Automotive Connoisseur
Drives: too many cars
BBK Caliper color opinions
My calipers are being powder coated tomorrow by Baer and I was pretty well set on the fire red translucent calipers but last minute has me thinking the translucent Arizona copper color may be the better choice. I was hoping I could get some feedback from you guys to help me determine which color I should go with. They both look amazing in person and they both hold up very well to track temps. The red is my favorite but it may be too much "pop" for my car. The red is insane in the sun. I have a whiteout FR-S and the Wheels are Rota RT-5s in Hyper black. I have put both calipers behind the wheels in both colors and at the time I thought the red was the choice but after thinking about it I am stuck because I personally like them both a lot....... I have the opportunity to change my mind to copper but I need to know asap.
![]() ![]() or ![]() ![]() My wheels from wheeldude
Drives: WRB BRZ
have you thought about going a green/blue color? You really have a plethora of choies to do with a white car.
id do some photo searching and see what colors you like. ![]()
I have considered doing something totally off the wall but I am trying to stick with a clean look. Mature if you will..... I love the wild colors but I am not sure its the direction I plan to go long term.
I would go with the Red! Love it!
Drives: Attitude
Search for pictures of a white STI with black wheels; that will give you a better understanding of how your car will look with gold calipers and black wheels.
Site Moderator
Drives: Stuff
I like the copper. Red is overused.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
Keep in mind this is not a normal red. It almost glows in the sun. They call it fire red and it really does take on that appearance. I have looked at tons of white STIs, EVOs, and 350Zs since they seem to have a lot of the gold calipers and I like em but they are not like this copper that Baer uses so its tough to compare. The pictures I put up just don't do either color justice. They are very unique looking in person. They both look like anodizing but with a clear coat so they look deep in color. They use a translucent powder coat.
Here is a close up of the red:
Drives: Whiteout FR-S
That red looks pretty sick, goes with the red trim inside the car also. The copper looks good too and may keep its color a little better long term.
I like Project Mu Teal but probably not the look you are going after |
#9 | |
Site Moderator
Drives: Stuff
It's still red though, just a fancy red. At a quick glance it's red no matter what
-Dave
#10 |
Drives: Attitude
#11 |
#12 |
Drives: SSM LT MT BRZ
the first picture in this post is bothering me,
It appears that they installed aluminum sleeves in the piston bores and then final machined the pad pocket (albeit with really bad speed/feed data producing alot of chatter) EDIT: on second thought the piston bore looks like it was simply masked before (whatever) plating process. is this really how they finish their brakes? that is quite scary if that is the case. Furthermore, that is not powdercoat...if it was powdercoat it would atleast cover all the shoddy machine work. |
#13 | |
They do offer regular old non transparent powder coating which does look smooth as butter |
#14 |
Drives: Firestorm FR-S
Im thinking of running the baer pro+ as well. what size wheel/offsets are those rotas? Im trying to see whats the minimum offset I can run with 17x9 and this BBK.
| GRB Brembo caliper on BRZ | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 66 | 11-15-2016 02:50 PM |
| DIY - Caliper removal and paint | olorin | DIY (Do-It-Yourself) Guides | 9 | 04-04-2014 10:12 AM |
| MGP caliper Covers | USMC -FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 02-06-2013 10:15 PM |
| Would you get these?...Caliper covers | mckobus | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 01-28-2013 09:27 PM |
| Color Opinions | chipz91 | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 07-30-2012 06:27 PM |
