Old 03-04-2013, 09:24 AM   #15
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Originally Posted by polancd View Post
How bad is the scoring? You can probably get them resurfaced
I had never actually seen scoring before (had to look it up to confirm that is what it was). I personally think a couple of the lines are pretty deep. I might try to get them resurfaced. But I can also use the opportunity to talk the wife into letting me upgrade. And the kit comes with pads, lines, and rotors. Just dont know if they are any good. I've had one person say they are good, but i'd really like a few more positive (or negative) calls before making the decision.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 03-04-2013, 09:48 AM   #16
polancd
Drives: a few
Can you post a pic of the scoring?
polancd is offline   Reply With Quote
Old 03-04-2013, 09:55 AM   #17
akuhei
akuhei's Avatar
I'll try to get one later today. It probably isnt as bad as i am making it out to be, looks like a few grains of sand or something got in there and caused it.
Akuhei's Blog
"Inconceivable"
Old 03-04-2013, 12:52 PM   #18
akuhei
akuhei's Avatar
Cell phone pic..best i can do for now..
Akuhei's Blog
"Inconceivable"
Old 03-04-2013, 01:21 PM   #19
Racecomp Engineering
It's probably okay but it's hard to tell in pics. Can you snag a nail on the rotors?
The stoptech street pads are good street pads, but may not be up to the track if you're running stickier tires. Their rotors and lines are good stuff if you are indeed in need of replacement.
For the track, it's preferable to have a dedicated set of track pads. That said, Ferodo 2500s are one of the best street pads that can take a little bit of heat.
- Andrew
akuhei (03-04-2013)
Old 03-04-2013, 01:36 PM   #20
akuhei
akuhei's Avatar
- Andrew
Snag a nail? Like a fingernail running across it? If so, then yes. It seems like a substantial couple of lines in it, easily felt.
I am not running sticky tires yet, though when these run down further i will likely upgrade those.
Akuhei's Blog
"Inconceivable"
Old 03-04-2013, 02:14 PM   #21
Yeah snag a fingernail. It's not a good sign when your rotors are that grooved.
- Andrew
akuhei (03-04-2013)
Old 03-04-2013, 02:53 PM   #22
akuhei
akuhei's Avatar
- Andrew
Shyt..thats what I thought. Hmm...
Akuhei's Blog
"Inconceivable"
Old 03-04-2013, 03:19 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That looks fine to me. I would run them till you see cracks that go to the edge. If you are worried about them, swing down and I will take a look at them. Then show you the cheap $15 rotors on my racecar that look way worse, haha.
akuhei (03-04-2013)
Old 03-06-2013, 05:47 AM   #24
polancd
Drives: a few
^ This. hard to tell from the pic, but dont see pitting or cracking so you should be good. Also I would trust RCE's word when it comes to Stoptech, if you are dead set on changing your rotors.
Old 07-10-2018, 01:10 PM   #25
E_br4ke
Drives: FRS 6MT
Did you end up getting the kit? Review?
Thanks!
E_br4ke is offline   Reply With Quote
Old 07-10-2018, 03:05 PM   #26
JMon85
JMon85's Avatar
Drives: 2019 WRX
I'm using this kit currently. The difference is marginal between OEM pads and these stop techs. I did however install the cusco master cylinder brace along with this kit and I feel the brace made the difference in pedal feel, not the pads. Perfect for street use nothing more imo.
JMon85 is offline   Reply With Quote
The Following User Says Thank You to JMon85 For This Useful Post:
E_br4ke (07-11-2018)
Old 07-10-2018, 09:06 PM   #27
akuhei
akuhei's Avatar
Thanks!
I did not. I ended up buying some cheap rotor blanks, and they have worked just fine.
Akuhei's Blog
"Inconceivable"
Stop Tech Big Brake kit installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 03-27-2013 07:52 PM
FS: BRZ Sport Tech in Edmonton tawheed Canada Classifieds 1 03-10-2013 06:17 PM
BRZ Sport Tech For Sale - Toronto roban86 CANADA 16 02-28-2013 02:32 PM
SWP BRZ SPORT TECH MANUAL FOR SALE Skye CANADA 2 11-14-2012 08:27 PM
BRZ Sport tech manual for sale Skye Cars for Sale/Trade 0 11-06-2012 02:57 PM
