Old 03-10-2013, 04:05 AM   #15
VoiD
Drives: 13 WRB BRZ
Originally Posted by GhostofAkina View Post
Do you guys recommend an alignment after installing the springs?
Yes
Sent from my GT-N7105 using Tapatalk 2
VoiD is offline   Reply With Quote
The Following User Says Thank You to VoiD For This Useful Post:
GhostofAkina (03-10-2013)
Old 03-10-2013, 06:52 AM   #16
GhostofAkina
Drives: 2013 Scion FR-S Raven
What do you guys think of Tein?
GhostofAkina is offline   Reply With Quote
Old 03-10-2013, 07:41 AM   #17
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I have the H Tech and they ride very nicely on the stock struts and shocks. I would stay away from the S Tech though.
Here's a nice list depending on your price range:
RCE Yellow: well reviewed and ideal for handling, only 20mm of drop though
Swift "BRZ spec" springs: reputable manufacturer with 25mm drop
Eibach Pro Kit: most common sets sold, only ones that come with bumpstop besides RCE
H&R Sport and Tein H Tech: both nice drops and comfortable ride
Hard to go wrong with any of the above just depends on what you are looking for.
Koni's are on sale this month also so even if you don't want to replace them right now you can get a good price on them and put them away for later when you need them.
Old 03-10-2013, 08:05 AM   #18
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Every thing Joeboxer said, springs figure $250-$300ish & up
shocks figure $800ish and up for cut n gut shocks from koni
thats already $1050-$1100 & up
if you can wait, IMHO nothing like a matched setup, clean non gutty or cutty for a few hundred more.. I'd be on this: nothing wrong with reusing the oe bumpstops or upper mounts for a DD, and the koni yellows are pretty good if you ask me, better than oe
http://www.ground-control-store.com/...ion.php?II=931
keep it simple and 'base'
if $1350 is over the budget cap, then I'd probably look at the eibach sport coils for a more lively character or like an rce yellow or hr sport for more grippyness outta a set of coils with oe dampers, tho I think the oe dampers work best with the oe coils,other setups work, but still feel a bit under shocked/over sprung to me
Huehuecoyotl is offline   Reply With Quote
Old 03-10-2013, 08:24 AM   #19
JoeBoxer
JoeBoxer's Avatar
Would love to try the GC street kit myself, the Tein street basis is probably what i will end up with though if i ever change mine out. I can get it for just a little more than the koni's alone.
Old 03-10-2013, 12:12 PM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
The problem with question like this is that there will be as many answers as there are posters.
My personal thoughts on the subject, if you're not racing, want to keep some ground clearance while keeping the front end off the bump stops, go with RCE yellows. I'm doing the same.
As for dampers, I've ran Koni's in the past and liked them a lot. But I'd rather something that's easier to rebuild and I have no need for adjustment. Personally I'm waiting for Bilstein to come out with a set and RCE to match them to their springs.
The Following User Says Thank You to Calum For This Useful Post:
Racecomp Engineering (03-10-2013)
Old 03-10-2013, 12:23 PM   #21
JoeBoxer
JoeBoxer's Avatar
The cut and gut is the main reason i haven't ordered the Koni's already, they are hard to pass up on sale though.
Old 03-10-2013, 12:44 PM   #22
Calum
That Guy
Agreed! But they should be on sale again this time next year.
Old 03-10-2013, 01:16 PM   #23
Captain Insano
Ditto, I want the Konis as well for my Eibach pro kit springs at some point. I am waiting though as car feels pretty darn good right now.
Captain Insano is offline   Reply With Quote
Old 03-11-2013, 02:37 AM   #24
GhostofAkina
Are S. Techs really that bad?
Old 03-11-2013, 08:09 AM   #25
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I went with the RCE Yellows coupled with their sway bars. 25mm hollow front and 19mm hollow rear. I didn't realize how much body roll the car does have until I did the sway bars. Very good setup at a good price.
kask2_6.0 is offline   Reply With Quote
The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post:
GhostofAkina (03-11-2013), Racecomp Engineering (03-11-2013)
Old 03-11-2013, 02:16 PM   #26
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I'm going this route as well, I went with Eibach Sportlines because I was looking for a decent drop.
I would stick with a manufacturer that includes new bumpstops.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
TRD Springs on std shocks? Panman AUSTRALIA 3 02-14-2013 03:59 PM
TRD JDM Springs on standard shocks? Panman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-08-2013 07:49 AM
Forget it... I'm doing springs and shocks... not coilovers... seven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-17-2013 12:31 AM
Coil springs on OEM shocks Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 01-04-2013 08:22 PM
Matching shocks with springs Ben_G Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 07-22-2012 10:32 PM
