Old 02-25-2013, 08:03 PM   #1
GotM
GotM's Avatar
Drives: 14 Porsche Cayman S
Wheel Directory: Enkei RPF1 17x7.0 +42
New Set-up for the BRZ.
Enkei RPF1 17x7 42
BF Goodrich G-force Rivals 225/45/17
Name:  side angle.jpg
Front view.
Rear view.
Enkei RPF1 17x7 & new BF Goodrich Rivals 225/45/17, 37.8lbs.
Name:  enkei weight.jpg
Stock wheel and tire weight 40.6Lbs ~2000miles on tires.
Name:  stock weight.jpg
BF Goodrich Rivals 225/45/17 vs Stock Michelins 215/45/17
Name:  side by side.jpg
Tire tread width came in right at 8.5 inches.
Previous cars:
2013 Subaru BRZ (2012-2017)
2009 BMW135 6MT (2009-2012)
1999 BMW M Roadster (2000-2010)
2004 Audi A6 2.7T (2004-2007)
GotM is offline   Reply With Quote
Old 02-25-2013, 08:05 PM   #2
was385
Drives: MT WRB BRZ Limited, 2007 911s
Looks great. This is the exact setup I want. What is your opinion on the Rivals so far?
was385 is offline   Reply With Quote
Old 02-25-2013, 11:45 PM   #3
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
looking good ..nice square tire profile
Gearhd79 is offline   Reply With Quote
Old 02-26-2013, 12:04 AM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I rarely say this but damn, does it need a drop.
Old 02-26-2013, 01:56 AM   #5
brz7400
brz7400's Avatar
Drives: Subaru BRZ
this must be the first pics of the 17x7, thank you. the 42mm offset looks perfect to me.
the rival's shoulder doesn't look too pleasing, but if it performs like they say it does, i want them too
brz7400 is offline   Reply With Quote
Old 02-28-2013, 08:25 AM   #6
GotM
GotM's Avatar
I only have about 100 miles on them now.
Dry grip: much better than the stock tires, but would we expect any different. I will have a better comparison at the end of the month.
Wet grip: It doenst rain often enoght here
Noise: These are noisy, but so are the stock tires. It does seem more noisy.
I agree, but to remain in a stock class you really cant do anything to help.
It almost looks like a truck.
Previous cars:
Old 02-28-2013, 08:57 AM   #7
FR-S Matt
I've got the BF Goodrich Rivals on my Camaro, good tires.
Old 02-28-2013, 09:21 AM   #8
DarkSunrise
DarkSunrise's Avatar
Looks nice on blue.
2022 BRZ Build
2013 FR-S Build
Old 02-28-2013, 10:01 AM   #9
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Looks great!
Psst. Mach V springs.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 02-28-2013, 11:11 AM   #10
was385
Good to know. I've got a while before I run through the stocks but its nice to have another affordable option with the z2 and rs3s
Old 02-28-2013, 02:09 PM   #11
jeebus
oooh I am way curious about those rivals. Nice job on a grippy, light, stock-legal setup!
jeebus is offline   Reply With Quote
Old 03-02-2013, 08:16 PM   #12
SVThis
SVThis's Avatar
Drives: Scion FRS
Mine are a bit heavier with 225/45R17 DZ2's
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 03-14-2013, 03:15 PM   #13
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory
http://tinyurl.com/86wheels
Old 03-24-2013, 07:32 PM   #14
GotM
GotM's Avatar
Ran last week with the new set of tires and wheels. I started off the day at 38psi front and 36psi rear.
The rear pressure seemed to work well, but had to bump up the fronts a few psi to get the wear in the right spot. I think I went to 44psi hot in front and that worked better.
I may have been over driving the car, I am new at this .
I think I will start with 40psi cold in the fron next event and see if this is a better starting point.
Previous cars:
Wheel Directory: Enkei RPF1 17x7.5 +48 Guillaume Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 04-12-2021 04:30 PM
Wheel Directory: Enkei EV5 17x7.0 +38 rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-17-2016 11:47 AM
Wheel Directory: Enkei RPF1 Type-II 17x7.0 +48 hankster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 10-05-2013 02:23 AM
Wheel Directory: Enkei FLC-01 17x7.0 +40 Mr.Jay Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-09-2013 03:44 PM
Wheel Directory: Enkei WTE II 17x7.0 +41 stout90 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-06-2013 10:18 PM
