Old 03-10-2013, 04:26 PM   #43
FT_Monk
Drives: Over the hill WRX
I wonder how much power the Vortech made before the parasitic drag losses. What I mean is how much power it takes to drive a supper charger like the Vortech? With a turbo, the propeller spins freely when the exhaust gases blows on it. An SC with all of its gearing and belt tension and oil drags and weights of the mechanical components must be taxing significant horsepower from the engine to spin the propeller. I like supper charging, just a curious question.
FT_Monk is offline   Reply With Quote
Old 03-10-2013, 05:01 PM   #44
Unleashed
Unleashed's Avatar
Drives: 13' WRX
I'm not too familiar with supper charging, I didn't know a late evening meal improved power. hahaha
Unleashed is offline   Reply With Quote
The Following User Says Thank You to Unleashed For This Useful Post:
racecaresuaceb (03-13-2013)
Old 03-10-2013, 07:24 PM   #45
FT_Monk
Dam ESL
Old 03-11-2013, 09:58 PM   #46
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I would like to add an update to this system. This has a lot to due, I believe with the tune so maybe John will chime in if he's following this thread.
The car has picked up some response over the last week. It now responds, Like I would had imagined it would. It also has a lot more power down low. This I think has to due with the advanced Timing map. It felt like the timing map was very conservative thats why the motor felt so lazy and restricted it now has much more power and a lot better response.
It actually has some real pull to it now when entering freeway on ramps ect.
jdzumwalt is offline   Reply With Quote
The Following 3 Users Say Thank You to jdzumwalt For This Useful Post:
Coheed (03-11-2013), Sonolin (03-12-2013), Sportsguy83 (03-11-2013)
Old 03-11-2013, 11:19 PM   #47
Visconti
Drives: 05 STi
I'm not really sure what you mean.
The log file you sent to me looks normal and I haven't made any revisions.
Sounds like the cams were OFF on the first drive
John
Visconti is offline   Reply With Quote
Old 03-12-2013, 12:19 AM   #48
jdzumwalt
Motor Sports slut
John
That may be about the cams, I really didn't look at the logs maybe I'll check the cam phasing verus now. The motor does feel more lively for one reason or another. Is this common with ECUTEK?
One other question what is the second map for on my map select?
Old 03-12-2013, 12:43 AM   #49
ahausheer
Re-member
Drives: Toyota camry
What is meant by ''the cams were off''. Is this an ECU learning thing?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 03-12-2013, 08:10 AM   #50
Pete
Pete's Avatar
Drives: 22 BRZ
That sounds like the same experience I had with Perrin's 93 tune, according to the ole butt dyno it picked up power for several days after the flash. That's also why I want to dyno this kit again sometime to see if it picked up power. I have definitely noticed the 'dead pedal' feel I get after any ECU flash is gone now.
Pete is offline   Reply With Quote
Wireless Charger (aka Inductive Charger) in the Scion FR-S PhastekSport Electronics | Audio | NAV | Infotainment 2 01-01-2013 04:46 PM
DIY - A Pillar USB Charger juny3 DIY (Do-It-Yourself) Guides 19 12-03-2012 01:38 PM
Turbo or Super Charger Ryan86 AFRICA 7 11-21-2012 08:14 AM
Frs dealer/port addons including SUPER CHARGER Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 83 05-08-2012 11:33 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
