Old 03-04-2013, 01:54 AM   #1
sw20kosh
Drives: 2013 Black FR-S
Thunderhill Raceway 3/2/2013 (Video)
Lots more fun around thunderhill (CA) in my lightly modified FR-S. Only new mod was custom cat back instead of a muffler delete, and a rear diffuser.
I was quite a bit faster out there this time around. I was focusing on being in the powerband more (aka. downshifting more) and I was a lot more confident in pushing entry speeds as Icemang will atest (he feels bad for my front tires). LOL
This time around I found much much more understeer with my set up. Only thing different was the diffuser. Even the tire pressures were the same. I had to take out 2-3 psi in the front to dial back the understeer. Looks like this may be a sign the diffuser is working? Maybe I need a front splitter now?
App/phone was not cooperating in the later sessions where I feel I was faster but here is a vid from the earlier sessions.
2:12
[ame]http://youtu.be/jQVYjPTfGb4[/ame]
_
_
Diffuser - http://www.ft86club.com/forums/showthread.php?t=30149
Relevant Mods:
RCE Yellow springs
-1.5 camber front
-1.7 camber rear
245/40/17 Hankook RS3's
Mach V Awesome 17x9 +42 rims
FT86 Factory 11lbs battery kit (20lbs savings)
Custom Magnaflow Cat Back (Burlingame Mufflers: Performance and Custom) (10 lbs)
Rear Seat Delete (20lbs)
Spare Tire + Tools Removal (30lbs)
~80lbs weight reduction
3 FR-S and 1 BRZ at the event. I was so happy to see them there!
The Following 4 Users Say Thank You to sw20kosh For This Useful Post:
enjoyminutemaid (03-04-2013), orthojoe (03-05-2013), suaveflooder (03-04-2013), Touge Monster (03-04-2013)
Old 03-04-2013, 02:35 AM   #2
suaveflooder
I can't wait to do this!!! How many miles on your car? I was planning on waiting until 7500 miles before I starting tracking mine, but I don't know if I can wait that long.
suaveflooder is offline   Reply With Quote
Old 03-04-2013, 03:57 AM   #3
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Good times man sorry I couldn't make it still dealing with a family crisis stuck out in Hawaii now. Ill see you at Laguna Seca in May you are going the 19th right?
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
Old 03-05-2013, 12:03 PM   #4
icemang17
Drives: Scion FR-S/ Subaru BRZ
to help reduce some front understeer try adding a bit more camber in front..might take camber plates.....also try reducing front and-or increasing rear pressure to help the car rotate.......do you know what the front-rear toe settings are? I would guess you are running a "street" style alignment toe settings so probably a little toe in all around.....I would try setting the front toe to zero.....this makes for MUCH faster-stronger turn in.....my racer has this with just a smidge toe in out back.... setting the rear to zero to slightly in also helps the car rotate....
Next time you can pit with me.....I have full alignment tools & can take tire temps to determine exactly how to setup the alignment....I take tire temps everytime I come off track.....
icemang17 is offline   Reply With Quote
Old 03-05-2013, 02:23 PM   #5
sw20kosh
I took out pressure in the front for the 4th and 5th sessions and it stabilized the understeer.
Toe is 0 all around I think. I'll double check.
Thanks for the offer to Pit! That is awesome!
Old 03-06-2013, 03:17 PM   #6
Teo
Teo's Avatar
What is your setup for iPhone camera "harrys lap timer" ?
Where is installed?
Teo is offline   Reply With Quote
Old 03-06-2013, 10:12 PM   #7
sw20kosh
Where is installed?
http://www.igloocase.com/
Case and mount. It is mounted to my rear window.
Old 03-07-2013, 06:53 AM   #8
Teo
Teo's Avatar
Thanks!
NorCal 2/9/2013 Saturday, Portola Valley Tank Museum Visit (or ThunderHill) RSVP 86BRZ Northern California 43 02-28-2014 05:13 PM
H2R (Harris Hill Raceway) 2013 Time Trials!! track_warrior Tracking / Autocross / HPDE / Drifting 5 02-24-2013 07:19 PM
Thunderhill Raceway 2/8/2013 (Video) sw20kosh Tracking / Autocross / HPDE / Drifting 21 02-10-2013 11:49 AM
Customized 2013 FR-Z video floridaguy Southeast 44 11-08-2012 10:27 AM
Five Axis FR-S from Regional Launch Event at Pocono Raceway - Pics and Video ruskymx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 06-22-2012 08:00 PM
