Old 03-04-2013, 10:13 AM   #127
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by Kodename47 View Post
Sierra, there is enough flex in the top of the bumper if you want to do it that way, you just have to be gentle and not yank at it! If you don't want to risk it then take off the bumper, it will make it so much easier anyway, but it can be done without removing it.
I'm sure there is but it would be a mega piss off if it did damage it.
I wish someone would make a cold air intake that didn't mean taking the front off the car to clean it, or risk busting it taking the short cut.
sierra is offline   Reply With Quote
Old 03-04-2013, 10:30 AM   #128
vtmike
vtmike's Avatar
Drives: Scion FR-S
I'd be happy with an improved snorkel that runs to the stock location under the bumper cover. That way your only removing the bumper once.
Sent from my Galaxy Nexus using Tapatalk 2
vtmike is offline   Reply With Quote
Old 03-04-2013, 06:36 PM   #129
sierra
Yes, that would be a good mod.
Old 03-04-2013, 06:46 PM   #130
Turdinator
Señor Member
Turdinator's Avatar
How would you improve it? Could you maybe mod the stock one or make your own?
1974 TA22 Celica
2013 86 GT
Old 03-04-2013, 07:01 PM   #131
NickFRS
Drives: 2013 Asphalt FRS
Sold my iphone but my friend took this picture the other day!
i'll try to get a close up tonight. Sorry for the long weight. I still have some more sanding and welding to do on it to make it look perfect. You might be able to load the full size image in another window and zoom in. This approach makes it almost look like the stock airbox has a small nub. I'll later be making it flush with the box! And just painting that side of the box a matte black with the perrin logo white.
NickFRS is offline   Reply With Quote
Old 03-04-2013, 07:17 PM   #132
sierra
Just removing the resonator and exposing those 2 holes almost doubles the intake area.
46mm dia seems too small considering the size of the throttle body. By leaving the 2 x 29mm holes open that is equivalent to having a 61mm dia cold air intake which still seems a bit small but is a big improvement.
Old 03-04-2013, 07:19 PM   #133
NickFRS
If anything that may disrupt the airflow and suck in engine hot air which kills the effectiveness of the snorkel.
Old 03-04-2013, 07:44 PM   #134
sierra
I think the benefits of almost doubling the intake area would overshadow any airflow disruption at the airspeeds involved.
I just went out and had a look at mine and that snorkel doesn't look long enough to get right across and past the radiator. If that's the case and it's certainly the case with pod filters there, it doesn't matter.
The air it draws in is in front of the heat exchangers and part of the high pressure pool of cool air they draw through. The only time it would warm up is while it's stationary before the thermo fans cut in to start the airflow again.
There's also plenty of room for a much larger intake to go through from the factory airbox. Do any of the after market airboxes take advantage of that?
Old 03-04-2013, 07:49 PM   #135
Turdinator
Señor Member
Turdinator's Avatar
I was thinking more along the lines of chopping the end off at a point that is larger and heating it up and bending the edges to creat a crude trumpet. But i haven't seen the snorkel first hand yet to know if this is possible.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Kostamojen (07-18-2014)
Old 03-04-2013, 08:17 PM   #136
sierra
It could work alright the way you suggest but you wont get any ram effect where it is, it's just a pool of cool high pressure air. Having a small trumpet will help smooth the flow a bit.
Even having an intake down lower where the air comes in wont get much, if any ram effect because the air is dammed up in front of the heat exchangers and moving relatively slowly. It needs to be in an area of unrestricted flow, like the ones above the drivers head in race cars, where the air has high velocity and that kinetic energy can increase the air pressure, same as the main intake on our has already done.
Old 03-04-2013, 08:40 PM   #137
roddy
roddy's Avatar
Drives: '13 Ultramarine
I've been thinking about getting the intake tube, then removing the resonator, and doing a snorkel-ectomy. For those that have removed the large resonator attached to the airbox, how secure is the airbox with that extra mounting point gone along with the resonator?
Old 03-04-2013, 08:47 PM   #138
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
It's still really secure, there may be a bit more wiggle, but not much. You don't have any of that extra weight there.
Cade01 is offline   Reply With Quote
The Following 2 Users Say Thank You to Cade01 For This Useful Post:
roddy (03-05-2013), sierra (03-04-2013)
Old 03-04-2013, 08:49 PM   #139
vtmike
vtmike's Avatar
Drives: Scion FR-S
It's secure. The resonator has some play in it when attached to the box so no loss in rigidity.
Also after having the resonator off and getting some more seat time in the induction noise is louder at about 2500-3000 rpms when the engine is under load. Not much difference in sound at other rpms.
Sent from my Nexus 7 using Tapatalk HD
The Following User Says Thank You to vtmike For This Useful Post:
roddy (03-05-2013)
Old 03-04-2013, 08:50 PM   #140
sierra
Do you have yours with those 2 ports open for extra airflow?
If so have you noticed any gains at the top end?
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Length of stock resonator? jm1681 Engine, Exhaust, Transmission 5 10-26-2012 07:25 AM
WTB Stock OEM Airbox/snorkel brichard0625 Engine, Exhaust, Bolt-Ons 1 10-20-2012 09:21 AM
WTB: Stock AirBox SkullWorks Engine, Exhaust, Bolt-Ons 1 08-15-2012 09:09 AM
