Old 02-08-2013, 05:58 AM   #1
Panman
Panman's Avatar
Drives: 86 GTS
TRD JDM Springs on standard shocks?
Has anyone done this?
I know someone has done STI pinks on std shocks.
I await your counsel!
Panman is offline   Reply With Quote
Old 02-08-2013, 06:18 AM   #2
Juvenile
Juvenile's Avatar
Drives: 86 GTS
What would you like to know about them ? I don't have them, just asking
Old 02-08-2013, 06:41 AM   #3
Panman
Panman's Avatar
Drives: 86 GTS
I'd like to know if anyone has used the JDM TRD springs (Part Number MS250-18001) with the OEM shocks.
Someone else has used the STI Pink springs with the OEM shocks but I haven't seen anyone using these springs.
Reason for asking is I'm considering purchasing the springs standalone without the shocks.
Old 02-08-2013, 06:49 AM   #4
Juvenile
Juvenile's Avatar
Drives: 86 GTS
I think one of your fellow QLDers had a set then went to the TRD coilovers. I don't see an issue with them though. TRD coilovers and spring are both set at 15mm drop as TRD recommend.. I have yet to find what the spring rates on the ones you mentioned are..
Bit secretive according to other forum members.
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
TRD Springs on std shocks? Panman AUSTRALIA 3 02-14-2013 02:59 PM
Forget it... I'm doing springs and shocks... not coilovers... seven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-16-2013 11:31 PM
Coil springs on OEM shocks Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 01-04-2013 07:22 PM
Matching shocks with springs Ben_G Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 07-22-2012 09:32 PM
