CANADA Canada
Old 01-07-2013, 02:26 PM   #15
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
To the OP, I wouldn't worry too much. I started my FR-S a few times now at -20c and it's by far the easiest car I ever had to start with the stock 0w20 oil, it just spins like it's 20c. That synthetic oil works really well.
Another thing I noticed, is that even though we have very harsh and cold winter, where we get -20 celcius weather often during winter (-4 F), the cars here all easily last over 300 000 KM+...so I don't know where all the myths about cold engine starts comes from, maybe in theory, but in practice engines really are that tough...and cold starting engine in the cold even without block heater don't seem to have as much effect as we think on overall engine wear and longevity.
Rayme is offline   Reply With Quote
Old 03-10-2013, 03:51 PM   #16
Trobinson
Trobinson's Avatar
Drives: F150
Hi there, new member from northern Ontario, redlake. Used to live in Toronto and didnt know what block heaters were because... You don't need them! I don't plug my vehicle ( not an frs yet) in until its getting lower than minus 25 at night. When I forget at minus 45 I have to steal my girlfriends vehicle to get to work before she wakes. Synthetic oil, and letting the car run for not even a minute will be enough. Running for any longer is just gonna make it nicer to sit in. Engine will be fine.
Edit: ofcourse my battery has 850 cca.
Trobinson is offline   Reply With Quote
Old 03-11-2013, 10:07 AM   #17
wparsons
wparsons's Avatar
One thing to remember is that a block heater heats up the oil, but heat is provided by the coolant. Doesn't matter how hot the oil is, if the coolant is still at -5 the air in the cabin won't be warm.
flickr
Old 03-11-2013, 12:04 PM   #18
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
How does a block heater heat the oil?
A block heater heats the coolant as it is generally installed in a frost plug location which is where coolant flows. An inline block heater is installed in the coolant lines, but most factory units are installed in the frost plug location.
Slick is offline   Reply With Quote
**IMPORTANT** Sand in the engine block USMC FR-S Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2013 07:44 PM
Has anyone installed a block heater? empower-auto Scion FR-S / Toyota 86 GT86 General Forum 14 11-20-2012 04:21 PM
1st Oil Change & Block Heater JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 11-09-2012 11:20 AM
Seat heater temperature? milenko11 BRZ First-Gen (2012+) — General Topics 29 09-20-2012 01:19 PM
Engine Block # ichitaka05 Engine, Exhaust, Transmission 23 05-06-2012 05:33 PM
