Old 03-04-2013, 02:59 AM   #127
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by shishand View Post
So can we expect dyno charts between the AT and M/T about the same? thanks again for your work!
You betcha. As soon as the AT BRZ gets what it needs to optimize the Stage 2 tune (exhaust components) - I'll post up both side by side right here. I will also have a condensed write-up with all the pertinent information so we don't have to weed thru 100 pages of text...
Originally Posted by cmss2000 View Post
In reality stage 1 started off at a nice $3800, but then jumped to $4400 with now standard ceramic coating and needs a BOV, so stage 1 in reality is $4650 (correct me if I'm wrong here).
As stated above in previous posts, you don't have to buy a BOV from AVO. I think a used EVO one goes for next to nothing and I think that will work too. I might be able to get one to try it out... More on this later.
Price for the kit without the ceramic coating is $3800, and you can get them untreated, but I strongly recommend the coating particularly because of the proximity of the plastic undertray to the header. It's well worth the $600 difference IMHO. There are three parts that are coated for that price incidentally, in case you guys were wondering...
Base map is included and cannot be taken out. Even with a base map, you still are recommended to get your local tune. Base map is a general map to get the car running safely after install.
A Stage 1 basemap will be included with the purchase of the kit. Not sure about a Stage 2 one - that's a question for AVO to answer. We were brought in only to show what kind of gains you can expect when the product is PRO-Tuned (as opposed to being E-Tuned,) mind you.
Regards!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
BRZranger (03-04-2013)
Old 03-04-2013, 06:42 AM   #128
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by AVOturboworld View Post
Roughly looking at a target of 5800.00, that's the Stage 1 + the Stage 2 components (MAP sensor, 7psi Actuator, Cross-Over Pipe, High-flow Front Pipe, Stage 2 Base Map).
Regards!
See post above, AVO will offer Stage 2 base map.
Sent from my HTC One X using Tapatalk 2
Old 03-04-2013, 07:13 AM   #129
troek
troek's Avatar
Drives: 2012 Toyota 86
so this kit comes with no BOV at all, or does it come with a recirc valve?
troek is offline   Reply With Quote
Old 03-04-2013, 07:29 AM   #130
driver01
Drives: brz 13
Kit does not come with a bov. i got the avo bov from paul, nice looking and high quality. If not any evo8 bov will fit.
driver01 is offline   Reply With Quote
Old 03-04-2013, 01:39 PM   #131
Drift-Office
Did it say it was free? I don't recall seeing that.
Old 03-04-2013, 06:49 PM   #132
Sportsguy83
Drives: Limited BRZ
I never said it was free either... I ONLY said it will be included with the Stage 2 purchase, and that is exactly what AVO said in their post....
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 03-21-2013, 08:05 PM   #133
BRZranger
Dropped off my BRZ with Paul @AVOturboworld and Bob @Drift-Office for stage 2... Stay tuned!
BRZranger is offline   Reply With Quote
The Following 12 Users Say Thank You to BRZranger For This Useful Post:
Alienate (03-21-2013), Apex Chase (03-21-2013), civicdrivr (03-21-2013), cmss2000 (03-22-2013), dabocx (03-22-2013), Draco_PR23 (03-21-2013), Drift-Office (03-21-2013), Imrac (03-22-2013), kidgogeta (03-21-2013), Sportsguy83 (03-22-2013), TRD_07 (04-04-2013), vubaru (03-22-2013)
Old 03-26-2013, 07:53 PM   #134
AVOturboworld
Still working on ironing some exhaust details out. We know what we've hit on the manual, and this is what we are aiming for with the automatic.
8psi on Stage 1.5, manual transmission, with full exhaust, MAP sensor, 7psi Actuator
10psi on Stage 1.5+, manual transmission, with full exhaust, MAP sensor, 7psi Actuator
The Following 15 Users Say Thank You to AVOturboworld For This Useful Post:
Apex Chase (03-26-2013), BRZranger (03-26-2013), Calum (03-26-2013), dabocx (03-26-2013), Draco_PR23 (03-27-2013), Drift-Office (03-26-2013), kidgogeta (03-26-2013), MSTiFK8R (03-27-2013), NorCalRider (03-27-2013), OjiGeorge (03-27-2013), Sonolin (05-14-2013), Sportsguy83 (03-26-2013), sw20kosh (03-26-2013), TRD_07 (04-04-2013), vubaru (03-27-2013)
Old 03-26-2013, 08:52 PM   #135
dabocx
dabocx's Avatar
Drives: Scion FRS
That 10psi map is exactly what I want. Looks awesome!
dabocx is offline   Reply With Quote
Old 03-26-2013, 09:21 PM   #136
Calum
That Guy
Drives: 2013 asphalt FRS MT
Before I get too excited, what gas octane was used for testing?
What's the plan? Is AVO going to be selling the stage 1.5 aswell as a stage 2?
Old 03-26-2013, 09:27 PM   #137
AVOturboworld
That was all on 92 octane.
Stage naming is a bit flexible. There's stage "stock fueling system" and stage "injectors, fuel pump, and a clutch".
The Following User Says Thank You to AVOturboworld For This Useful Post:
SkullWorks (03-27-2013)
Old 03-26-2013, 09:27 PM   #138
Drift-Office
That's 92 Octane from Sam's Club (I know, he's cheap right?! ) but that really wasn't the concern. The clutch at that point isn't holding up very well, probably doesn't help when we've kicked it a whole bunch in the months before during our Gymkhana events...
Cheers!
Old 03-26-2013, 09:39 PM   #139
dabocx
dabocx's Avatar
Drives: Scion FRS
So that 10psi run is still on stock fueling?
Old 03-26-2013, 09:42 PM   #140
AVOturboworld
Yes. And no, I don't recommend more than 8psi on stock fueling.
My Beltronics STi-R Plus Installation - Work in progress xjohnx Electronics | Audio | NAV | Infotainment 27 07-20-2013 11:10 AM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 12:06 PM
P&L Motorsports Stage 1 Turbo Kit Review (In Progress) Supermassive Forced Induction 66 02-07-2013 01:30 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 08:38 PM
Our FRS work in progress! detainu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 06-24-2012 10:36 PM
