Old 03-09-2013, 07:40 PM   #925
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by whitefrs View Post
Is this a good setup
17x9 et 35
225/45/17 front Hankook rs3
245/40/17 rear Hankook rs3
Car will be turbo
No one?
Old 03-09-2013, 07:48 PM   #926
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by -DK- View Post
Hey all,
I'm planning to get gram light rays 57Extreme.
Front: 18x8.5 +30
Rear: 18x9.5 +40
What size tires would make an optimal fit? I'm thinking of getting Dunlop DZ101 with sizes 225/45/18 front and 245/40/18 rear. Would this make a good fit and no impact to speedo/handling?
If I were to drop it by 1", would there by anything I need to change?
Thanks for the help.
If you want those tires, buy more narrow wheels. If you are dead set on those wheels, 245/35F and 275/35R
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
-DK- (03-10-2013)
Old 03-09-2013, 08:43 PM   #927
Dipstik-sportech
Dipstik-sportech's Avatar
Originally Posted by Dipstik-sportech View Post
Rota grid 17x9 +35 front and rear with a 245/40-17 square setup
No one?
Old 03-10-2013, 01:05 AM   #928
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
Will I run into any problems with a set of ENKEI RS7 17x7 +35 using the stock michelins? Wheels will be shipped with nuts and rings.
Old 03-10-2013, 10:28 AM   #929
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
That should look perfect IMO , stock is 17x7.5 +48 so with that offset the wheels will be closer to flush , you will be happy
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
The Following User Says Thank You to ScionFR-S For This Useful Post:
m.box.design (03-10-2013)
Old 03-10-2013, 10:32 PM   #930
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
Will this fit? If not what do I need.
Offset: +53
Bolt pattern: 5x100
Old 03-11-2013, 01:52 PM   #931
yohan04
yohan04's Avatar
Drives: Your sister
No one?
I would run 245/40 and 255/40 if you're going turbo, you will need the extra grip.
No one?
You'll be fine. You can even fit 255/40 if you have negative camber in front and back without any rubbing.
yohan04 is offline   Reply With Quote
Old 03-11-2013, 04:19 PM   #932
CrizRN-86
Drives: 2003 Toyota Celica GT-S
hey guys, i'm a soon to be owner of what im hoping to be either a white or red FR-S this week. I'm coming from a 7th gen Celica Gt-s currently with CCW Classics 17x8.5 +19 offset. Will the +19 offset require some work to fit on the FR-S? ANy suggestions on tires are appreciated as well. Right now i'm running 225/45/17 square on my celica.
thanks,
Chris
CrizRN-86 is offline   Reply With Quote
Old 03-12-2013, 09:29 AM   #933
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
thanks,
Chris
I don't think you'll get a +19 offset to work. I just received my 18x9 +35 wheels and they already stick out almost 1" past the fenders. I'll need some lowering and camber to bring that back into spec.
In your case, even with extra camber, not sure it'll fit.
Maybe someone withe experience with a +20 fitment can chime in.
Slick is offline   Reply With Quote
Old 03-12-2013, 11:45 AM   #934
Slick
Slick's Avatar
Reposting from another thread as it is pretty relevant here:
I received my wheels and test-fitted them last night.
These are PhatFux Ballzy in 18x9 +35. No tires selected yet as I wanted to check fitment first.
I'm currently running stock suspension and alignment (stock looks to be close to 0 camber compressed), but these wheels stick out alot, about 1". It's obviously accentuated more since there's no tire on to give the full effect and it doesn't take into account suspension travel and arc.
I know a drop will pull it in a bit as well as some camber, but will it be enough?
Old 03-12-2013, 07:55 PM   #935
HATED1
HATED1's Avatar
Drives: 86
will 17x9 +35 fit dropped on eibach sportlines?
HATED1 is offline   Reply With Quote
Old 03-12-2013, 08:05 PM   #936
CrizRN-86
I appreciate the input Slick! I was figuring it would be a tough fit after doing some reading on the board. If anything, new wheels wouldn't be the worse thing.
I'll still try them on just for the hell of it.
Chris
Old 03-13-2013, 10:07 AM   #937
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
Hello all i have a thing here, i own a Work Emotion XC8, size 18 x 7.5 , et +42
I want to install it using Sard PCD Changer (from 100 to 114.3), which is 15mm width.
I am on stock suspension, no plan for a drop/any other suspension tunes (shocks, coilovers, etc)
Is it possible that it will never rub the front and rear fender even under full load ? Or maybe hitting a high speed bump, holes, etc.
Thank you for the answer
dokterdewe is offline   Reply With Quote
Old 03-13-2013, 10:35 AM   #938
Slick
Slick's Avatar
A 15mm spacer will effectively make it a +27 offset. It is going to be close but I think you should be inside the fender so slightly.
What size tire are you planning?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
