Old 03-16-2013, 10:19 PM   #183
Blue86
Drives: Sonic Blue 86GT Manual
Awesome work
Blue86 is offline   Reply With Quote
Old 03-16-2013, 10:26 PM   #184
juanmedina
Drives: WRX
So, you why do you want anything more than 604 whp 400+ wtq??
I think at this point, its good that they are starting to explore upgraded components. I don't know what else more you expect out of the stock engine. Yes, it may make more power... but after 600+, you can expect the engine not to last very much.... Might as well start testing for upgrades.
why not?
juanmedina is offline   Reply With Quote
Old 03-16-2013, 10:28 PM   #185
juanmedina
Drives: WRX
Originally Posted by FullBlown View Post
We are in the process of doing a intake manifold for a S2000, so we are aware of what is involved with the whole process. Making a intake manifold is not as easy as it sounds. A sheet metal Intake manifold would be painful to produce in mass quantity. Therefor, it would need to be done by casting, and casting a manifold takes a lot of time and money.
The bottom end on these motor are pretty solid so far. Subaru made it really easy to work on these cars. Although the goal with our car is to push it to the limits and see how far we can go. The main goal that we are trying to achieve is a stock motor that can carry power to atleast 9k.
Maybe is a good idea to start working on the cast intake manifold. The new WRX will be out soon and they should be really similar. The market will be huge .
I am sorry if I sounded abrasive I am just excited about this engine.
Old 03-17-2013, 03:55 AM   #186
phatpanda
phatpanda's Avatar
Drives: Scion FR-S
Stock internals?
phatpanda is offline   Reply With Quote
Old 03-17-2013, 04:57 AM   #187
Sonolin
This car is still alive?
I'm amazed already, haha. Awesome numbers.
Sonolin is offline   Reply With Quote
Old 03-17-2013, 05:07 AM   #188
cf6mech
Drives: FRS Silver LS1 swapped.
A cast intake has already been started by someone else.
cf6mech is offline   Reply With Quote
Old 03-17-2013, 05:13 AM   #189
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by ft_sjo View Post
Probably those who want more than a 2000rpm powerband.
for those 2000rpm or less.... I'm free.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
Sportsguy83 (03-17-2013)
Old 03-17-2013, 08:48 AM   #190
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Our car currently is still on the stock motor and will stay that way until something fails.
Originally Posted by phatpanda View Post
Stock internals?
From the OP.... Was it that hard to read at least the OP?
Old 03-18-2013, 10:50 PM   #191
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
We want to rip it apart to see if the are any signs of wear and tear, but I think we will just run it till it gives up.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 03-18-2013, 10:53 PM   #192
OrbitalEllipses
Drives: Attitude
I'd be more interested in wear and tear than a blown engine, that seems like more useful data.
Old 03-19-2013, 06:49 AM   #193
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
We have a engine on the stand ready to go and we will be testing our cnc ported head with cams in a month.
The heads will be flowed before and after,then tested in the car.
FB yall could just use a 3D scanner to make a plastic copy of the intake manifold then make a cast for a metal replacement, i am also worried about the intake manifold going at this rate, that alone could kill the engine without and internals actually failing
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following User Says Thank You to carbonBLUE For This Useful Post:
Murseman27 (04-04-2013)
Old 03-19-2013, 07:44 AM   #194
RWD-boxer
RWD-boxer's Avatar
Drives: Black
O load Jesus there's a fire
Thenittis.com
RWD-boxer is offline   Reply With Quote
The Following User Says Thank You to RWD-boxer For This Useful Post:
Floggin Tires (03-19-2013)
Old 03-19-2013, 08:14 AM   #195
ft_sjo
Drives: GT86
You do realise that air flows inside the manifold and not around the outside, right?
Old 03-19-2013, 10:28 AM   #196
mact
Drives: 13 GTI
I doubt the plastic intake manifold is going to explode, crack, or leak.
mact is offline   Reply With Quote
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 03:41 PM
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Forced Induction 234 09-24-2015 05:45 PM
AVO Turbo Kit Stage 2 - work in progress AVOturboworld Forced Induction 202 06-18-2013 01:35 PM
P&L Motorsports Stage 1 Turbo Kit Review (In Progress) Supermassive Forced Induction 66 02-07-2013 02:30 PM
