Old 03-21-2013, 03:51 PM   #211
Xdragonxb0i
Drives: ex500r
Okay so i bought Part #02606 (47mm-50mm) to delete the big resonator from advance auto
Do not buy this product, it is slightly to big, I say the hole is around 45mm. Long story short, it is too big and will crack the the airbox. After i cracked it i shaved the rubber piece with a dremel drill to make it smaller to fit.
Xdragonxb0i is offline   Reply With Quote
The Following User Says Thank You to Xdragonxb0i For This Useful Post:
Turdinator (03-21-2013)
Old 03-22-2013, 04:16 AM   #212
Kodename47
Kodename47's Avatar
Drives: UK GT86
I posted these earlier on:
Originally Posted by Kodename47 View Post
I also thought I'd add some measurements (in mm as I'm British ):
Main Resonator outlet:
Outer Diameter - 50mm
Inner Diameter - 46mm
Pipe Resonator:
OD - 30mm
Snorkel Resonator Connections (Both the same):
OD - 32mm
ID - 29mm
Basically if you want to cap them, use the OD. If you want to try and plug them then use the ID measurements.
.: Stealth 86 :.
Kodename 47 DJ:
johnnie (04-01-2013)
Old 03-22-2013, 01:03 PM   #213
zoomzoomers
zoomzoomers's Avatar
Have you guys seen any benefit from deleting those resonator boxes? Or is it just to clean up the engine bay?
Old 03-22-2013, 02:41 PM   #214
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Both intake noise & cleaning up the engine bay. Power is the same.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to Tim_Asphalt_FRS For This Useful Post:
ddevl_86 (03-31-2021), zoomzoomers (03-22-2013)
Old 04-01-2013, 05:02 AM   #215
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is everyone happy that theirs still feels good? Whilst I've proven on the dyno that power isn't any worse I sometimes feel at low RPM partial to full throttle isn't as reactive as it once was. This could be due to my testing with the holes all open and the trims all going out on the ECU but part of me thinks that the main resonator may have been there for that reason. After all it is making the air box roughly 15% larger in volume. Anyone got thoughts on that?
I'm waiting on a map update from Litchfield and then I'll see what I think, but seeing as it's not hard to put back on or remove again I may try it back in.
Apart from that, I'm still happy with it. Car is running well and the induction noise is awesome, especially with the resonator in the pipe blocked.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-01-2013, 07:04 AM   #216
vtmike
vtmike's Avatar
Drives: Scion FR-S
Did you do a pre and post dyno? You would think as large as the opening left for the main resonator you would be pulling in a lot more hot air and making less power. It's been proven with removing the snorkel.
Sent from my Nexus 7 using Tapatalk HD
vtmike is offline   Reply With Quote
Old 04-01-2013, 09:03 AM   #217
maj75
Drives: Blue FRS 6sp, 95 M3
Originally Posted by sierra View Post
Makes you wonder why they went to the trouble of working out the volumes, making and fitting them? They just clutter the engine bay up with cheap plastic.
Perhaps they engineered these first and decided to try the sound tube option later, liked it and didn't want to mess with the result by deleting the resonators?
You really are too much, could you please clutter up this thread with more uninformed crap
The resonators are to quiet external noise. Yes, they are carefully designed, but they are not designed to maximize performance. The resonators are designed to meet the external noise to the levels required by the EU. The EU has very strict noise levels and great effort is required by auto manufacturers to comply. The best that could be said for the resonators is that they are designed to minimize the loss of power due to the efforts to quiet the intake.
Toyota felt the sound tube was needed because the external intake noise had been made so quiet that enthusiast drivers would not appreciate the driving experience. They added the sound tube in an effort to get intake noise into the cabin where it could be heard by the driver and not heard by the external mics of EU testing equipment.
