Old 03-02-2013, 02:28 PM   #421
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Originally Posted by abutterman View Post
so the red wire from the switch could just go to the side marker and if needed add some extra wire to make it long enough to go in through the firewall to wherever you want the switch?
yes. but i think its better if u just look or the wire for side marker/parking lights under the steering column (behind the trunk switch) to tap that red wirefrom the switch.
Originally Posted by lbroskee View Post
so my bezels came in yesterday, but i wasnt home so they left a notice for "redelivery". does any1 know if i need to fill that out or if they will just try again on the next business day?
no. u gotta ask for a request before they attempt to redeliver. or u can pick it up from ur nearest local post office.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
The Following User Says Thank You to 86 FRS For This Useful Post:
lbroskee (03-02-2013)
Old 03-02-2013, 07:03 PM   #422
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Im confused on how to tap the parking light wire with nigel harness
I dont wanna use a switch.
I want them on when parking lights are on.
How can i do this?
Old 03-02-2013, 07:11 PM   #423
frsguy707
frsguy707's Avatar
How can i do this?
Your gonna want to tap the tail light fuse
Sent from my SPH-L900 using Tapatalk 2
frsguy707 is offline   Reply With Quote
Old 03-02-2013, 07:18 PM   #424
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
How?
I do have to run the black wire (one that goes to the switch) inside.
But if i dont wanna use a switch
Why tap to the tail light?
Can i tap them to my day time running light so they come on when i lower my ebrake.
Old 03-02-2013, 07:50 PM   #425
frsguy707
frsguy707's Avatar
How?
Just run it and tuck it, thats what i did, you cant even see it. It beats cutting and splicing factory wires.
Old 03-02-2013, 07:54 PM   #426
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I still dont know what wire i have to use to tap pn mu side markers
Old 03-02-2013, 07:58 PM   #427
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Im not sure about this. But i think the black wire that goes inside to connect into switch that it came with the harness. Tap that black wite to the white wire in the side marker.
Old 03-02-2013, 07:59 PM   #428
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
from what i understand, the relay is red to battery, black to any ground. The switch is red to a power source of your choice and again black to ground. The red switch wire could go directly to the side markers or you could tap the fuse for the side markers or you could tap the fuse for the tail lights. You could then just leave the switch in the "on" position and stash it somewhere which is what i'll probably do unless it's easy enough to get it mounted. This will allow the fogs to always be on when you turn your headlights on.
abutterman is offline   Reply With Quote
Old 03-02-2013, 07:59 PM   #429
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
You think that will work?
Old 03-02-2013, 08:01 PM   #430
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Yes. Coz thats what i did to test the fogs. Before putting the wire thru the firewall and to the switch.
Old 03-02-2013, 09:15 PM   #431
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Originally Posted by indesign View Post
still waiting on my harness. should have went with ebay or amazon.
anyone running l.e.d bulbs?
Led bulbs suck as far as light out put.
Juanito08 is offline   Reply With Quote
Old 03-02-2013, 11:01 PM   #432
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
Originally Posted by terrypm View Post
I was confused because others, along with the DIY video, were saying you need to tap into the side marker for the fog lights to work.
Nigel's harness comes with a fuse included on the harness off the red wire from the relay but there is no fuse on the red wire from the switch.
You can tie the red wire from the switch into an existing circuit such as key ignition and you will not need a fuse because that circuit should already have one. If you tie into an existing, the switch will not work by itself, it will work whenever you turn what you tied it into on, then you can operate the switch. If you hook it directly up to the battery(as the power source) then the switch will work by itself and you can turn the fogs on and off whenever without turning something else off too. If you go directly to the battery from the switch though, it is strongly advised you put a fuse between the circuit to protect your switch and the inside of your car.
Note: If you look at any circuit where power is connected directly to the battery(relay of harness for example), it will have a fuse. This is to protect the electrical device and your circuitry so you dont fry your system if a surge or spike, etc.. goes through.
b$m1th91 is offline   Reply With Quote
Old 03-02-2013, 11:30 PM   #433
b$m1th91
b$m1th91's Avatar
Originally Posted by DarrenDriven View Post
What rims are those?? They're sick looking!!
Old 03-03-2013, 12:15 AM   #434
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
rota torques, hyper black.
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
FINALLY - Got my FR-S SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 28 08-03-2012 05:16 PM
FINALLY GOT IT! Ayaz2589 NY / NJ / CT / PA 8 07-28-2012 02:52 AM
Finally got it!! percyng CANADA 21 06-17-2012 01:50 AM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
