Old 02-28-2013, 02:14 PM   #1
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Reverse light relocation
Did a quick search with no results.
Has anyone relocated their reverse lights to the tail lights? and or deleted the lower bumper/diffuser light setup?
I ask because if in the future i modify the rear to include a diffuser or body kit i would still like my reverse lights visible.
Old 02-28-2013, 03:08 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I haven't seen it but it seems easier to do than the 4th brake light mod.
Swap the 7440 sockets for the turn signals out for 7443 sockets. Attach the reverse light positive to the dominant wire, the turn positive to the weaker positive, and the ground to ground. Use switchback led bulbs...done.
The Following 3 Users Say Thank You to boredom.is.me For This Useful Post:
03Z33 (02-28-2013), lbroskee (05-07-2014), norsamerican (02-28-2013)
Old 02-28-2013, 03:11 PM   #3
boredom.is.me
Custom User Title
I like this idea. This just might be my spring break project.
Old 02-28-2013, 03:15 PM   #4
norsamerican
Drives: WRB BRZ
haha its on my TO DO list.
Old 02-28-2013, 04:33 PM   #5
boredom.is.me
Custom User Title
The hardest part might be finding the right socket. I think they all have the same physical layout and size though. I'll check tonight.
The Following User Says Thank You to boredom.is.me For This Useful Post:
norsamerican (03-01-2013)
Old 03-01-2013, 09:18 AM   #6
boredom.is.me
Custom User Title
Crap, I forgot to check.
Old 03-01-2013, 12:27 PM   #7
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Manufacturers of these body kits or diffusers take that into consideration when drafting up ideas for their products. It would be pretty shitty if they just blocked your reverse lights and said: deal with it.
Of course you knew that though... so are you fabbing up your own stuff? I'm just curious.
EvilBeaverFace is offline   Reply With Quote
Old 03-01-2013, 12:57 PM   #8
boredom.is.me
Custom User Title
What? There shouldn't be any fabbing required. And what exactly do manufacturers take into consideration?
Old 03-02-2013, 01:04 PM   #9
EvilBeaverFace
see the connection yet? I didn't mean fabbing was a requirement to relocate, but rather a reason to want to. Professional manufacturers of body kits and diffusers would take into consideration of your reverse lights, rather than blocking them or deleting them and telling you to deal with it on your own.
Here is an example of someone fabbing up their own stuff to warrant a need for relocated reverse lights.
Old 03-02-2013, 02:55 PM   #10
DIM
This is the only body kit i've seen the relocated the reverse light right next to the tail lights.
DIM is offline   Reply With Quote
Old 03-02-2013, 03:05 PM   #11
boredom.is.me
Custom User Title
Ah I see. I wasn't thinking as far as you were.
I forgot to check again. I'm going to have to set an alarm...
Old 05-06-2014, 11:08 PM   #12
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
So has anyone taken the connector from the front signals and used them in the rears with switch backs yet?
thatfilipinoguy is offline   Reply With Quote
Old 05-06-2014, 11:10 PM   #13
DC2R
Drives: 2014 Scion FR-S
....I just want more bright!
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 05-07-2014, 12:05 AM   #14
thatfilipinoguy
I can't sleep because I keep thinking about this. What about swapping the connectors for the front signals and the rears via depinning. Then, you run the power/signal wires from the reverse lights to the newly swapped connector at the tailight housing. Finally, install switchbacks and viola! You have reverse lights in a much better location!
help! reverse light not working nab335 Cosmetic Modification (Interior/Exterior/Lighting) 4 10-14-2013 05:59 PM
Lamin-X - Headlight - Reverse Light Pieces TeamSweet86 Exterior Parts (Aero, Lighting, Etc.) 1 12-10-2012 04:34 PM
