Old 03-05-2013, 12:34 PM   #15
bakerr6
Drives: 2013 raven black fr-s
Originally Posted by reeves View Post
Pot stirred.
not really though. If you think about it, most products have at least a few bad products leave the shelf (even when using strict manufacturing processes and machines to manufacture items).
I wouldn't necessarily count out works exhaust for one item rusting. However, I would probably ask them to compensate me for replacing the tips with some that will not rust like these have.
bakerr6 is offline   Reply With Quote
The Following User Says Thank You to bakerr6 For This Useful Post:
SkullWorks (03-05-2013)
Old 03-05-2013, 12:39 PM   #16
Celica00
Celica00's Avatar
Drives: 86
idk man, i have 304 stainless and have driven during this heavy snow season and on consistantly salted roads and have had no rusting at all.
but i do wash the undercarriage pretty often ~1-2 weekly
Celica00 is offline   Reply With Quote
Old 03-05-2013, 12:46 PM   #17
SkullWorks
Drives: SSM LT MT BRZ
as Dimman pointed out any free iron particles on the surface of the metal can cuse rust (see threads on rail dust rusting white painted cars)
For stainless 300 series "best Practice" is to have the parts passivated after cutting/forming/welding. However passivating is not a process available in house at 99% of fabrication shops.
If a shop is both careful AND lucky, you can often get away with careful surface prep and keeping different polishing/buffing/grinding wheels, scotch-brite, sand paper etc etc for different materials.
I atleast find it refreshing that you aren't on here bashing and would rather address the problem at hand.
****If it was on my car, I would take the assembly off and start with a fresh piece of SS wool (extra fine), and roughen the whole polished tip, then polish it with a polishing wheel or buffer and some fine rouge (green or white) to get your polish back, this should get any surface contaminants out...but having those things handy and not is usually the difference****
Old 03-05-2013, 02:31 PM   #18
OrbitalEllipses
Drives: Attitude
Ran my Nameless all through winter and have had no issue like this with the tips or piping.
Old 03-05-2013, 02:34 PM   #19
Anorax
Drives: '13 BRZ SS
And you got considerably more "elements" then I did out here on the plains of the Rockies.
Anorax is offline   Reply With Quote
Old 03-05-2013, 02:37 PM   #20
OrbitalEllipses
Drives: Attitude
Severely over-salted roads, plenty of rain, occasional snow. Nice humid climate! The perfect breeding ground for rust. I think I sheared EVERY bolt on my WRX when I did exhaust, after ~8 years of ownership. Going to try and get the BRZ buttoned up exhaust wise before next winter.
Old 03-05-2013, 02:39 PM   #21
M1K3
M1K3's Avatar
Drives: vrooom...
No, they don't salt the roads here
Are you being sarcastic? That definitely looks like salt and its all over the place.
M1K3 is offline   Reply With Quote
The Following 2 Users Say Thank You to M1K3 For This Useful Post:
LeeMaster (03-05-2013), microbionic (03-05-2013)
Old 03-05-2013, 02:46 PM   #22
wu_dot_com
Drives: accord
also, just because its 304SS doesnt mean its 304SS. ask the manufactor for their batch certification. you could have a bad batch of 304SS with lower than usual chrom content.
wu_dot_com is offline   Reply With Quote
The Following User Says Thank You to wu_dot_com For This Useful Post:
STEVEOSTI (03-07-2013)
Old 03-05-2013, 02:56 PM   #23
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
Anorax where is your Location? That looks like salt on the ground, and all over the bumper, and the spot pattern on the exhaust tip looks like it has the usual salt corrosion effects. If you live anywhere that a parking lot could have salt on it thats all it takes. Either that or you live near a body of water with high salt content. Like others have said, the surface may have some iron contamination. Try cleaning it off with a metal polish.
Are the exhaust welds Rusting?
Most stainless will get a petina over time from water and air and temp.
The tips could be a lesser 3xx Stainless and possibly why it rusts faster?
turbocat is offline   Reply With Quote
Old 03-05-2013, 03:05 PM   #24
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Looks like it isn't the tip rusting but random road grime, brake dust, and other junk picked up during winter months that is rusting, especially with all the salt/brine used on roads.
Since you have a white car. Take a very close look at the paint. I bet you will also see "rust" spots in the paint. While the car isn't rusting, the material picked up from daily driving that is stuck on the paint is rusting. Most the time you can get it out with a nice hand car wash but other times it requires clay bar and some polishing.
Can look like this:
To me that looks like what is happening on the tips. Hard to say though without me taking a rag and scrubbing the tip down.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
wu_dot_com (03-05-2013)
Old 03-05-2013, 03:09 PM   #25
Anorax
Drives: '13 BRZ SS
I'll acknowledge that my work parking lot might have some salt, I can't say for certain. But again, that much in two weeks time?
I'll be getting some Eagle One Nev'r Dull today (hopefully) and seeing what comes out.
Old 03-05-2013, 03:11 PM   #26
Anorax
Drives: '13 BRZ SS
Silver car, actually and I intend on thoroughly cleaning the tips today if I can find the cleaner I want.
Hopefully, you're right.
Then I guess it'll be a matter of how long until it does it again, or if (if I'm REALLY lucky).
Old 03-05-2013, 03:11 PM   #27
SkullWorks
this isn't AeroSpace, it is highly doubtful that the "heat lot number" is going to be tracked thru any processes outside the original foundry.
and this isn't the 50's anymore the chance of getting "bad" 304 is not very high. heck 90% of the 302 I buy meets the 304 standard requirements also.
The Following User Says Thank You to SkullWorks For This Useful Post:
Old 03-05-2013, 03:16 PM   #28
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Anybody knows what the stock tips are made from (not trying to high jack but just for comparison's sake)... they looks pretty damn good after a whole winter.
Rayme is offline   Reply With Quote
Takeda exhaust rusting... trish07 Engine, Exhaust, Transmission 96 03-12-2014 01:41 PM
Anybody else's car rusting yet? Selvedge Issues | Warranty | Recalls / TSB 17 10-31-2012 10:11 AM
Another 8 weeks!! Wesley Scion FR-S / Toyota 86 GT86 General Forum 28 09-21-2012 07:25 PM
had my frs for two weeks..this is what happens bcmakesiteasy Scion FR-S / Toyota 86 GT86 General Forum 98 08-07-2012 11:20 AM
