Old 02-27-2013, 06:32 PM   #15
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I like the copper. Red is overused.
QFMFT!
Old 02-27-2013, 07:26 PM   #16
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Originally Posted by Ruckus View Post
Im thinking of running the baer pro+ as well. what size wheel/offsets are those rotas? Im trying to see whats the minimum offset I can run with 17x9 and this BBK.
I run the 18x8.5 +44 fronts and 18x9.5 +44 rears. I took the wheels up to Baer and we test fit the Pro+ on the smaller of the two and there is a TON of clearance as a result of the concave of these wheels. The rears are even more clearance.
I have a set of 5Ziegen FN01R-Cs that are 17x7 or maybe 8s.... with a +38 offset that I do not believe will fit the Pro+. Sorta bummed out if they don't but you can't have everything. I can let you know next week though if they do
AZFA20 is offline   Reply With Quote
Old 02-27-2013, 07:45 PM   #17
BlaineWasHere
Grip>Drift
Drives: FRS
Depends on the wheels but 17X9 et 35 has been somewhat BBK friendly depending on the wheel and brake kit.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
Ruckus (02-27-2013)
Old 02-27-2013, 08:24 PM   #18
AZFA20
AZFA20's Avatar
I know my other car that also has a Baer BBK was always a challenge to find 17" wheels that fit. My 5zigens would only fit my other setup if I used a 6mm spacer on the fronts. I have a set of Konig Daylites 17x7 that fit without issue but they are on the older 4 piston PBR calipers Baer use to use and 13" 2-piece rotors.
The Following User Says Thank You to AZFA20 For This Useful Post:
Ruckus (02-27-2013)
Old 02-27-2013, 08:34 PM   #19
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
how long will they stay looking like that?
Jesse@JDLAutodesign is offline   Reply With Quote
Old 02-27-2013, 08:49 PM   #20
AZFA20
AZFA20's Avatar
These two colors hold up pretty well to track temps as mentioned in my first post. If this were a dedicated track car I would opt for their raw coating. Depending how hot you get em though it will basically discolor anything.
Old 03-18-2013, 03:21 PM   #21
jadewbj
jadewbj's Avatar
The copper is nice.
jadewbj is offline   Reply With Quote
GRB Brembo caliper on BRZ RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 11-15-2016 02:50 PM
DIY - Caliper removal and paint olorin DIY (Do-It-Yourself) Guides 9 04-04-2014 10:12 AM
MGP caliper Covers USMC -FRS Cosmetic Modification (Interior/Exterior/Lighting) 9 02-06-2013 10:15 PM
Would you get these?...Caliper covers mckobus Cosmetic Modification (Interior/Exterior/Lighting) 35 01-28-2013 09:27 PM
Color Opinions chipz91 Scion FR-S / Toyota 86 GT86 General Forum 25 07-30-2012 06:27 PM
