Old 02-25-2013, 02:33 PM   #99
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by Jive Turkey View Post
i'm doing this exact switch today to me the drone on the greddy wasn't THAT bad but it was definitely there. i'll report back. i'm also going to do the nameless catted/resonated front/overpipe with this non resonated perrin catback.
Should be a good combo - would love to hear your feedback once you have the nameless combo up front, but at this point I'm leaning towards the Perrin OP/catted FP just to keep it all together.
If nothing else, maybe we can compare the two combinations at a future meet up.
Old 02-25-2013, 02:39 PM   #100
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
the reason i'm choosing nameless is because it is 1 piece. thus less issues with leaks because there is less gasket etc... in the end i think the gains will be the same but i know for a fact i want a resonator in the front pipe, even if the catback is resonated. i was fully catless and unresonated on my sti, NOT doing that with an NA car
i should have that within a month or so, just gotta buy my coils first
Jive Turkey is offline   Reply With Quote
Old 02-25-2013, 03:04 PM   #101
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
I heard they have been back ordered for over 2 month, when did you guys all get yours?
shu5892001 is offline   Reply With Quote
Old 02-25-2013, 03:08 PM   #102
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
LOVING the subtle rumble from the resonated version.
I ordered mine on Saturday the 16th and it showed up Wednesday.
Chewie4299 is offline   Reply With Quote
Old 02-25-2013, 03:12 PM   #103
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Never heard of a leak with the Perrin. There is only 1 gasket on the Perrin where the mid pipe meets the front pipe. The other two seals on the Perrin are gasketless V-Band Clamps which seal very well.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 02-25-2013, 03:22 PM   #104
Foobar
SLO NO MO
Foobar's Avatar
Ordered mine back in November (Black Friday) and received it in January.
He's referring to the Overpipe/Frontpipe combo. Nameless sells this as one long pipe from header to catback. Perrin has two separate components, keeping it similar to the stock configuration (albeit with a much better flow).
I'm going with Perrin just to keep everything in my system the same, and I figure it'll be easier to do a driveway install of the Perrin components on ramps/jackstands, whereas the Nameless (I presume) will need more clearance via a lift since it's a longer piece that you'll need to leverage. Someone with experience installing it can feel free to correct me.
The Following User Says Thank You to Foobar For This Useful Post:
shu5892001 (02-25-2013)
Old 02-25-2013, 03:26 PM   #105
Jive Turkey
the tuna, no crust.
i never said it leaked, i said that by having one piece you eliminate the POSSIBILITY of it not making a seal.
as for the install i'm no worried about clearance to be honest, i'll be doing it in the driveway as well.
in the end its the same shit, i just want a helmholtz resonator in my system. in the end its the header that will make or break the power here.
Old 02-25-2013, 03:36 PM   #106
Foobar
SLO NO MO
Foobar's Avatar
Definitely - you can't go wrong with either of them in my opinion. As for the Nameless install needing more clearance, that's just an assumption of mine - I could be wrong, but based on the pictures of the pipe and where it needs to snake into, it looks like a lift would be your best bet, but again, I haven't done it myself so someone with experience, please feel free to keep me honest here.
Old 02-25-2013, 04:47 PM   #107
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
The Nameless pipe is less expensive than separate front and over pipes too. I would expect you'd need a lot of space under the car to snake the front of it over the cross member. I'd ask Nameless before you install just to be sure, would suck to find out your jack and stands don't go high enough after pulling stuff apart.
Mobius357 is offline   Reply With Quote
Old 02-25-2013, 07:34 PM   #108
Visconti
Drives: 05 STi
Originally Posted by Chewie4299 View Post
Do it.
I'm about to pull the trigger on the resonated catback myself. I absolutely LOVE the way it sounds and looks.
Just hesitating likely in the same way as you. I KNOW I want it I just KNOW I'll regret (temporarily) shelling out the cash at this point in time.
Cant go wrong with Perrin's exhaust !
Visconti is offline   Reply With Quote
Old 02-25-2013, 07:36 PM   #109
Chewie4299
Spaceman
Chewie4299's Avatar
Yep, I love it. Installed it yesterday and it is exactly what I wanted as far as sound goes. The quality is fantastic.
Old 02-25-2013, 10:36 PM   #110
Jive Turkey
the tuna, no crust.
i have access to a lift so i'm not worried much about the over pipe/fornt pipe to be honest, at most i'll jack the motor up if i do it on the ground.
now for the good stuff... i just got rid of my greddy, and instead put on a perrin NOT-resonated catback. all i can say is holy****. difference is unbelievable in sound. perrin is almost stock sounding to me at this point, SO QUIET and zero drone/cabin noise but it has a very nice tone from what i could hear when ripping under bridges. install was easy, just have to mess with the v-bands to align the tips just right.
now i'm sorry for not my usual picture quality, hands were too dirty to grab my camera so i used hipstergram follow me @comrad
greddy before i polished her up:
perrin:
Old 02-26-2013, 04:49 PM   #111
Chewie4299
Spaceman
Chewie4299's Avatar
WOOT just received my Perrin intake and Perrin inlet hose to go with the Perrin catback I just installed.
What am I gonna do with 6 license plate frames?
Guess I'll throw two on my Jeep.
The Following User Says Thank You to Chewie4299 For This Useful Post:
PERRIN_Mladen (02-26-2013)
Old 02-26-2013, 04:52 PM   #112
sieeegel
Drives: rsx was stolen :(
Im selling my Unresonated perrin MIDPIPE if anyone is interested. Was only used for 1 week.
sieeegel is offline   Reply With Quote
To pull the trigger or to wait? that_one_guy Scion FR-S / Toyota 86 GT86 General Forum 17 10-24-2012 04:17 PM
Pulling the trigger this afternoon, some last minute questions. shu5892001 Scion FR-S / Toyota 86 GT86 General Forum 19 08-29-2012 09:06 PM
pulled the trigger after 22 minutes. robbins226 Scion FR-S / Toyota 86 GT86 General Forum 3 07-09-2012 11:55 PM
Pulling the trigger tomorrow Style Scion FR-S / Toyota 86 GT86 General Forum 13 05-14-2012 02:38 PM
2007 STi... should I pull the trigger? RRnold Other Vehicles & General Automotive Discussions 25 02-23-2010 09:37 PM
