Old 03-06-2013, 01:15 AM   #1
Xdragonxb0i
Drives: ex500r
Questions about Nameless Front pipe with Helmholtz Resonator
for those of you who do have it, do you guys think its worth it? I want the performance gains but near stock level sounds. So i will get a high flow cat, is the resonator needed?
Xdragonxb0i is offline   Reply With Quote
Old 03-06-2013, 06:49 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, Worth it. I've heard both setups, and own with helmholtz. Get it especially sicne you are looking to keep it as similar to stock sound as possible. (That was my same goal)
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Alabang 86 (03-08-2013), kuhlka (12-14-2013)
Old 03-06-2013, 07:53 AM   #3
FR-S Matt
I'm still in question about the Helmholtz as well. I ordered the centered version of the Axleback but I'm not sure if it is coming that way or offset. I do plan on getting a header so that alone might be worth getting the helmholtz for.
Actually, scratch that. If I go the UEL route, I probably won't get one because racecar.
Old 03-06-2013, 10:27 AM   #4
mad_sb
Drives: 2013 Asphalt FR-S
I just installed mine with Helmholtz... I also got it with because i plan to do the header as well. I also just ordered the new 3" inlet dual 5"X8" axle back. Honestly, with the stock axleback the only time it is even noticeably louder than stock is on cold start. After the idle kicks down you can't even tell it's there.
Old 03-06-2013, 10:36 AM   #5
BRZ?
Drives: 2014 SWP 6MT BRZ
How does the catless front pipe with the helmholtz sound? Significantly louder than catted helmholtz?
BRZ? is offline   Reply With Quote
Old 03-06-2013, 12:10 PM   #6
FR-S Matt
I would say yes but with rasp as 90% of exhaust systems that go catless are raspy. Even with the stock header cat still there, you can get rasp with it. It's not worth going cheaper for the horrible sound.
The Following User Says Thank You to FR-S Matt For This Useful Post:
CodyFRS (11-29-2013)
Old 03-06-2013, 12:47 PM   #7
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
It's not raspy at all, I have the catless over/front pipe with the HH resonator and the offset axle back and it is actually way quieter than I had hoped it would be. I plan on getting their header(most likely catted) as well so I got the HH res. Definitely louder when cold, but mellows out real quick as it warms up, and it's almost inaudible at cruising speeds, absolutely no drone in my car. And not raspy.
I was under the impression, correct me if I'm wrong, that the resonator was only targeted at the frequencies produced by the header and should have no effect on the sound of the rest of the exhaust.
Cade01 is offline   Reply With Quote
The Following User Says Thank You to Cade01 For This Useful Post:
unsurety (05-22-2014)
Old 03-06-2013, 12:49 PM   #8
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
can you compare the sound, tonal qualities loudness, high pitch content and rumble content of this with vs without vs say perrin resonated vs unresonated?
(yup, I'm considering a nameless for our 2nd BRZ)
you know, I want dirty nitty gritty details sportguy!
Huehuecoyotl is offline   Reply With Quote
Old 03-06-2013, 05:32 PM   #9
FR-S Matt
Your setup has enough muffle to reduce the rasp with the resonator and off-set design. You'll have to be careful if you go with a catless header though. Jason said it gets really loud with theirs and even in the catted downpipe video, there was some rasp in the 2.5" setup. Not sure if it was the redesigned 2.5" system though.
Old 03-06-2013, 07:01 PM   #10
Sportsguy83
Drives: Limited BRZ
I don't have empirical data on exactly how loud it is.
A)
MY BRZ with Helmholtz and Ofsset mufflers has a deeper tone, and is quieter than
B) @DGMBRZ's W/O Helmholtz and Non-Offset mufflers has a higher pitch tone, and sounds more aggressive.
Both tones are similar, but B) commands more attention, sounds more like a race car. A) is more mellow.
Lverasky (05-08-2013), Tainen (03-07-2013)
Old 03-06-2013, 07:20 PM   #11
Huehuecoyotl
Is "A" wife/business client friendly as a passenger, can it be compared to stock, and can it be said "its quiet" below 4000 rpms? I need to get inside a Nameless equipped car,and under one to see this thing with the helmholtz
me likey! Thanks for your feedback!
Old 03-06-2013, 09:41 PM   #12
Cade01
Cade01's Avatar
My exhaust setup would be wife/business client friendly according to my wife, and that is 2.5" offset (original version) and a catless over/front pipe with HH resonator. Below 4000rpms cruising you can barely even hear it.
Old 03-06-2013, 10:08 PM   #13
Sportsguy83
Drives: Limited BRZ
I'd say its acceptable. Not quiet like stock, but quiet enough to be pleasant. I will show you a pic of the Helmholtz give a moment.
Edit: That growing tumor/appendix is the Helmholtz.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 03-06-2013, 11:26 PM   #14
Cade01
Cade01's Avatar
I forgot to mention, I believe the new revision exhaust also uses 8" mufflers instead of 6" like mine has, so that will also help with sound level.
Will Helmholtz resonator decrease power? shu5892001 Engine, Exhaust, Transmission 31 01-07-2015 09:37 AM
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Ordering Nameless Exhaust - Helmholtz Resonator?? Umbie Engine, Exhaust, Transmission 16 12-03-2012 01:48 PM
