#127 |
Drives: 2013 Asphalt Scion FR-S
Ok so I got the harness in finally. The relay has a direct battery fused power lead(30), 87 has the fog light power lead going from relay to h11 sockets,86 has the ground from the fog lights to it and a ground for the relay(so it is the ground for the relay and also grounds fog lights), and the last port 85 has the button wire. The button has two wires which are combined into one that connects to the wire coming from relay 85(so 85 is the button on the relay),then there is a red wire with no fuse that ties into a power source such as the battery, and lastly there is a ground wire for the button.
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
#128 | |
Drives: Toyota 86
#129 |
So I could tie the white wire into the ground correct?
#130 |
Drives: Toyota 86
Google "BRZ Wiring Diagram". You will see that a lot of the systems (headlights, tail lights, horn, etc) are set up like that (Negative trigger). Power will not be "running" to the relay if the circuit is not complete. After reading the wiring diagram, you should have a better understanding.
#131 |
Drives: Toyota 86
#132 |
So I should tie the white wire to the switch wire running to the relay because there is no power there until I press the button
#133 |
Drives: Toyota 86
#134 |
Drives: pinto power
#135 |
I finally had time to configure the relay diagram showing exactly how the harness i ordered is setup.
#136 | |
Drives: Toyota 86
You're feeding ground to both ends of the coilI'm assuming your switch is a positive trigger. You can add a second relay to convert that trigger wire to negative. 85 and 30 to ground 86 to the trigger wire on the first relay 87 to the white wire pin 24 |
#137 | |
Drives: Asphalt FR-S
He isn't using the stalk switch so I don't see why this won't work. I'm just basing this on the other diagrams that the pin out of the relay is correct. The ground in his switch is for switch illumination. He is using a positive trigger not a negative trigger.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 |
#138 | |
Drives: Toyota 86
#139 | |
Asphalt FR-S
#140 |
The 12v dash illumination wire will actually be to a power source such as ignition switch. this is a positive output relay because terminal 87 the output terminal is the red or power wire to the fogs and is powered from direct battery current. The reason the ground from the fogs goes to the terminal is because rather than the fogs be grounded individually, they are grounded via the relay. Yes this is a positive trigger setup.
Note: I bought this harness, i did not make it and how the switch is internally wired may not look exactly like this diagram i got off the internet and edited to my setup.
| Who here has LEDs in their fogs/DRLs in their GT? | RZ86 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-30-2013 10:54 PM |
| Fogs wiring; Will this work? | Khánh | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-16-2013 12:44 PM |
| BRZ HID Bulb + HID Fogs | delusional | DIY (Do-It-Yourself) Guides | 4 | 02-05-2013 05:09 AM |
| new Camry fogs fit the frs?? | hislargeness | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-26-2012 03:20 AM |
| for everyone thinking of using rear fogs | xpicer | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 07-04-2012 12:53 AM |
