Old 03-19-2013, 03:56 PM   #1
FullBlown
FullBlown's Avatar
Drives: Scion FRS
FBM 8.8 IRS Rear Diff Conversion
We designed a conversion kit to put a ford 8.8 IRS into the FRS/BRZ. This is the same setup we used in many fast S2000's around the world.
We chose this option again, because there are tons of gear rations to Pick from.
Our kit will come complete with Driveshaft shop axles, drive shaft, studs, hubs, the whole works.
Pricing TBA
[URL=http://s124.photobucket.com/user/fullblown2k/media/88_zps8606691c.jpg.html]
FullBlown is offline   Reply With Quote
The Following 17 Users Say Thank You to FullBlown For This Useful Post:
cf6mech (05-23-2013), civicdrivr (03-21-2013), Creole (05-01-2014), Deepseadiver (05-10-2013), Drift&Drag (04-30-2014), illmatic (05-10-2013), jstans84 (06-09-2013), KAB-FRS (01-26-2014), Kakawate (01-22-2014), No Limit Motorsport (03-19-2013), NorCalRider (03-20-2013), sandman126 (03-19-2013), SirBrass (05-05-2015), SnapOv3st3r (03-19-2013), srt4_night_rider (03-20-2013), tech4pdx (03-21-2013), zoomzoomers (03-20-2013)
Old 03-19-2013, 03:57 PM   #2
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
how much heavier it it? i know it probably doesnt matter since most people buying this are pushing like 55psi with one gazillion horsepower, but just wondering
Silverdub is offline   Reply With Quote
Old 03-19-2013, 04:01 PM   #3
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I'll get the final weight difference, a little extra weight on the rear tires is a good thing
The Following 5 Users Say Thank You to FullBlown For This Useful Post:
campy (03-19-2013), jstans84 (06-09-2013), Murseman27 (03-19-2013), NorCalRider (03-20-2013), Silverdub (03-20-2013)
Old 03-19-2013, 04:02 PM   #4
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Can't wait to test it!
Pure Automotive is offline   Reply With Quote
Old 03-19-2013, 04:18 PM   #5
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Holy shit you guys do everything.
Tansey86 is offline   Reply With Quote
Old 03-19-2013, 04:30 PM   #6
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
WOW full-blown are dominating !
i also assume you're another step closer to running that frs into 9's
Old 03-19-2013, 04:44 PM   #7
Dipstik-sportech
Dipstik-sportech's Avatar
You guys are really making it hard for me to save any money for a house lol. Props to you guys for releasing so many top quality parts so fast for these cars.
Old 03-19-2013, 04:47 PM   #8
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Seriously! Are you guys building a Pro Street FR-S?
Between your dyno numbers and this rear-end integration, I'm starting to think you are building with a purpose in mind! Sub-10 second FR-S maybe?
Scott
naikaidriver is offline   Reply With Quote
Old 03-19-2013, 05:03 PM   #9
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Scott
Not sure what we are doing yet
LOL, we want to go out and have some fun this year.
Old 03-19-2013, 05:26 PM   #10
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
You missed a bolt...
The Following 4 Users Say Thank You to Draco-REX For This Useful Post:
*KID* (03-19-2013), jstans84 (06-09-2013), Murseman27 (03-19-2013), usptwins (05-10-2013)
Old 03-19-2013, 05:33 PM   #11
FullBlown
FullBlown's Avatar
Drives: Scion FRS
LOL, yes it was just for mock up.
Old 03-19-2013, 05:36 PM   #12
Calum
That Guy
Drives: 2013 asphalt FRS MT
Does this mean you've found a need for this part? Yes, I'm asking if you blew up the stocker.
Old 03-19-2013, 05:58 PM   #13
Pete
Pete's Avatar
Drives: 22 BRZ
They seriously are not F***ing around. I love these guys. They regularly give me something to bore my co-workers with. (co-workers are not car people)
Pete is offline   Reply With Quote
The Following 2 Users Say Thank You to Pete For This Useful Post:
usptwins (05-10-2013), zohare (03-19-2013)
Old 03-19-2013, 05:59 PM   #14
FullBlown
FullBlown's Avatar
Drives: Scion FRS
No, but the stubs going into the diff will only allow for a certain diameter axle. Also the ring and pinion is pretty small.
However, we did find tons of shavings every time we tore the cover off the OEM diff. The stock unit probably would of lasted, but we did not want to invest a ton of money in to the axles, drive shaft ect.. just to find out if it will break.
The main advantage to this swap is the gear ratio options . All of which are under $200 a set.
3.08:1
3.27:1
3.55:1
3.73:1
3.90:1
4.10:1
4.30:1
The Following 6 Users Say Thank You to FullBlown For This Useful Post:
buditjoenawan (03-19-2013), Calum (03-19-2013), cobrabyte (03-20-2013), Pete (03-19-2013), SirBrass (05-05-2015), Wes B. (03-20-2013)
Video and short review on the Cusco Engine Mounts and Rear Diff Brace RallySport Direct Engine, Exhaust, Transmission 24 07-23-2018 03:43 AM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 10:23 PM
T1R Rear Diff colars ! AJ PwR Engine, Exhaust, Transmission 0 10-09-2012 10:00 PM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 03:28 PM
