Old 12-29-2012, 05:49 PM   #29
Future
Future's Avatar
Drives: BRZ!
Thank you so much, will try this asap
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 12-29-2012, 09:26 PM   #30
Ben_G
Drives: Blue BRZ
Originally Posted by 8987846 View Post
i was going to switch the pins. but i found cable connection on OEM unit is different from those retail ones. that means i need to buy a extra harness($60).
You're talking about the harness that plugs in beside the green plug in the back of the Pioneer navi unit? Where did you find the harness for sale?
Ben_G is offline   Reply With Quote
Old 12-29-2012, 10:08 PM   #31
8987846
Drives: BRZ MT SWP
[ame="http://www.amazon.ca/Replacement-Assembly-Harness-Pioneer-X9310BT/dp/B0088HRFJG/ref=sr_1_4?ie=UTF8&m=A24X6BONU07T8U&qid=1352489637 &s=generic&sr=1-4"]Subaru Replacement RCA Cord Assembly AV Radio Harness for Pioneer Avic X9310BT.: Amazon.ca: generic[/ame]
this is the cheapest one i found.
or the ebay :
http://www.ebay.ca/itm/Pioneer-Avic-...ht_1810wt_1163
8987846 is offline   Reply With Quote
Old 12-29-2012, 11:20 PM   #32
Ben_G
Drives: Blue BRZ
Thanks! I just found the same thing just now!
Old 01-01-2013, 05:51 PM   #33
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
"Place the 2 folders “Firmware” and “Update” along with the file “CARDINFO.cif” at G:\. (only these 2 folders + 1 file, the others in the torrent are useless at this time)"
I dont understand this step. I dont see these folders from the file that i downloaded from piratebay
vignesh is offline   Reply With Quote
Old 01-01-2013, 05:53 PM   #34
Ben_G
Drives: Blue BRZ
In the torrent you downloaded, you should have a zip file called "2012 upgrade.rar"
When you unzip that, it will create a folder called "z140 Files" and within that folder, you'll see the two folders and cardinfo.cif file.
Old 01-02-2013, 10:24 AM   #35
mikep
Drives: 2013 Subaru BRZ Sport-Tech SWP
I finally got my navigation bypass completed, mostly using USB.
You can use USB to access the file navigation using testmode.key, but you must use a SD card to do the maps update, I couldn't get the update to be detected on the USB drive.
To get the RenewalIFLib Replacement working with USB, you need to change lines 12 and 13 of ScriptExec.ini from:
12 COPY -c SD\RenewalIFLib.dll USER\PRG0\APL\RenewalIFLib.dll
13 COPY -c SD\RenewalIFLib.dll USER\PRG1\APL\RenewalIFLib.dll
to
12 COPY -c USB\RenewalIFLib.dll USER\PRG0\APL\RenewalIFLib.dll
13 COPY -c USB\RenewalIFLib.dll USER\PRG1\APL\RenewalIFLib.dll
mikep is offline   Reply With Quote
The Following User Says Thank You to mikep For This Useful Post:
djdnz (01-02-2013)
Old 02-01-2013, 11:07 AM   #36
KingRohan
Drives: BRZ Sport Tech 6sp
Great info, was researching this last night on avic411.com for hours on how to do it.
This takes out some of the guess work.
KingRohan is offline   Reply With Quote
Old 03-01-2013, 10:08 PM   #37
cocoy_labuyo
Drives: WRB BRZ
Does anyone have a copy of the NAVI.exe that needs to be edited? I checked my backup and double checked everything but I can't find the offset strings. I have the same model as indicated and supported by the hack to no avail. can't find it. anyone?
cocoy_labuyo is offline   Reply With Quote
Old 03-02-2013, 09:41 AM   #38
Ben_G
Drives: Blue BRZ
I had this problem too, but I wasn't able to find the hex string under PRG0 I found it under the PRG1 folder. I ended up finding the reason in the third AVIC411 link provided which says that the Navi file used is under the PRG1 folder if there is a USER folder that contains a PRG.FLG file. I edited the Navi.exe file from the PRG1 folder and it all works great now.
Old 03-02-2013, 12:21 PM   #39
cocoy_labuyo
Drives: WRB BRZ
I checked PRG1 folder too from my back-ups and I still can't find the hex strings. Do you still have the folder backed up? Maybe I can get a copy from you and compare what I missed with my backup.
Old 03-02-2013, 01:06 PM   #40
Ben_G
Drives: Blue BRZ
Sorry, that I don't have.
Old 03-09-2013, 01:37 PM   #41
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
bought the wiring harness, received it yesterday... i will probably try tonight the mute grounding bypass to unlock the DVD feature
Walla Walla is offline   Reply With Quote
Old 03-11-2013, 08:56 PM   #42
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
It would be Very nice to have the ability to play movies for passengers on longer road trips.
Deadspool is offline   Reply With Quote
BRZ Navi in the FRS? nocurfew Electronics | Audio | NAV | Infotainment 15 11-19-2012 05:37 PM
Canadian BRZ Navi EQ settings? Burrcold CANADA 10 11-13-2012 10:49 PM
BRZ Canadian Navi (Pioneer) Ipod Issue zex Electronics | Audio | NAV | Infotainment 0 08-15-2012 09:04 PM
Adding navi to FRS Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 9 06-04-2012 10:14 AM
Adding Navi to the FRS? Pake1 Electronics | Audio | NAV | Infotainment 3 06-01-2012 01:26 PM
