:
tripjammer (03-29-2013)
Old 03-25-2013, 12:34 PM   #87
zooki
Drives: waiting on a 2021...
Somebody in another thread was datalogging with the Torque app a stock FR-S, but was getting some pretty interesting reading on the CFM through the MAF. Something like 960 CFM, which just possibly be correct. Also a VE of 130+%. This is why I would like to see these intakes on a flow bench. But I don't know anybody who has one, and I'm too lazy to pull my intake off anyway...
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Old 03-25-2013, 12:43 PM   #88
zooki
Originally Posted by industrial View Post
I think airraid did this actually...
I've been trying to find the results, but all I can find is that used a bench to simulate airflow through the MAF.
Old 03-25-2013, 01:34 PM   #89
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by zooki View Post
What I would like to see is a flow bench test of the stock intake system, with all the resonators & inlet tube attached. Once you get a CFM rating on it, it should be simple to figure out how much HP it will support. I have a feeling it's not the bottleneck people think it is...maybe one of the vendors will do this to show how much better their intake flows versus stock.
Pressure drop is what matters.. If there is no or very little pressure drop with the stock system, there will be no gains from going to a "higher flowing" system. Of course the less the system can flow the greater the pressure drop would be. Ideally, having both sets of measurements (pressure drop and flow bench data) would paint a very clear picture.
I already ordered a digital manometer but they sent me the wrong dam thing... I'm gonna try to do a pressure drop measurement after the maf (time limited) to see how much drop there is in the stock setup as a whole.
Old 03-25-2013, 02:24 PM   #90
tennisfreak
Drives: 2018 BMW M240i
Originally Posted by naynaybm View Post
Aren't these all aftermarket parts, as in non-OEM? I didn't know dealers could order or install parts like these.
No they are all official Scion/Toyota parts.
The 5 axis kit is actually promoted by Scion and has a dedicated website.
Old 03-25-2013, 02:37 PM   #91
Push
I love food
Drives: Toyota Cressida
[ame="https://www.youtube.com/watch?v=vfXY5OtYhbU"]2013 Scion FRS TRD Race car for Celebrity Race walk around Long Beach, California - YouTube[/ame]
https://www.youtube.com/user/pushtoyota?feature=mhee
Keep an eye out on all the lastest Scion FRS Videos on my youtube page
Push is offline   Reply With Quote
The Following User Says Thank You to Push For This Useful Post:
Old 03-25-2013, 02:39 PM   #92
Kodename47
Kodename47's Avatar
Drives: UK GT86
Remember that the MAF doesn't read the actual airflow through the pipe, it's just a measured value that the ECU uses. Hence using a bigger or smaller pipe won't increase airflow but makes the MAF read a different value fooling the ECU to change the fuel input. That's why the Injen makes the power it does on a stock car.
The TRD seems to keep the MAF on the airbox and on the same size section and I'd assume they'd keep the air straighteners which will help. Having the tube behind the filter rather than a 90 degree bend like the OEM may mean that MAF reading will be changed again, whether this is beneficial though would have to wait and see.
@mad_sb has the right idea and those results I'd like to see. I have MAP readings for my setup, I'd like to see OEM ones to compare though.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-25-2013, 09:27 PM   #93
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I don't understand why this is a desired item. It looks like it's just a short ram. I understand it's larger but the filter box still sits in the engine bay. So the air flow will still be warm but now there's more of it?
This is the first intake I think looks the absolute worst and is an oversized stock intake with TRD letters written on it...
RIP OFF price inc.
I think this has a very novel design but the simplicity is throwing you guys off. Like some have mentioned:
1. Straight tube has less impedance than a 90 degree elbow (which is what most other aftermarket CAIs have).
2. Larger area filter for greater intake volume sucking cold air from outside the engine bay.
3. Accordion tube. Not sure the technical benefit but it adds a coolness factor because apparently Ferrari rally cars use it.
4. Way easier to change/clean the filter compared to most aftermarket CAIs.
The Following 3 Users Say Thank You to switchlanez For This Useful Post:
Pascal_TTH (04-09-2013), tripjammer (03-29-2013), Turdinator (03-26-2013)
Old 03-25-2013, 09:42 PM   #94
mad_sb
the accordion tube just allows the engine to do it's thing and rock side to side while the airbox stays attached to the core support. Not 100% necessary but from an oem perspective it's good protection against the boot workings it's way loose from the airbox or throttle body.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
switchlanez (03-25-2013), tripjammer (03-29-2013)
Old 03-25-2013, 10:05 PM   #95
switchlanez
Thanks for clarifying. That explains the accordion features on the stock tube as well.
Old 03-27-2013, 12:35 AM   #96
nb2005
Drives: Scion FRS
So now the only restriction is the post MAF hose on this TRD system... anyone know how much it cost ?
nb2005 is offline   Reply With Quote
Old 03-27-2013, 03:07 PM   #97
switchlanez
$525 according to this: http://www.ft86club.com/forums/showthread.php?t=31947
Old 03-27-2013, 03:33 PM   #98
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Maybe @nigel-jdmparts will carry it?
edit: and it will be a little bit cheaper than that^^
EvilBeaverFace is offline   Reply With Quote
2013 Long Beach Pro Celebrity Race Specification FR-S Preview. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 58 04-13-2013 09:36 AM
Tuned Scion FR-S Chosen as Next Toyota Pro/Celebrity Race Car for Long Beach GP Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 62 03-07-2013 04:25 PM
Cerritos/Long Beach ggpaul Southern California 12 11-12-2012 07:53 AM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
First 86 Long Beach Last Supper fieryhooligan Scion FR-S / Toyota 86 GT86 General Forum 1 04-09-2012 05:47 PM
