Old 08-16-2012, 11:30 AM   #1
ravenMTgirl
ravenMTgirl's Avatar
Drives: Raven FR-S
Flashing Security Light in Dash?
I was sure when I first got the car there was a flashing security light in the dash after you lock the doors with the fob. Can someone confirm if the FR-S has this? Our tC has one even though there's no alarm.
ravenMTgirl is offline   Reply With Quote
Old 08-16-2012, 12:56 PM   #2
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
Mine does not have a flasher. I was just thinking about this last night in fact when I noticed my Legacy has a blinker, so I went and checked the FR-S and it didn't
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 08-16-2012, 03:23 PM   #3
Revmatch
Revmatch's Avatar
Drives: 2013 FR-S Black
Mine has one, I remember noticing it yesterday when I was parked in the garage at work. I will have to look closer to tell you where it is located. I was used to this on my tC and was happy to see that the FR-S had the same thing.
Revmatch is offline   Reply With Quote
Old 08-18-2012, 12:25 PM   #4
nocurfew
nocurfew's Avatar
Drives: Whiteout FR-S
I can confirm the FR-S has the security blinking light.
nocurfew is offline   Reply With Quote
Old 08-18-2012, 01:24 PM   #5
Derrickchai39
Drives: FR-S Raven
I know theres a light that blinks on the dash, when you have the key in the car. to warn you that the key is somewhere in your car (ex. in your pocket) just in case you dont lock your car and leave your keys inside.
Derrickchai39 is offline   Reply With Quote
Old 08-18-2012, 05:08 PM   #6
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The FR-S does have a security light when the car is locked.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-18-2012, 05:10 PM   #7
driver01
Drives: brz 13
FR-S does have this light, even though it has no alarm. The light means that the immobilizer is set. After inserting the key, the car will read the transponder inside the key. if the transponder code is a match, light goes off car fires up. If the transponder code in the key is not registered with the immobilizer ecu, the ecu will cut fuel. The car will crank but it will not start cuz the injectors are not opening. you can get a key that actually turn the ignition cylinder and makes the car crank however it will not start.
driver01 is offline   Reply With Quote
Old 08-18-2012, 05:41 PM   #8
ravenMTgirl
Drives: Raven FR-S
Thanks for confirming mine quit flashing for a couple days but now its working again. I guess I'll make an appointment if it stops again.
Old 11-21-2012, 03:25 PM   #9
pituala
Mr. Know It All
Drives: 2013 FR-S Asphalt
Mine never flashed, and just today it started flashing.....or somehow I never noticed it before and all the sudden I do notice it???
2013 FR-S Asphalt MT (55w HID's)
1985 Celica Supra 1JZ (Stupid Fast)
pituala is offline   Reply With Quote
Traction light flashing under trail braking; TC and VSC are both off... CSG Mike Tracking / Autocross / HPDE / Drifting 72 06-12-2016 08:18 AM
Light flashing under trail braking. CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-16-2012 04:10 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
Turn signal amber LED's flashing quickly michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 11 07-13-2012 10:55 PM
anybody else see the flashing carrot??? poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 46 01-18-2012 09:25 AM
