Old 03-19-2013, 03:54 PM   #127
zoomzoomers
zoomzoomers's Avatar
Originally Posted by 2forme View Post
I dynoed it, as well as did air temp testing.
2-3whp difference, consistent.
So your saying that there's added benefit with the snorkel off or on?
Old 03-19-2013, 03:54 PM   #128
2forme
Originally Posted by zoomzoomers View Post
I was actually thinking of getting a pair of stockings and just blocking off the throttle body like we did in the 80's.
Pics or it didn't happen
I'm sorry, 2-3 gained by taking it off.
The Following User Says Thank You to 2forme For This Useful Post:
zoomzoomers (03-19-2013)
Old 03-19-2013, 03:59 PM   #129
zoomzoomers
Unfortunately, I don't know if I have any pics of it. It was way before the digi cam era. All the guys with the hot rod v8's were doing it, so we figured it couldn't hurt. Plus we didn't know any better. I used to run around town in my brother 86' Acura Inegra with the intake tube disconnected because it sounded mean and we thought it felt faster. BTW, that car ran like a champ no matter what dumb sh1t my friends and I did to it.
The Following User Says Thank You to zoomzoomers For This Useful Post:
2forme (03-19-2013)
Old 03-19-2013, 04:01 PM   #130
zoomzoomers
That's it then. You helped me make my mind up. So I'm going to go back to the stock air box with the AVO inlet tube + drop-in filter and leave the snorkel off. I've been wanting to try going back to stock, but have been avoiding it, but now I have no excuse. Plus, I've really been wanting to test if the Airaid intake is the root of my low gas milage. I guess we will now see.
Old 03-19-2013, 04:04 PM   #131
2forme
Make sure you post your results.
Old 03-19-2013, 04:06 PM   #132
zoomzoomers
I don't have any fancy data capture measuring tools like some of you guys have, but I'll certainly post up my butt dyno results. LOL
Old 03-19-2013, 04:10 PM   #133
2forme
Is your butt dyno calibrated like a mustang or dynojet? Don't forget MPG.
Old 03-19-2013, 04:11 PM   #134
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Lol!
Those were the days when if someone asked me if I changed out my intake, my answer would be something along the lines of;
"Seriously? Do you NOT notice that big chunk of Edelbrock-stamped aluminum sitting on top of the engine block where there used to be a big chunk of iron?"
Those were the days when us "tuners" used vacuum gauges and digital RPM meters to tune AFRs. Also we used feeler gauges, distributor weights, springs and timing lights to set ignition curves!
I miss feeling like I knew what I was doing with cars!
Scott
naikaidriver is offline   Reply With Quote
Old 03-19-2013, 04:13 PM   #135
naikaidriver
Just so we're clear... there's no need to post a picture of that dyno result!
Scott
The Following User Says Thank You to naikaidriver For This Useful Post:
2forme (03-19-2013)
Old 03-19-2013, 04:19 PM   #136
zoomzoomers
Not really sure how to calibrate my butt dyno, but I'll make sure to eat a solid meal before. LOL
Originally Posted by naikaidriver View Post
Lol!
Scott
Back then, my buddies and I were removing the springs from the strut/shocks and cutting the springs to lower the cars in our back yard. We had to stop doing that when one of my friends broke his arm in 3 places. See, we didn't have spring compressors, we actually didn't have any tools other than the garden variety house tools, and we would loosen the bolts on the strut/shocks and them release the spring to a 2 foot high brick wall on my front lawn. Worked great for like the first 20 times until one spring went wild and hit my friend and broke his arm. LMAO
Ahh those were the days.
Scott
Point taken! LOL
2forme (03-19-2013)
Old 03-19-2013, 06:06 PM   #137
Kodename47
Kodename47's Avatar
Drives: UK GT86
Surely that's enough to be caused by variance?
Here's my MAF readings that I did:
Green is OEM
Blue is no snorkel
Red is dyno run with all resonators removed but blocked up (5th gear run)
I can't see how less airflow = more power, unless the MAF reading is thrown out enough to make it run unintentionally leaner. The IATs though without the snorkel was enough to make me never want to run like that. It was ok for 10-15 mins but once the car was warm it ran so poorly. From my experience you'll gain those 1/2 hp for 10 mins then spend the rest of the time losing more!
Here's my temperature/MAF thread. Temperature in deg. C on the right BTW.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-19-2013, 08:13 PM   #138
2forme
Green is OEM
Blue is no snorkel
Here is a dyno. I did 3 runs without the snorkel, and this was the middle one compared to with snorkel. Notice the AFR and peak numbers.
Old 03-19-2013, 10:48 PM   #139
Turdinator
Señor Member
Turdinator's Avatar
In regards too the snorkel being a restriction this was posted in another thread...
Originally Posted by Martin Donnon View Post
Our Maxspeed is in the air on the way to us to use on our WR86 development car. Data from the dyno shows a 2kpa pressure drop in the inlet system from around 5800rpm falling away until 8000rpm. If this duct relieves that restriction then it will be worth a few horsepower in stationery (dyno) testing, and possibly a little more at 80mph plus. Time will tell
Its a simple fact. Log the manifold pressure of your 86/BRZ in a full throttle pull and you will see that with the stock airbox/snorkel there is a pressure drop (negative boost) in the intake of around 0.1psi. Remove that without some nasty hot air induction system under the hood, and hey-presto you have your gains!
This is nothing new in tuning/modifying cars. Maxspeed should do the job nicely.
Maxspeed racing inlet duct fitted and tested. Pressure drop is halved. Dyno gains - measured properly, not sales orientated Disney Dynoing, shows around 3rwhp over the factory snorkel. Zero driveability issues. Its a good thing
Forum member is an Aussie race team that are making around the 200hp at the wheels on their own setup.
Quotes are from this thread LINK
1974 TA22 Celica
2013 86 GT
Old 03-20-2013, 01:35 AM   #140
zoomzoomers
Ok guys English please... I'm now more confused then ever.
Can you guys just spot it out in plain ebonics?
Yes my sizzle my nizzle on the snorkel? Or no my nizzle my bizzle?
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
