Old 02-25-2013, 11:03 PM   #43
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by chadstyle View Post
@Sportsguy83 I know I'm a little bit north of you but I'd be happy to help... If you have ever watched Street Customs then you would know I'm the "car audio guru"
@Acree has posted some very useful and technical information and he def knows what he's talking about. I'm sure I can get the dimmer to work properly in the aftermarket gauges...I've never let one beat me to date and in not about to start now.
Thanks man, I'll take you up on that offer if I run into issues when connecting them.
Old 02-25-2013, 11:18 PM   #44
Sportsguy83
Drives: Limited BRZ
@chadstyle, @dwx, @Acree I am planning on getting add a circuit tap (see below image)
I will connect both gauges together and tapping them into the spot below (its not used by the car but has 12V ignition power. (See pic below, the fuse spot between DRL and Tail)
Thoughts, comments, suggestions?
Old 02-27-2013, 01:03 AM   #45
Sportsguy83
Drives: Limited BRZ
bump?
Old 03-01-2013, 05:18 AM   #46
Sportsguy83
Drives: Limited BRZ
Originally Posted by dwx View Post
There isn't a good way to get a 0-12v with the newer Subarus which are PWM for most dimming. The older models used a 12v hot side (Ill+) and then a floating ground which was 0-12v (Ill-) which controlled the dimming. With the PWM models the Ill- (the B/W wire in your diagram) is a ground while the Ill+ is still +12v all the time. With the old models you could use a simple circuit to output a 0-12v signal for gauges to use.
Probably the easiest way to control dimming is use some kind of potentiometer unfortunately. Or build something to convert the PWM to an analog 0-12v signal...
Those wires you are looking at go to the gauge cluster directly I believe to control lights which are not LEDs? So they use the old method where they are 4.1v hot all the time on one side and reversed 0-3.8v based on the dimmer switch. Just my guess.
Where in the car can I find the Ill+ or Ill- cables?
Old 03-01-2013, 05:01 PM   #47
xwd
The Ill+ you can get off the TAIL or PANEL fuse or various other points. Check out the BRZ wiring manual. I'll- off the dimmer switch, radio, etc but its a PWM signal and probably not much use.
Old 03-01-2013, 09:23 PM   #48
Sportsguy83
Drives: Limited BRZ
The Failsafe guague can be calibrate to use either 12V signal or 0V signal, that's why I think the Ill- "might" work. So, if I want to take the Ill+ from the Tail fuse, the way to do it is via Add a fuse correct? (Again, I apologize for the dumb questions, I'm not very educated with car wiring... at all).
Old 03-25-2013, 03:25 AM   #49
Lonely Sushi
Drives: 2013 Scion FRS
Hello guys,
I am also looking for the tach rpm signal wire.... so far with no success. I need it for my Racepak G2X rpm signal. On the wiring diagram it says connector A35 pin 15 with a gray/red wire should do, but on my FRS that pin on that connector is empty.... BRZ and FRS dont share the same wiring ??
Lonely Sushi is offline   Reply With Quote
Old 03-25-2013, 07:10 AM   #50
Sportsguy83
Drives: Limited BRZ
I have the dimmer wire hooked up properly to my AEM gauge which allows the dimmer circuit to be either 0 to 12v or 12 to 0v. Unfortunetly, the difference in V between dim and not dim is not enough to change the gauge. I would recommend just leaving that wire unhooked. As for RPM, there are a couple wires that you can use:
Pin 17 on connector D48 Gray Wire
Pin 15 on connector A35 Gray/Red Wire
I haven't gotten around to trying either of these yet though.
Originally Posted by Lonely Sushi View Post
Hello guys,
Use Pin 17 on connector D48, Gray wire.
I spoke yesterday with @King Tut and he has successfully connected it already. I'll do it this weekend.
Old 03-25-2013, 07:39 AM   #51
Lonely Sushi
I see, Let me try again tomorrow... I tried to look for the D48 connector and couldnt find it today >: /
Old 03-25-2013, 07:41 AM   #52
Sportsguy83
Drives: Limited BRZ
That pin goes to a box close to the ECU. If you can;t find it, I will hook it up next weekend so I'll try to remember to take a pic.
Old 03-25-2013, 07:44 AM   #53
Lonely Sushi
Appreciate it, hopefully my eye sight gets better tomorrow when I look for it
Old 03-25-2013, 03:13 PM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The connector is one of the three that goes to the thin certification ECU box that mounts lower than the ECU does.
Old 03-27-2013, 01:52 AM   #55
Lonely Sushi
Hmm... is it possible BRZ and FRS has different wiring?
I looked under there once more and cant find the thin box you mentioned... below is the picture showing the ECU and where I think the "thin box" should be? its just a plastic mount there at the moment...
(sorry for the bad cell phone pic...)
Old 03-27-2013, 04:11 PM   #56
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I can't see the pic at work, but I will check when I get home.
dash, gauge, gaugle cluster, pod
What is that blinking dash light when the car is off? JayNutter Scion FR-S / Toyota 86 GT86 General Forum 7 02-03-2014 10:59 AM
WTB: FRS instrument cluster jabbajaw99 Interior Parts (Incl. Lighting) 3 02-14-2013 01:31 PM
surprised at how much MORE i like the frs dash cluster pr086 Scion FR-S / Toyota 86 GT86 General Forum 26 12-07-2012 09:09 PM
Flashing Security Light in Dash? ravenMTgirl Electronics | Audio | NAV | Infotainment 8 11-21-2012 03:25 PM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 07:50 AM
