Old 03-01-2013, 12:04 PM   #113
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by ATL BRZ View Post
I deleted all the resonators on my stock intake.
$12 worth of parts from Advance
Sorry to be a pain but can you elaborate which one was for what?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-01-2013, 12:31 PM   #114
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I think the 1 7/8 plug is for the big resonator on the front of the airbox, the 1 5/8 plug is for the noise gen, and the 1 1/4 plug is for the little blob resonator underneath the intake tube. The hitch ball cover stretches over the airbox plug and you use a hose clamp to seal it down.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Kodename47 (03-02-2013)
Old 03-02-2013, 02:53 PM   #115
vtmike
vtmike's Avatar
Drives: Scion FR-S
Just finished blocking off the main resonator. I already had the perrin inlet tube installed. Couldn't really get the plug to fit to block the resonator off, but the toe hitch cover worked well enough to seal it off. The plug doesn't seem necessary to me for the big resonator, it probably weights as much as the resonator too so there really wouldn't be any weight savings using it.
As far as sound goes, not really noticing much of a difference from before it was removed. The perrin inlet tube removing the sound generator made the biggest impact on sound.
Sent from my Nexus 7 using Tapatalk HD
vtmike is offline   Reply With Quote
Old 03-03-2013, 11:41 AM   #116
vtmike
vtmike's Avatar
Drives: Scion FR-S
Sent from my Galaxy Nexus using Tapatalk 2
The Following User Says Thank You to vtmike For This Useful Post:
sinigang_guy (03-09-2013)
Old 03-03-2013, 11:44 AM   #117
ATL BRZ
ATL BRZ's Avatar
looks good!
Old 03-03-2013, 12:01 PM   #118
vtmike
vtmike's Avatar
Drives: Scion FR-S
looks good!
Thanks. Now if my exhaust would hurry up and get here my engine mods will be complete.
Old 03-03-2013, 12:54 PM   #119
vtmike
vtmike's Avatar
Drives: Scion FR-S
Has anyone removed the resonators on the snorkel.
Old 03-03-2013, 11:22 PM   #120
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I want to, just don't want to take off the bumper.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 03-04-2013, 04:15 AM   #121
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'll answer this one with a picture:
I also thought I'd add some measurements (in mm as I'm British ):
Main Resonator outlet:
Outer Diameter - 50mm
Inner Diameter - 46mm
Pipe Resonator:
OD - 30mm
Snorkel Resonator Connections (Both the same):
OD - 32mm
ID - 29mm
Basically if you want to cap them, use the OD. If you want to try and plug them then use the ID measurements.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
nix (04-19-2013), vtmike (03-04-2013)
Old 03-04-2013, 07:03 AM   #122
vtmike
vtmike's Avatar
Drives: Scion FR-S
I'm in the same boat. If I'm going to that trouble might as well get the perrin cai or an aftermarket snorkel. Although haven't seen any US companies selling aftermarket snorkels. I don't care for the max racing one, we get some pretty good storms where I live.
Old 03-04-2013, 07:34 AM   #123
Kodename47
Kodename47's Avatar
Drives: UK GT86
You don't need to remove the bumper, you can flex it enough to move it out the way. Look in the DIY section for Airaid install/Snorkel removal, shows you easily how to do it. It's a bit of a pain but possible. I've still got to re-install mine back in the car....
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-04-2013, 08:26 AM   #124
sierra
Drives: Skoda Yeti DSG diesel 4x4
It costs $3,000 for one headlight assembly.
How much will it cost for a new front end if it breaks?
sierra is offline   Reply With Quote
Old 03-04-2013, 08:42 AM   #125
vtmike
vtmike's Avatar
Drives: Scion FR-S
Pipe Resonator:
OD - 30mm
OD - 32mm
ID - 29mm
Thanks for the measurements. I take it you removed all of the resonators at the same time. Just wondering how much of a difference the 2 remaining ones on the snorkel make since I have already removed the others.
Old 03-04-2013, 09:52 AM   #126
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yeah I did I'm afraid. I've only run without the snorkel so far as it's awaiting the caps but then I'll shove it in. The noise like that is pretty awesome though.
Sierra, there is enough flex in the top of the bumper if you want to do it that way, you just have to be gentle and not yank at it! If you don't want to risk it then take off the bumper, it will make it so much easier anyway, but it can be done without removing it.
.: Stealth 86 :.
Kodename 47 DJ:
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Length of stock resonator? jm1681 Engine, Exhaust, Transmission 5 10-26-2012 07:25 AM
WTB Stock OEM Airbox/snorkel brichard0625 Engine, Exhaust, Bolt-Ons 1 10-20-2012 09:21 AM
WTB: Stock AirBox SkullWorks Engine, Exhaust, Bolt-Ons 1 08-15-2012 09:09 AM
