#155 | |
Drives: Nevermorange FRS
I was just thinking about this. I didn't take into account the depth of the pan. Honda pans are really shallow and only hold 4-5 qts so even with sensor being the drainplug (at the very bottom) it's still pulling recently heated oil. But on a deep pan that also has cooling fins then I could see how the oil at the bottom of the pan has undergone some cooling before the temp gets picked up by the sensor (assuming the sensor being at the bottom). This is all easy to swing to the equation though. If I know my pan is shallow and doesn't dissipate heat well and my sensor is at the bottom of it then I know the temp reading is on spot but if I have a deep pan that cools well then I can estimate a 260F reading is closer to 270-80 and respond accordingly. How's that sound?
PRO86 | STL | LuckyDog
#157 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#158 | |
I Love custom Turbo kits
Drives: Limited BRZ
#159 |
Site Moderator
Drives: Stuff
It already comes on the adapter and I did use it on the sender.
-Dave
#160 |
i'm sorry, what?
Drives: Canada
So how is it that a stock engine, which should have been stress tested by the engineers, is put out that can't handle more than a minute of being out on the track?
and what about all those people currently driving their cars without coolers that have no idea this posts exist, are they going to fry their engines soon, are they already fried, did Toyota really screw up on this one? hard to buy that in order to enjoy this car as intended a person needs to dump a considerable amount of money to prevent the supposed damage? I've already had a few long sessions at a track in the summer, is my engine already compromized?
#161 | |
Site Moderator
Drives: Stuff
I race a car with no cooler for 24 hours straight. It runs 290-300+ (gauge stops at 300) oil temps the entire time. It has 222,000 miles on the engine,~5,000 since rebuilding it, 100% race miles since about 214k. Current leakdown/compression is identical to post-rebuild. We run thick oil in it (due to bearing clearances) but that's it. No cooler.. in fact the cooler I have on my BRZ is from that car, we removed it due to a leak at a fitting (wasn't tight enough) and decided the engine going away was a better risk than a leak removing us from a race weekend that cost us $5k. One is simply a lot more likely than the other. Having said that, I run a cooler because I intend to track the BRZ a lot and daily drive it a lot. I don't want to rebuild it for 200,000 miles at least. Oil being cooler let's me be lazy. Hot oil can/does run at lower pressures and heat is one of the causes of shear in a VII (vis idx imp) oil. On the flip side, thicker oil actually results in higher engine oil temps as it's less effective at removing heat from the engine so everything heats up more. My opinion is that an oil cooler is a good idea for a car that sees track use, especially in hot climates, but if UOAs are showing no major shear/etc and you are good about oil changes I wouldn't consider it a requirement. Thin oil that is shearing and at high temps (where it's vis/HTHS isn't very good) isn't great at protecting an engine from wear over the long haul. Thicker oil adds heat, which brings it closer to those points where it breaks down/shears/etc, hence the issue.. and eventually the desire for a cooler to bring temps down. Thin as you can go, thick as is needed.
-Dave
#162 |
i'm sorry, what?
Drives: Canada
So i shouldn't worry about a day's worth of autocross?
#163 |
Site Moderator
Drives: Stuff
I wouldn't. I've autocrossed and tracked the car without a cooler without worrying about it.
-Dave
#164 |
Wise old man
Drives: 86 GTS
I spoke to tetsuya tada, and i asked him what is the max safe oil temp. he said 130C was the guideline. so if you are seeing beyond that, you need an oil cooler!
#165 |
Drives: Perrin/VORTECH Supercharger TestBRZ
#166 |
Wise old man
Drives: 86 GTS
yes i prefer to have oil just 10 degrees more than coolant.
#167 |
Drives: 2013 Firestorm FR-S
Has anyone noticed the car losing power due to oil temps?
2013 Firestorm FR-S, MTX, build date 1/13.
#168 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Perrin did extensive testing and posted results in their blog: http://blog.perrinperformance.com/pe...-s-oil-cooler/
They measured a loss in power as the oil temps went past 100C |
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 08:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 04:30 PM |
| One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 05:42 PM |
| Oil Cooler kit for FI applications, getting one? | JoeBoxer | Forced Induction | 84 | 01-20-2013 09:48 AM |
| Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 12:55 AM |
