Drives: SWP BRZ-L 6MT Sold
A hot lap of Thunderhill in my stock 2013 Subaru BRZ
Here is a lap from last Monday in my 2013 Subaru BRZ Limited.
![]() [ame="http://www.youtube.com/watch?v=HdZY1l08veM"]Stock 2013 Subaru BRZ @ Thunderhill 02/25/13 Toyota GT86 Scion FR-S - YouTube[/ame] The BRZ was on the original Michelin Primacy "Prius" tires and aligned to -1.4 degrees of camber front and rear with zero toe. The brake pads were changed to Ferodo DS2500 and the lines were flushed with Motul RBF600. Laptime: 2:15.87
2017 Tesla Model 3, 2016 Porsche GT4, 2004 Honda S2000 Stock '13 FT86 lap record Thunderhill Stock '13 FT86 lap record Sonoma Raceway Stock w/ upgraded tires '13 FT86 lap Buttonwillow 13CW |
#2 |
Drives: 2013 Firestorm FRS, 1993 Civic Si
Very nice! I hope to bring the FRS up there once I break it in.
#3 |
Proud of BOXER
Drives: Subaru Boxer
Nice lap, looked pretty fast! Thanks for sharing this!
#4 |
Codename: Stitch
very nice, and fastest (near) stock lap of a BRZ at THill that I've seen... mine is similar specs but the day in December I went it was rainy and damp and I wasn't nearly as fast.
#5 | |
I plan to run the OEM tires as well with the SSL lines and blue Ate already on the car. Pads are < than week turnaround. I was not tempted to get an alignment but I'm learning otherwise. Thanks for sharing. |
#6 |
Aww man, you're in Pleasanton! Hello neighbor, San Ramon here
#7 |
Drives: 2013 Black FR-S
Awesome driving! That's fast for stock tires!!!
#8 |
WOW! FANTASTIC DRIVING! The benchmark has been set.
Were you able to get the -1.4 camber with the stock bolts, or did you have to get an aftermarket kit?
2013 Subaru BRZ
#9 | ||
Hey, thanks for the compliments guys! This car is a lot of fun and pretty intuitive to drive on the stock suspension/tires.
With regards to the alignment, it was done with camber bolts. I do not believe there is any stock adjustment. The tires only exhibited minor tread block scrubbing at 32 psi cold all around. The idea was that if I went to the track with zero camber, I would have probably ruined the tires in just one day due to edge wear. In response to MyRx, my perception is that I was at the limit of the stock tires in all the corners and braking zones. I think I could go just a little faster if I were to rush shifts or run up further on the curbs, but I try not do either of those things in daily driven street cars. ![]() By the way, if anybody knows of a shop (i.e. CSG, Robi, Evasive, etc.) that is interested in a driver for time attack/racing/testing, I'd be very interested in the opportunity! Thank you, Sean Quote:
#10 |
Drives: Scion FR-S/ Subaru BRZ
nice driving.....very fast lap.....clearly the camber + upgraded brakes translate to much faster lap times.....I would also guess that the slightly more understeer bias of the BRZ helps at Thunderhill too.....
#11 | |
The extra -0.75 camber over a stock alignment may have improved front traction a little, but the main benefit was better tire wear. The lack of rear toe in compared to stock specifications was probably just as large of a factor in making the car more neutral. I thought the BRZ was nicely balanced at the track for a street car. It did understeer a bit as you mentioned. I haven't tracked an FRS for comparison but would love to try one given the opportunity!
2017 Tesla Model 3, 2016 Porsche GT4, 2004 Honda S2000 Stock '13 FT86 lap record Thunderhill Stock '13 FT86 lap record Sonoma Raceway Stock w/ upgraded tires '13 FT86 lap Buttonwillow 13CW Last edited by smmmurf; 03-06-2013 at 12:20 PM. |
#12 |
I just ran both my bypass video and your video side by side (comparing 1-4 & 6-15). We were identical. But I had the advantage due to tires so your skill made up for lack of grip. Excellent!
![]() I have work to do.
#13 | |
I like comparing stock tire times since not everyone upgrades to the same rubber (and all the car magazine tests are done on the Primacy's so it gives you a benchmark to shoot for).
#14 |
Drives: Brz WRB - Europe LHD
WOW!" Great.....a nice circuit....beautiful the downhill section.....finest!!!!!
What do you think about R1-R and/or Toyo R888GG on BRZ?
| NorCal 2/9/2013 Saturday, Portola Valley Tank Museum Visit (or ThunderHill) RSVP | 86BRZ | Northern California | 43 | 02-28-2014 05:13 PM |
| Thunderhill Raceway 3/2/2013 (Video) | sw20kosh | Tracking / Autocross / HPDE / Drifting | 7 | 03-07-2013 06:53 AM |
| Thunderhill Raceway 2/8/2013 (Video) | sw20kosh | Tracking / Autocross / HPDE / Drifting | 21 | 02-10-2013 11:49 AM |
| 2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast | Zgrinch | Scion FR-S / Toyota 86 GT86 General Forum | 124 | 02-21-2012 02:43 AM |
