Old 01-12-2013, 01:58 PM   #15
TSY
TSY's Avatar
Drives: 2013 BRZ Limited SWP
Originally Posted by chadstyle View Post
Wow, 4 hours?!?!? I have never spent more than 45 minutes for a full install with soldered connections and run with factory harness. I couldn't imagine it ever taking that long...
Umm, this is what you said. I suppose I could be interpreting it wrong, but this is quite condescending whether it was your intention or not, as well as misleading someone who may have minimal experience taking the inside of their car apart.
I think it's easy enough to do if you take your time. Rushing it won't help and telling someone it's only 45" AT MOST is not helping them and just making them feel lame- I posted this for DIYers, not professional installers.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX
TSY is offline   Reply With Quote
Old 01-12-2013, 02:50 PM   #16
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
There's a HUGE difference between 45 minutes and 4 hours. I'm not telling anyone to "rush" anything. If you're DIY then take 2 weeks for all I care, its your time not mine. I was just surprised that it took 4 hours when the car is so little and running the wires takes only a few minutes.
You also made a comment that it was a pita to pass the wire through the trunk grommet and if you had to do it over you would cut the plug then re attach. I would never recommend this to anyone without tons of experience soldering, heat shrinking, and knows about video signal and shielded wires etc..these are small wires that the majority of people will screw up. I'd suggest a passing a long zip tie through the grommet from the opposite direction and then electrical tape the plug to the zip tie nice and tight and pull it through. A little soap helps them slide if they're sticking. I installed a Rydeen camera on my BRZ and I didn't need to use these techniques as the plug passed through the grommet with no issues at all but if someone is having a hard time I would offer that advice instead of cutting the plug off.
Lastly, if you're not a professional then why would you be writing a how to for other diy'ers? Blind leading the blind...
chadstyle is offline   Reply With Quote
Old 01-12-2013, 11:07 PM   #17
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
damn, nice install... however im always worried about these aftermartket rearview cameras with the hex/screw adjustment... i can just imagine someone trying to steal the camera or just screwing with the angle
i hope you enjoy yours for many years!
mikeg7827 is offline   Reply With Quote
The Following User Says Thank You to mikeg7827 For This Useful Post:
TSY (01-13-2013)
Old 01-13-2013, 02:47 PM   #18
TSY
TSY's Avatar
@chadstyle
Dude, you're the one who started hating on my install and what I did. You should be nicer about what you say in someone else's post.
And, um, how many DIY'ers are professionals? I wasn't telling people how to install the camera (this was done in other posts) I was just showing my own install so people can see how this camera looks to help people who have the skills to install something simple like this BUT DON'T DO IT EVERYDAY BECAUSE WE HAVE OTHER JOBS.
I'm just trying to be helpful to people dude just like I've benefited from others. I'd appreciate it you didn't keep insulting me (Blind leading blind, reallly???)
The Following 2 Users Say Thank You to TSY For This Useful Post:
mit_peid (04-24-2013), Sportsguy83 (01-13-2013)
Old 01-13-2013, 02:49 PM   #19
TSY
TSY's Avatar
Yeah, I know what you mean. But what can you do? They could key your car and break your windows too. Some people really suck, you know?
Old 02-26-2013, 02:29 PM   #20
dammitcubs
Drives: 2008 EVO X
this is a must. if i buy this car. AN ABSOLUTE MUST!!!
dammitcubs is offline   Reply With Quote
Old 02-26-2013, 06:37 PM   #21
TSY
TSY's Avatar
It totally makes backing up so much easier! And this camera is so clear night and day- awesome.
My Acura has a factory backup camera- it's awful compared to this one.
Old 02-26-2013, 07:13 PM   #22
dammitcubs
Drives: 2008 EVO X
How much did it cost?
Old 02-27-2013, 07:55 PM   #23
TSY
TSY's Avatar
I paid about $135 at the time. It's about $140-150 now. It really is nicely made, but it does cost more.
Old 02-27-2013, 08:11 PM   #24
dammitcubs
Drives: 2008 EVO X
I just hate doing the work. I'm a lazy man. LOL
Old 02-27-2013, 11:29 PM   #25
TSY
TSY's Avatar
LOL. Well, that's why you can hire someone to do it!
Old 04-03-2013, 12:00 AM   #26
Sensisnow
Drives: 05 TSX & 13 BRZ
I just ordered this same camera through Amazon and noticed that it lists the operating voltage as 14.4V (9.0 - 16 V allowable). Were you able to use the normal 6v harness from SVXdc, or did you have to tap into a 12v source somewhere?
Sensisnow is offline   Reply With Quote
Old 04-03-2013, 01:35 AM   #27
TSY
TSY's Avatar
No I had to tap a 12v source and the wiring to power the camera is back up at the head unit, so you'll have to tap a wire from the harness which is pretty easy.
pulling the wire through the rubber tubing at the trunk is a major pain- I would suggest lubricating it first!!!
Good luck with the install!
tom
Old 06-16-2013, 11:11 AM   #28
mtimney
mtimney's Avatar
OK...an old thread, but I have an important question....
Can you describe or post a photo that shows which wire you tapped into?
And, forgive this question but I don't know much about this stuff.... I know the camera will now come on when you go into reverse, but is the camera on all the time with this power tap? IF so, is that a bad thing?
mtimney is offline   Reply With Quote
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 12:07 PM
In car black box camera cgrey Scion FR-S / Toyota 86 GT86 General Forum 56 08-26-2012 07:35 PM
Reverse Camera - install question Sutty AUSTRALIA 1 07-28-2012 08:40 AM
Planning out my Kenwood install KRAZYK Electronics | Audio | NAV | Infotainment 1 07-19-2012 09:24 PM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
