Old 08-31-2012, 10:18 AM   #15
ayau
Drives: Some rust bucket
Originally Posted by F1point4 View Post
You're right. I pushed the tab back and got a darkened image. Then I tilted the mirror back until I got a normal image. It looks so much better this way.
Fixing the images in the DIY
i thought that as well at first. when i had the tab folded back, the mirror didn't tilt high enough to give me a good rear view. i looked at it with the black tab down and knew it didn't look right. you have a beautiful frameless mirror but then there's this ugly black tab sticking down. then i started looking at some jdm 86/brz brochure pics and saw that they all had the tab folded back. after playing with it some more, i realized that there are 2 pivot points on the mirror, and this allowed me to tilt the mirror higher to give me the optimal rear view. i believe there's only 1 pivot point on the stock mirror.
Old 08-31-2012, 01:23 PM   #16
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 08-31-2012, 08:51 PM   #17
motofan
Drives: 10 VW GTI
Interesting. I went downstairs to check and it's a definitely darker picture when I push the tab back. Mind checking yours when you get a chance?
I think they work either way, (at least on my car). If you adjust the mirror when when the tab is down, it becomes darker after you push it back; If you adjust the mirror when when the tab is up, it becomes darker after you pull it down.
I think the default position is up for day driving. It is in all the car owners manual I've read. I believe it is because you won't see the tab for most of the driving.
motofan is offline   Reply With Quote
Old 08-31-2012, 08:58 PM   #18
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Great pics and installation walkthrough.
cobrabyte is offline   Reply With Quote
Old 09-07-2012, 02:39 PM   #19
Turbowned
Turbowned's Avatar
It's amazing just how much sexier that frameless mirror looks! Forget the Homelink mirror - I'll find a way to make that work elsewhere!
Old 09-21-2012, 12:01 AM   #20
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Just installed this. Thanks for the DIY. One thing that tripped me up for a second is when you say "Now insert the other clip into the mirror by inserting the hairpin end first...." This makes it sound as if you place the clip into the mirror, but I think you're supposed to put the clip into the BASE. You do go on to say "...then pushing the sides into the WINDSHIELD BASE".
The way I did it, and what I think you mean, is that you put the clip into the windshield base, then screw on the new mirror (thereby putting the clip into the new mirror). Pretty obvious, but just to clear this up even further for others.
Phaedrus29 is offline   Reply With Quote
Old 09-21-2012, 12:14 AM   #21
ayau
yup. the clip goes into the windshield base first.
Old 12-17-2012, 02:44 PM   #22
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
Thank you to the OP for the DIY. Gf just bought this for me for my birthday, installed it in less than 5 minutes!
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
Old 02-25-2013, 05:10 PM   #23
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
I just got mine. I just used my fingers to pinch the clip out. Looks about the same... switched it out just in case. Looks good clean and pretty... all the guys at my shop says everything made overseas looks better and everything the US gets is BS....
Took about 1 - 2 mins to do. Most of the time was wasted opening box and taking pics, lol
sbxjap is offline   Reply With Quote
Old 03-08-2013, 03:21 AM   #24
BrianJC
Drives: 2013 Hot Lava FRS M/T
Did mine in minutes, thanks OP for the DIY!
BrianJC is offline   Reply With Quote
Old 06-26-2013, 04:28 AM   #25
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
@thatWESguy @sbxjap @ducks @Turbowned @F1point4 or anybody else who has this, for the ball joint that is closer to the windshield mount, is that in a fixed position (cannot be adjusted)? If so, is the bracket arm centered, angled to the left (so mirror is closer to driver's side), or angled right (closer to passenger)? See pic below.
I looked at my stock USDM mirror and it angles to the left. The ball joint closer to windsheld seems to be in a fixed position/not adjustable. I could only adjust the ball joint attached to the mirror's backing like you do when you normally adjust rear view mirrors.
Old 06-26-2013, 09:41 AM   #26
ducks
Drives: car
it is adjustable.
ducks is offline   Reply With Quote
Old 06-26-2013, 05:08 PM   #27
Turbowned
Turbowned's Avatar
*shrug* I just snapped it in and angled the mirror so that I could see out the back window. Sorry.
Old 06-30-2013, 01:20 PM   #28
sbxjap
sbxjap's Avatar
I didn't pay attention. It seems the same as stock as for where the ball joint is. Seems centered... I think? Lol
Ill have to look again, but I think it's both adjustable
diy, frameless, jdm, mirror, rear view mirror
Stock Rear View Camera for Fujitsu Ten? Foobar Electronics | Audio | NAV | Infotainment 151 08-19-2021 11:24 AM
DIY-Replacing Rear View Mirror/Hardwire Radar Detector Lil Abner DIY (Do-It-Yourself) Guides 40 06-11-2020 02:48 PM
What will you hang from your rear view mirror? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 148 11-15-2013 02:52 PM
Taking rear view mirror off ? JB1 Cosmetic Modification (Interior/Exterior/Lighting) 7 06-21-2012 09:53 AM
Rear view Mirror pic nixeighty6 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 45 01-27-2012 05:10 PM
