| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#925 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
No one?
#926 | |
Drives: 2003 Subaru Outback
| The Following User Says Thank You to Tansey86 For This Useful Post: | -DK- (03-10-2013) |
#927 |
No one?
#928 |
Drives: 2013 Whiteout FRS
Will I run into any problems with a set of ENKEI RS7 17x7 +35 using the stock michelins? Wheels will be shipped with nuts and rings.
#929 |
Drives: Raven Scion FR-S
That should look perfect IMO , stock is 17x7.5 +48 so with that offset the wheels will be closer to flush , you will be happy
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
| The Following User Says Thank You to ScionFR-S For This Useful Post: | m.box.design (03-10-2013) |
#930 |
Drives: Gray.
Will this fit? If not what do I need.
Size: 17x8" Offset: +53 Bolt pattern: 5x100 |
#931 |
Drives: Your sister
#932 |
Drives: 2003 Toyota Celica GT-S
hey guys, i'm a soon to be owner of what im hoping to be either a white or red FR-S this week. I'm coming from a 7th gen Celica Gt-s currently with CCW Classics 17x8.5 +19 offset. Will the +19 offset require some work to fit on the FR-S? ANy suggestions on tires are appreciated as well. Right now i'm running 225/45/17 square on my celica.
thanks, Chris Last edited by CrizRN-86; 03-11-2013 at 06:28 PM. |
#933 | |
Drives: FR-S Firestorm 6MT
In your case, even with extra camber, not sure it'll fit. Maybe someone withe experience with a +20 fitment can chime in. |
#934 |
Reposting from another thread as it is pretty relevant here:
I received my wheels and test-fitted them last night. These are PhatFux Ballzy in 18x9 +35. No tires selected yet as I wanted to check fitment first. I'm currently running stock suspension and alignment (stock looks to be close to 0 camber compressed), but these wheels stick out alot, about 1". It's obviously accentuated more since there's no tire on to give the full effect and it doesn't take into account suspension travel and arc. I know a drop will pull it in a bit as well as some camber, but will it be enough? |
#936 |
I appreciate the input Slick! I was figuring it would be a tough fit after doing some reading on the board. If anything, new wheels wouldn't be the worse thing.
![]() I'll still try them on just for the hell of it. Chris |
#937 |
Hello all
i have a thing here, i own a Work Emotion XC8, size 18 x 7.5 , et +42I want to install it using Sard PCD Changer (from 100 to 114.3), which is 15mm width. I am on stock suspension, no plan for a drop/any other suspension tunes (shocks, coilovers, etc) Is it possible that it will never rub the front and rear fender even under full load ? Or maybe hitting a high speed bump, holes, etc. Thank you for the answer
#938 | |
What size tire are you planning? |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
