| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 | |
SLO NO MO
#30 |
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
Lux-motion 2.0 wide body. They haven't published the final kit, because they're still building it and I'm first in line... so that'll be fun... (-_-)
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3 2013 Scion FR-S 2011 Land Rover LR4 2013 Lamborghini Gallardo LP570-4 Superleggera |
#31 |
If you're going to increase traction, why only do the rear, when you can do the front too for minimal additional cost? It won't *hurt* you in any way, and gives you the flexibility to rotate tires.
The only reason to go staggered is because you simply cannot fit the rim/tire you want in the front. |
#32 | |
2005 Lotus Elise
#33 |
Drives: Raven Black FR-S
I went staggered for looks and also the cars that I drive occasionally (porsche cayman and bmw 535i f10) are also staggered and I'm more familiar with the grip/ correction with more throttle. Although my Rx8 was square and really really neutral and fun to throw around the mountains, I like the security of a little understeer just because I don't have the funds to fix it if i break it hehehe...
I could always just add stiffer sways in the rears to get more oversteer, but my set up right now has plenty of oversteer and I can still do donuts for days
#34 |
WWPD
What Would Porsche Do?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following User Says Thank You to swift996 For This Useful Post: | SLICVIC (02-28-2013) |
#35 |
Drives: White MT FR-S
#36 | |
#37 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Amadeus (02-26-2013) |
#38 | |
Drives: Scion FR-S (Raven)
With stronger longer studs it makes no difference. Lots of track racers and racecars use spacers all the time.
2013 Raven FR-S MT + Sparco Assetto 18x8 + Michelinn Pilot Super Sprot 225/40/r18 + Takeda CAI + Fortune Auto 500 coilovers + Tanabe Sustec front and Rear strut tower brace + Carbeau FX1 / 6 point harness / Harness Bar + Nameless front pipe + Perrin cat back + FA20club E85 tune + Wilwood front & rear brakes
#39 |
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
well my goals are mainly going to be streetable a fun frs with some auto x and drift on the side. I know for sure I will eventually get a turbo kit looking to get around 350 whp. And I mainly want to use the car as a fun dd/week end warrior. I hate drag. Is Square still okay with this setup?
Everyone says if you go turbo get staggered but why? just because of the more grip? Cant i upgrade the tires and go a little wider and bigger and still be fine? |
#40 |
Drives: 2013 FR-S Ultramarine
I agree with @CSG Mike. You want as much grip in the front as possible, there's plenty of room for tire in the rear. ESPECIALLY on stock power, a staggered setup is purely for looks.
The only time I can see doing a staggered setup for a performance application on this car is to get more grip in the rear on a very high power setup when the fronts are already maxed out size wise. There are better ways to tune the limit characteristics of a car than forcefully limiting grip via tire size, especially in the front. Think about it this way. 225 front 255 rear. The car pushes into corners but is very stable under power since it has a lot of rubber in the rear. Now. Take the fronts and replace them with 255's. You've done nothing to sacrifice the rear grip, but your front grip has potentially improved. You still have great grip under power because again, your rear grip hasn't changed. But now, if you wanted to, you could tune your suspension to have similar limit characteristics as your 225 front setup, but your front tires are breaking traction because of the suspension setup and not because they've reached their ultimate grip level sooner than the rears due to their smaller width. Your new wider front tires are giving you the same driving characteristics and at least equal grip, while having an easier time at it. This means lower tire temps, longer tire life, and a system that as you learn to drive faster and wish for a more neutral car, you can tune it to be that way with a few small mods instead of buying a new pair of front wheels. Also. Comparing to Porsche or any other sports car is pointless. The 911 is a particularly bad example because it's weight distribution is the polar opposite of this car's with more than 60% of it's weight on the rear wheels and much of that being behind the wheels. Of course it runs staggered, because there's no other way to get the thing to handle in any kind of normal way. Cheers Nathan |
#41 |
Rocket Bunny FRS
at what hp are staggered rims/tires needed
#42 |
head of infinite swagger
Drives: 2013 FR-S 6MT
tire rotation as a reason not to go staggered is mostly a myth.
generally it just means you end up replacing your rear tires twice as often and your front tires half as often. unless your rear tires are drastically more expensive than the fronts for whatever reason it all nets out.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
| >>> Klutch SL14 staggered 18x8.5/18x9.5 wheels - starting @ $985.00 shipped | speed depot | Wheels and Tires | 35 | 12-05-2012 11:54 AM |
| Rotiform NUE Wheels 18" staggered FR-S Fitment in any color | GuerillaRacing | Wheels and Tires | 15 | 11-13-2012 01:52 PM |
| staggered and unstaggered wheels | 86 FRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-06-2012 04:27 PM |
