AVOturboworld
Old 03-21-2013, 04:53 AM   #2339
ft_sjo
Drives: GT86
If you want a proper fuel pump, buy Bosch. Won't be a direct drop-in though.
Old 03-21-2013, 05:33 PM   #2340
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
yeah I thought of inline Bosch 044
but the noise it makes is a KILLER
Walbro 255 vs Bosch 044 )
MSTiFK8R is offline   Reply With Quote
Old 03-23-2013, 07:18 PM   #2341
Calum
That Guy
Drives: 2013 asphalt FRS MT
Honest question, what's going on with the torque curve?
Old 03-23-2013, 07:46 PM   #2342
Calum
That Guy
Originally Posted by vubaru View Post
Boost is dropping from 5 psi to 4.5 in the midrange as I indicate above, we're looking at the limit of the stock 5 psi actuator. I'll post the boost graph ASAP when I get it from WORKS along with the other dynos so you can see what's up.
Might be able to tune around it, need more money for more dyno time first Honestly it beats the base map by a long shot, just looks like we need more dyno time to fix the midrange.
As with any type of process control if 5 psi is your goal, you shouldn't be running an actuator that maxes out a 5 psi. How much is it to upgrade so your not running at the very limit of the spring?
I really don't want to seem rude or combative but I've got to add, .5 psi shouldn't make a 20 ftlb difference, should it?
Old 03-23-2013, 07:49 PM   #2343
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Maybe this is a dumb question but are you guys using boost control through ecutek, a MBC or running purely off the wastegate spring?
industrial is offline   Reply With Quote
Old 03-23-2013, 08:28 PM   #2344
dabocx
dabocx's Avatar
Drives: Scion FRS
So this is on stock exhaust with only the stage one kit out of the box? Pretty good numbers, hopefully you can get another actuator.
dabocx is offline   Reply With Quote
Old 03-23-2013, 10:32 PM   #2345
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Nameless exhaust
The Following User Says Thank You to Sportsguy83 For This Useful Post:
vubaru (03-25-2013)
Old 03-23-2013, 10:33 PM   #2346
Sportsguy83
Drives: Limited BRZ
My install is going pretty good. I hope to be complete by next weekend, Dyno numbers to follow!
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
civicdrivr (03-24-2013), Draco_PR23 (03-23-2013), Jeff86 (03-24-2013), vubaru (03-24-2013)
Old 03-23-2013, 10:57 PM   #2347
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Nice!!! Keep us posted (:
I really want a turbo kit lol
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Sportsguy83 (03-24-2013)
Old 03-24-2013, 01:35 AM   #2348
sw20kosh
Drives: 2013 Black FR-S
250 whp at 5-6 psi... Wowy. I hope you bump the boost up to 8-9 psi and get some dyno time! It wouldn't be too hard would it? Just need a map sensor and boost controller?
The Following User Says Thank You to sw20kosh For This Useful Post:
vubaru (03-25-2013)
Old 03-24-2013, 07:25 AM   #2349
Sportsguy83
Drives: Limited BRZ
Correct.
Old 03-24-2013, 10:33 AM   #2350
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Very exciting! I'd love to see pics as you install! *hint*
Jeff86 is offline   Reply With Quote
Old 03-24-2013, 10:39 AM   #2351
Sportsguy83
Drives: Limited BRZ
See signature
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Draco_PR23 (03-24-2013), Jeff86 (03-24-2013)
Old 03-24-2013, 10:47 AM   #2352
scraejtp
Drives: 2013 Subaru BRZ
Originally Posted by AVOturboworld View Post
The car was logged the entire time so we could track water and oil temps, along with a lot of other data we were keeping an eye on. Over the course of the day, the max water temperature we hit was 106° C, which dropped to 98°C when the heater turned on. Oil temperatures hit 140°C at max, which dropped to 135°C when the heater went on. In direct comparison, another BRZ being driven at the same time that was N/A and running a large oil cooler was hitting 117° C oil temperatures.
Needless to say, it was a fairly comprehensive thrashing of the car at the track. Yet at no time did the car overheat. One reason for that is that the oem radiator cap is 1.1-bar unit.
I would almost consider that oil temperature as overheating. I don't think many people were expecting overheating to the point of limp mode/not running.
That is way too hot, where were you measuring oil temperature?
scraejtp is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