You are welcome. :happy0180:
maj75 is offline   Reply With Quote
The Following User Says Thank You to maj75 For This Useful Post:
Old 04-01-2013, 09:38 AM   #218
tennisfreak
Drives: 2018 BMW M240i
According to this: http://www.ehow.com/info_12156112_ai...onator-do.html
Resonator boxes serve a real purpose and can have a negative impact if you remove them.
Not sure I want to get rid of mine for no reason.
The Following 5 Users Say Thank You to tennisfreak For This Useful Post:
Black Tire (04-27-2013), ddevl_86 (03-31-2021), Kodename47 (04-01-2013), sierra (04-01-2013), stevesnj (11-04-2015)
Old 04-01-2013, 09:43 AM   #219
sierra
Drives: Skoda Yeti DSG diesel 4x4
Good to see you making an effort instead of the usual one liners but perhaps a little harsh?
sierra is offline   Reply With Quote
Old 04-01-2013, 01:52 PM   #220
Kodename47
Kodename47's Avatar
Drives: UK GT86
No pre-dyno but I organized a dyno day for local owners and on my standard map my power was in line with what I would expect. I may speak to my dyno guy and run some tests. I doubt that the power differences would even be noticeable tbh.
BTW, I'm not running with an holes open to engine heat, my pics are a couple of pages back in this thread, so the main resonator hole is blanked off. I'm just wondering if it's worth putting the main resonator back in to see if it cures it. I'm not on about a loss of power, its more a case of c.2k RPM going from part to full throttle it doesn't seem to pick up like I remember. Maybe its just me....?
Tennis freak, that link has a good point which I was/am aware of and why I asked what others think. I'm the kind of person that will try and test a theory. There is a nice improvement in sound with my setup and it makes good power. Is it better than with the full stock resonators in place, maybe I should prove it?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-01-2013, 02:02 PM   #221
vtmike
vtmike's Avatar
Drives: Scion FR-S
Tennis freak, that link has a good point which I was/am aware of and why I asked what others think. I'm the kind of person that will try and test a theory. There is a nice improvement in sound with my setup and it makes good power. Is it better than with the full stock resonators in place, maybe I should prove it.
Oh ok, I got confused with the holes open comment. There was someone talking earlier about running with it open and having an extra orifice increasing the flow area. Seemed like a bad idea to me.
Sent from my Galaxy Nexus using Tapatalk 2
Old 04-01-2013, 02:28 PM   #222
Craig
Craig's Avatar
Drives: Asphalt FRS
Almost done with my snorkel design. Gonna have a prototype done in a few weeks, heading to a dyno if all works out during weekend of April 20th or 27th. I'm excited to say it will fall under $125 as far as end user cost is concerned.
Craig is offline   Reply With Quote
Old 04-01-2013, 02:42 PM   #223
Kodename47
Kodename47's Avatar
Drives: UK GT86
Air will take the path with least resistance, so I'd assume that the air box would get more air from that hole than the snorkel meaning higher IATs but without any real benefit except for induction noise.
Mine was driven with a few different configs while I waited for the delivery of the parts to finish the install and I data logged etc. My current setup is no resonators what-so-ever, all holes smoothed off but with the noise pipe still in place. I might dyno test with/without main resonator and the "bulb" one under the intake pipe. My dyno guy is away at the moment and I'll wait until my updated flash arrives. I'd bet the difference is so minimal though.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-01-2013, 03:14 PM   #224
vtmike
vtmike's Avatar
Drives: Scion FR-S
Nice, I'm hoping to dyno my car soon. I have the perrin inlet hose, drop in filter, nameless downpipe, and axleback. Thinking about seeing if I can increase the seal between the air box and snorkel. Seems to be some room for improvement there. You have any pics of your snorkel?
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Length of stock resonator? jm1681 Engine, Exhaust, Transmission 5 10-26-2012 07:25 AM
WTB Stock OEM Airbox/snorkel brichard0625 Engine, Exhaust, Bolt-Ons 1 10-20-2012 09:21 AM
WTB: Stock AirBox SkullWorks Engine, Exhaust, Bolt-Ons 1 08-15-2012 09:09 AM
