Old 02-25-2013, 04:38 PM   #127
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
So what all do I need to make this work? I see that the Rydeen duo is like only $100. Which wiring harness do I need to just plug and play into the stock BRZ head unit?
tripjammer is offline   Reply With Quote
Old 02-25-2013, 04:41 PM   #128
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
contact SVDX and he will send you the harness. you literally plug that into the back of your head unit and tap the red wire or use the harness he provides and thats it. then all you have to do is run all the wiring back to the trunk, drill your trunk garnish and tuck all the wiring and thats its. really no more than an hour if you take your time and kill a 6-pack
Jive Turkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
lbroskee (02-25-2013), tripjammer (02-25-2013)
Old 02-25-2013, 05:24 PM   #129
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Does using the factory mounting location throw off the image since it's off center?
Skippman is offline   Reply With Quote
Old 02-25-2013, 05:38 PM   #130
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
No because the lines that are built into the factory deck are skewed to match. The factory location works great and if you start looking at other cars with factory back up cams you will notice they are almost always off center.
chadstyle is offline   Reply With Quote
The Following 2 Users Say Thank You to chadstyle For This Useful Post:
Jive Turkey (02-27-2013), tripjammer (02-25-2013)
Old 02-27-2013, 04:40 PM   #131
Jive Turkey
the tuna, no crust.
to be honest i dont even pay attention to the lines, you can visually see the distance of the bumper to w/e is behind you.
Old 02-27-2013, 05:40 PM   #132
Foobar
SLO NO MO
Foobar's Avatar
Not only that, but you can configure the line placement anyway. I have a license plate camera that's dead center - I adjusted the lines to reflect the same.
Old 02-27-2013, 05:47 PM   #133
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
For symmetry freaks like me who hate offset stuff, you can adjust the lines on the camera via the HU. I installed m Rydeen smack dab center and its way more stealth than the offset install.
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 02-27-2013, 05:48 PM   #134
xjohnx
Grip>Slip
xjohnx's Avatar
BRZ Limited owners don't have that option, unfortunately.
Old 02-27-2013, 08:12 PM   #135
chadstyle
chadstyle's Avatar
This^^^
Old 02-27-2013, 08:30 PM   #136
Norkoastal
Norkoastal's Avatar
One advantage of the Premium Sorry Limiteds no center mount for you!
CO>CA Cartel
Old 03-01-2013, 12:40 AM   #137
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
any1 got a link where to pickup this camera from?
lbroskee is offline   Reply With Quote
Old 03-01-2013, 01:43 AM   #138
kludger
kludger's Avatar
Drives: '13 Boxter S, '13 BRZ(gone)
Yep I posted where I picked mine up from on a prev post in this thread see:
http://www.ft86club.com/forums/showp...&postcount=103
kludger is offline   Reply With Quote
Old 03-01-2013, 02:09 AM   #139
lbroskee
lbroskee's Avatar
thanx, i missed that. any update on if it works perfectly too?
Old 03-01-2013, 12:21 PM   #140
kludger
kludger's Avatar
I've been waiting on svxdc to return for the power wire update on the HU harness so haven't done the install yet (don't want to tap the factory harness), but I think a couple of others may have ordered from there as well and I haven't heard anything negative...
I'm getting pretty antsy though so I might end up installing anyhow soon.
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 03:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 03:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 12:32 PM
Want to buy a BRZ Limited AT kgc Northwest 1 06-17-2012 12:45 AM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 01:50 PM
